- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Why do we have "Prop < Set" ? Why not just "Prop ≤ Set" ?
- Date: Fri, 20 Jan 2017 14:23:20 +0100
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=dfrumin AT cs.ru.nl; spf=None smtp.mailfrom=dan AT ip-145-116-190-57.wlan-int.ru.nl; spf=None smtp.helo=postmaster AT ip-145-116-190-57.wlan-int.ru.nl
- Ironport-phdr: 9a23:lpqTuBZStL9dZi038p9oG5v/LSx+4OfEezUN459isYplN5qZpsq/bnLW6fgltlLVR4KTs6sC0LuK9fy7EjBeqdbZ6TZZL8wKD0dEwewt3CUeQ+e9QXXhK/DrayFoVO9jb3RCu0+BDE5OBczlbEfTqHDhpRQbGxH4KBYnbr+tQt2a3IyL0LW5/ISWaAFVjhK8Z6lzJVO4t1b/rM4T1KdrLO4f0AbMo30AL+hY335tJFS7lA26/Nr2+po1oHcYgO4o68MVCfayRK8/V7ENVDk=
On 01/19, Matej Kosik wrote:
On 01/19/2017 05:56 PM, Pierre Courtieu wrote:
Hi,
Something that may confuse Matej is also that the only way of defining
an inductive in Coq is to declare it via a definition. Which Matej
associates to "changing the type Set by adding new inhabitants in it"
but this is a wrong interpretation.
I was probably spoiled by Coq's implementation where are perceived the
commands such as:
Axiom ...
Definition ...
Theorem ...
Inductive ...
as atomic transactions that manipulate the global environment.
(adding things, most of the time or undoing of previous transactions)
Even though this viewpoint was strange at the beginning
(having E[Γ] monster instead of merely Γ)
I got used to it and over time I stopped noticing this strangeness.
In a way Coq is similar to Prolog or LISP which smash definitions into the
global space.
It would be extremely attactive to make it more Scheme-like
(dropping the need for the global environment and enriching just the local
context)
All inductive types exists from
the beginning,
This is what Théo has said and which totally baffeled me,
but I should probably have read Martin-Löf's work where this may be the case
I don't think it is the case in Martin-Loef's work, however there is a
Martin-Loef type theory with W-types, using which you can define all
the usual inductive types. And those exist "from the beginning". By
contrast in CiC the W-types are definable just like any other
inductive types.
it is just that the implementation of Coq does not have
a anonymous syntax for them (and maybe other deeper problem I am not
aware of).
You can define anonymous functions like this: (fun x:Prop => Prop).
And everyone will probably admit that this function existed even
before we write it (although we may reach philosophical problems with
this formulation).
I think this this makes sense.
But you cannot declare an anonymous inductive in such a way in coq
(say for instance with a binder syntax like this: (Ind nat:Set =>
O:nat | S: nat -> nat). So one could conclude that nat "does not exist
until it is declared".
This is my perception, which valid if we restrict ourselves to Coq but I see
that it would be invalid in case we made it more Scheme-like instead of
keeping it more LISP/Prolog-like.
(e.g. provide mechanisms you mentioned which would force us to consider all
valid inductive types to exist a priori. Now they exist a posteriori.)
I find this idea very attractive.
But actually the underlying theory do have this kind of anonymous
inductive (see constr.ml as suggested by Maxime).
I failed to find it.
You do not mean this:
https://github.com/coq/coq/blob/trunk/kernel/constr.ml#L96
or this:
https://github.com/coq/coq/blob/trunk/kernel/constr.ml#L97
Do you? Because these values just designate (they do not define) inductive
types / constructors.
The definition of inductive types is part of the global environment.
https://github.com/coq/coq/blob/trunk/kernel/pre_env.ml#L43
So all typable
inductives types always existed as every typable other terms.
I do not think this is the case in case of Coq, or is it?
Hope this helps,
Pierre
- Re: [Coq-Club] Why do we have "Prop < Set" ? Why not just "Prop ≤ Set" ?, (continued)
- Re: [Coq-Club] Why do we have "Prop < Set" ? Why not just "Prop ≤ Set" ?, Matej Kosik, 01/19/2017
- Re: [Coq-Club] Why do we have "Prop < Set" ? Why not just "Prop ≤ Set" ?, Emilio Jesús Gallego Arias, 01/19/2017
- Re: [Coq-Club] Why do we have "Prop < Set" ? Why not just "Prop ≤ Set" ?, Jonathan Leivent, 01/19/2017
- Re: [Coq-Club] Why do we have "Prop < Set" ? Why not just "Prop ≤ Set" ?, Pierre Courtieu, 01/19/2017
- Re: [Coq-Club] Why do we have "Prop < Set" ? Why not just "Prop ≤ Set" ?, Théo Zimmermann, 01/19/2017
- [Coq-Club] anonymous inductives (was Re: Why do we have "Prop < Set" ? Why not just "Prop ≤ Set" ?), Jonathan Leivent, 01/19/2017
- Re: [Coq-Club] Why do we have "Prop < Set" ? Why not just "Prop ≤ Set" ?, Dan Frumin, 01/20/2017
- Re: [Coq-Club] Why do we have "Prop < Set" ? Why not just "Prop ≤ Set" ?, Pierre Courtieu, 01/20/2017
- Re: [Coq-Club] Why do we have "Prop < Set" ? Why not just "Prop ≤ Set" ?, Jason Gross, 01/20/2017
- Re: [Coq-Club] Why do we have "Prop < Set" ? Why not just "Prop ≤ Set" ?, Matej Kosik, 01/21/2017
- Re: [Coq-Club] Why do we have "Prop < Set" ? Why not just "Prop ≤ Set" ?, Jason Gross, 01/21/2017
- Re: [Coq-Club] Why do we have "Prop < Set" ? Why not just "Prop ≤ Set" ?, Gaetan Gilbert, 01/21/2017
