coq-club - Re: [Coq-Club] Axioms reported by coqchk
  • To: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] Axioms reported by coqchk
  • Date: Fri, 19 Aug 2016 12:37:13 -0400
  • Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=jonikelee AT gmail.com; spf=Pass smtp.mailfrom=jonikelee AT gmail.com; spf=None smtp.helo=postmaster AT mail-qt0-f173.google.com
  • Ironport-phdr: 9a23:Tqku/x8lfJJ61P9uRHKM819IXTAuvvDOBiVQ1KB91uMcTK2v8tzYMVDF4r011RmSDNydsawP0rKP++C4ACpbsM7H6ChDOLV3FDY9wf0MmAIhBMPXQWbaF9XNKxIAIcJZSVV+9Gu6O0UGUOz3ZlnVv2HgpWVKQka3CwN5K6zPF5LIiIzvjqbpqsSVOVsD3WLkKfMqdVPt/F2X7pFXyaJZaY8JgiPTpXVJf+kEjUhJHnm02yjG28Gr4ZR4+D5Rsf9yv+RJUKH9YrhqBecAVGduYCgJ45jgsgCGRg+S7FMdVH8Xm1xGGVvr9hb/C7X2tCLmtuN7kA2XPNP7S6x8DTal6aZoRRvlhQ8IMjc49Cfcjckm3/ETmw6ouxEqm92cW4qSLvcrJq4=
Certainly, we would like to have some convenient method to determine that no unexpected axiom usage takes place in some part of a development.
Right now, we have Print Assumptions and coqchk. However, neither quite does the desired job. There are several reasons for this.
For Print Assumptions - this is currently just a per-definition check, hence it is difficult to use for a large development containing many definitions. Furthermore, because it is run from the script itself, it is susceptible to "plugin misbehavior" - the ability of a plugin to alter the functionality of just about anything in a script, possibly causing Print Assumptions to misreport.
For coqchk the issue is that it checks module "inclusion", not actual definition usage. Hence it will report that axioms are "present' when Print Assumptions (even without plugin misbehavior) does not. But, it doesn't load plugins, hence is safe from "plugin misbehavior".
Some have suggested that coqchk, while remaining a module inclusion checker, could be used for the desired check provided that modules are careful about their inclusions. The maximal care would be to completely segregate axiom-providing and axiom-consuming modules from others. There are two problems with this that I see. One is that there are existing modules in the standard library and plugins that currently violate this rule. The other is that the rule itself may force module developers to contort their modularity in difficult ways just to accommodate this practice and create modularity problems in other areas.
I would rather not base axiom checking merely on inclusions, even if the standard library and plugins could be "cleaned up" in this regard. I think the behavior of Print Assumptions is closer to what people actually want - but it needs to be made both wider in scope (something like allowing Print Assumptions on an entire module, which would check all definitions created in that module), and rendered somehow safe from "plugin misbehavior". Do people agree with this? If so, should this become part of coqchk, or be a separate tool?
-- Jonathan
