- From: Matej Kosik <5764c029b688c1c0d24a2e97cd764f AT gmail.com>
- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Why do we have "Prop < Set" ? Why not just "Prop ≤ Set" ?
- Date: Thu, 19 Jan 2017 23:51:22 +0100
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=5764c029b688c1c0d24a2e97cd764f AT gmail.com; spf=Pass smtp.mailfrom=5764c029b688c1c0d24a2e97cd764f AT gmail.com; spf=None smtp.helo=postmaster AT mail-wm0-f65.google.com
- Ironport-phdr: 9a23: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
On 01/19/2017 06:02 PM, Théo Zimmermann wrote:
> Very good point Pierre. And now that you mention this, Matthieu was
> precisely recently talking about the need for anonymous records (which
> would probably be made available by creating a syntax for
> anonymous inductive types, since Coq's record are implemented in terms of
> inductive types).
Then you do not need "module sublanguage". You can similate it via structural
records and statical scoping.
(functors would become functions)
This is what Benjamin Pierce & David Turner did in Pict.
> Le jeu. 19 janv. 2017 à 17:57, Pierre Courtieu
> <pierre.courtieu AT gmail.com
> <mailto:pierre.courtieu AT gmail.com>>
> a écrit :
> Hi,
> Something that may confuse Matej is also that the only way of defining
> an inductive in Coq is to declare it via a definition. Which Matej
> associates to "changing the type Set by adding new inhabitants in it"
> but this is a wrong interpretation. All inductive types exists from
> the beginning, it is just that the implementation of Coq does not have
> a anonymous syntax for them (and maybe other deeper problem I am not
> aware of).
> You can define anonymous functions like this: (fun x:Prop => Prop).
> And everyone will probably admit that this function existed even
> before we write it (although we may reach philosophical problems with
> this formulation).
> But you cannot declare an anonymous inductive in such a way in coq
> (say for instance with a binder syntax like this: (Ind nat:Set =>
> O:nat | S: nat -> nat). So one could conclude that nat "does not exist
> until it is declared".
> But actually the underlying theory do have this kind of anonymous
> inductive (see constr.ml <http://constr.ml> as suggested by Maxime). So
> all typable
> inductives types always existed as every typable other terms.
> Hope this helps,
> Pierre
> 2017-01-19 17:31 GMT+01:00 Jonathan Leivent
> <jonikelee AT gmail.com
> <mailto:jonikelee AT gmail.com>>:
> > On 01/19/2017 11:20 AM, Matej Kosik wrote:
> >> Coq < Check (forall x : Set, x) : Set.
> >> Toplevel input, characters 0-32:
> >> Error:
> >> The term "forall x : Set, x" has type "Type@{Set+1}"
> >> while it is expected to have type "Set".
> >> So this is not the counter-example that would show that, when I start
> >> "coqtop -noinit" it would be the case that:
> >> Set not only has all the inhabitants of Prop, but it also has
> some such
> >> inhabitants, which are not in Prop.
> >> (in which case we could relax "Prop < Set" to "Prop ≤ Set").
> >> Are there such counter-examples?
> > I think you are missing some implications of what Bruno Barras said
> here:
> >> The reason why Prop:Set does not hold (although it is consistent in
> the
> >> default settings of Coq: think of Set as Type(0) and Type(i) as
> Type(i+1))
> >> is that Coq allows to make Set impredicative, and we expect this to
> be an
> >> extension of Coq without the option set (all theorems of Coq without
> the
> >> option are theorems of Coq with it).
> >> With this option set and Prop:Set, Coq would then contain system U
> which
> >> is inconsistent.
> > (this, by the way, would be a great addition to the FAQ).
> > Note that when -impredicative-set is used, then
> > succeeds. I think that plus the design constraint on Coq Bruno
> mentioned
> > above - all theorems without -impredicative-set are theorems with
> > -impredicative-set - might imply that Prop can't bet <= Set even
> without
> > -impredicative-set.
> > -- Jonathan
Matej Košík
- Re: [Coq-Club] Why do we have "Prop < Set" ? Why not just "Prop ≤ Set" ?, (continued)
- Re: [Coq-Club] Why do we have "Prop < Set" ? Why not just "Prop ≤ Set" ?, Bruno Barras, 01/19/2017
- Re: [Coq-Club] Why do we have "Prop < Set" ? Why not just "Prop ≤ Set" ?, Matej Kosik, 01/19/2017
- Re: [Coq-Club] Why do we have "Prop < Set" ? Why not just "Prop ≤ Set" ?, Emilio Jesús Gallego Arias, 01/19/2017
- Re: [Coq-Club] Why do we have "Prop < Set" ? Why not just "Prop ≤ Set" ?, Jonathan Leivent, 01/19/2017
- Re: [Coq-Club] Why do we have "Prop < Set" ? Why not just "Prop ≤ Set" ?, Pierre Courtieu, 01/19/2017
- Re: [Coq-Club] Why do we have "Prop < Set" ? Why not just "Prop ≤ Set" ?, Théo Zimmermann, 01/19/2017
- [Coq-Club] anonymous inductives (was Re: Why do we have "Prop < Set" ? Why not just "Prop ≤ Set" ?), Jonathan Leivent, 01/19/2017
- Re: [Coq-Club] Why do we have "Prop < Set" ? Why not just "Prop ≤ Set" ?, Dan Frumin, 01/20/2017
- Re: [Coq-Club] Why do we have "Prop < Set" ? Why not just "Prop ≤ Set" ?, Pierre Courtieu, 01/20/2017
- Re: [Coq-Club] Why do we have "Prop < Set" ? Why not just "Prop ≤ Set" ?, Jason Gross, 01/20/2017
- Re: [Coq-Club] Why do we have "Prop < Set" ? Why not just "Prop ≤ Set" ?, Matej Kosik, 01/21/2017
- Re: [Coq-Club] Why do we have "Prop < Set" ? Why not just "Prop ≤ Set" ?, Jason Gross, 01/21/2017
