- From: Guillaume Melquiond <guillaume.melquiond AT inria.fr>
- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Axioms reported by coqchk
- Date: Fri, 19 Aug 2016 15:29:33 +0200
On 19/08/2016 15:12, Robbert Krebbers wrote:
> However, just importing Coq.Program.Syntax is enough.
This is kind of baffling: for some reason, requiring Program.Syntax
transitively causes Program.Tactics to be required.
> Why is one
> required to import anything of Program from the standard library to use
> the Program vernacular?
That is because the Program command inserts symbols from Program.Tactics
in the term under construction.
Best regards,
Guillaume
- Re: [Coq-Club] Axioms reported by coqchk, (continued)
- Re: [Coq-Club] Axioms reported by coqchk, Ralf Jung, 08/19/2016
- Re: [Coq-Club] Axioms reported by coqchk, Jacques-Henri Jourdan, 08/19/2016
- Re: [Coq-Club] Axioms reported by coqchk, Guillaume Melquiond, 08/19/2016
- Re: [Coq-Club] Axioms reported by coqchk, Matthieu Sozeau, 08/19/2016
- Re: [Coq-Club] Axioms reported by coqchk, Pierre-Marie Pédrot, 08/19/2016
- RE: [Coq-Club] Axioms reported by coqchk, Soegtrop, Michael, 08/19/2016
- Re: [Coq-Club] Axioms reported by coqchk, Robbert Krebbers, 08/19/2016
- Re: [Coq-Club] coqchk safe from plugins? (Was: Axioms reported by coqchk), Ralf Jung, 08/19/2016
- Re: [Coq-Club] coqchk safe from plugins? (Was: Axioms reported by coqchk), Robbert Krebbers, 08/19/2016
- Re: [Coq-Club] coqchk safe from plugins? (Was: Axioms reported by coqchk), Jonathan Leivent, 08/19/2016
- Re: [Coq-Club] coqchk safe from plugins? (Was: Axioms reported by coqchk), Guillaume Melquiond, 08/19/2016
