coq-club - Re: [Coq-Club] Why do we have "Prop < Set" ? Why not just "Prop ≤ Set" ?
  • From: Matej Kosik <5764c029b688c1c0d24a2e97cd764f AT gmail.com>
  • To: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] Why do we have "Prop < Set" ? Why not just "Prop ≤ Set" ?
  • Date: Sat, 21 Jan 2017 17:31:52 +0100
  • Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=5764c029b688c1c0d24a2e97cd764f AT gmail.com; spf=Pass smtp.mailfrom=5764c029b688c1c0d24a2e97cd764f AT gmail.com; spf=None smtp.helo=postmaster AT mail-wm0-f53.google.com
  • Ironport-phdr: 9a23:YLuiSBbWNubtuQmzXAnDkDv/LSx+4OfEezUN459isYplN5qZpsW6bnLW6fgltlLVR4KTs6sC0LuK9fy9EjxdqdbZ6TZZL8wKD0dEwewt3CUeQ+e9QXXhK/DrayFoVO9jb3RCu0+BDE5OBczlbEfTqHDhpRQbGxH4KBYnbr+tQt2a3IyL0LW5/ISWaAFVjhK8Z6lzJVO4t1b/rM4T1K5rNqszgjjOuXpLM7ALmj00LgrJzhyitpe7pZU7/34MsqgsppFLXfqkI6oQQrlRDTBgOGcwsp64/SLfRBeCsyNPGl4dlQBFVlDI
Hi Hugo,
For me, the most surprising parts of you reply are:
On 01/19/2017 11:58 PM, Hugo Herbelin wrote:
> The "Prop < Set" is technical: the universe-acyclicity algorithm
> internally needs to consider Prop <> Set to ensure that Prop is not
> accidentally equated to Set (*). Matthieu, who introduced this for the
> polymorphism of universes, confirmed.
> (*) In particular, changing the line "enforce_univ_lt Level.prop
> Level.set empty" into "enforce_univ_le Level.prop Level.set empty"
> would be incorrect, unless other means are used to ensure that the
> algorithm does not eventually incorrectly conclude that Prop = Set is
> part of the logic.
I wouldn't be surprised if Coq concluded that:
X ≤ Z (* all inhabitants of X are also inhabitants of Z *)
from the following two universe constraints:
X ≤ Y (* all inhabitants of X are also inhabitants of Y *)
Y ≤ Z (* all inhabitants of Y are also inhabitants of Z *)
Similarly, no surprise when it concludes:
X = Y (* X and Y have the same inhabitants *)
from these constraints:
Y ≤ X (* all inhabitants of Y are also inhabitants of X *)
However, when you claim that Coq can conclude
Prop = Set (* Prop and Set have the same inhabitants *)
from, and solely from:
Prop ≤ Set (* all inhabitants of Prop are also inhabitants of Set *)
isn't that counterintuitive for the user?
Did I understand you correctly when you said that this could really happen
(if we imagine that "Prop < Set" was relaxed to "Prop ≤ Set") ?
Would Coq do this only in case of Prop and Set or in general for any two
universes?
