- From: Matej Kosik <5764c029b688c1c0d24a2e97cd764f AT gmail.com>
- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Why do we have "Prop < Set" ? Why not just "Prop ≤ Set" ?
- Date: Sat, 21 Jan 2017 19:14:27 +0100
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=5764c029b688c1c0d24a2e97cd764f AT gmail.com; spf=Pass smtp.mailfrom=5764c029b688c1c0d24a2e97cd764f AT gmail.com; spf=None smtp.helo=postmaster AT mail-wm0-f66.google.com
- Ironport-phdr: 9a23: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
On 01/21/2017 06:03 PM, Jason Gross wrote:
> If you write
> (fun x : Set => (x : Prop))
> Coq will currently reject that. If you relax Prop < Set to Prop ≤ Set, Coq
> will add the global constraint that Set ≤ Prop and hence that Prop = Set,
> just as when you write
I wasn't able to reproduce what you say. In my branch where I relaxed Prop <
Set to Prop ≤ Set, this is what I see:
Welcome to Coq trunk (January 2017)
Coq < Print Universes.
Prop <= Set
Coq < Set Printing Universes.
Coq < Check fun x : Set => (x : Prop).
Toplevel input, characters 22-23:
Error:
In environment
x : Set
The term "x" has type "Set" while it is expected to have type
"Prop" (universe inconsistency: Cannot enforce Set = Prop).
which totally makes sense. The term:
is not well-typed because Set is not a subtype of Prop.
(this is not the case of neither in the official Coq branches, neither in my
experiment).
Relaxing Prop < Set to Prop ≤ Set does not imply Set suddenly becomes a
subtype of Prop.
> (fun x : Type@{i} => (x : Type@{j}))
> Coq adds the constraint that i ≤ j.
It may. I fail to see how it is a problem (wrt what I asked).
> It might also be the case that you'd get this constraint in more subtle
> situations, such as if you write
> Inductive inhabited (X : Set) : Prop := inhabits (_ : X).
> or if you write
> (forall X : Set, X) : Set
Prop <= Set
Coq < Inductive inhabited (X : Set) : Prop := inhabits (_ : X).
inhabited is defined
inhabited_ind is defined
Prop <= Set
> Does this answer your question?
Unfortunatelly, not. But think you (all) for the answers!
However, independently from your concrete arguments, which I wasn't able to
reproduce, there is more simple way to see that something is wrong after
these changes:
https://github.com/matej-kosik/coq/commit/2fcbb0ced3bc32210ae9fbf4acc40804841c9200
this:
Prop <= Set
Coq < Print Sorted Universes.
Prop = Set
shows that Coq, somehow really decides (why?) infers that "Prop = Set"
(regardless whether we add inhabitants to Set or not).
I wonder why Coq infers that.
This is consistent with what Hugo said.
Hm, I guess that the only way to find out is to look at the implementation ...
> On Sat, Jan 21, 2017, 11:27 AM Matej Kosik
> <mailto:5764c029b688c1c0d24a2e97cd764f AT gmail.com>>
> wrote:
> Hi Hugo,
> For me, the most surprising parts of you reply are:
> On 01/19/2017 11:58 PM, Hugo Herbelin wrote:
> > The "Prop < Set" is technical: the universe-acyclicity algorithm
> > internally needs to consider Prop <> Set to ensure that Prop is not
> > accidentally equated to Set (*). Matthieu, who introduced this for the
> > polymorphism of universes, confirmed.
> > (*) In particular, changing the line "enforce_univ_lt Level.prop
> > Level.set empty" into "enforce_univ_le Level.prop Level.set empty"
> > would be incorrect, unless other means are used to ensure that the
> > algorithm does not eventually incorrectly conclude that Prop = Set is
> > part of the logic.
> I wouldn't be surprised if Coq concluded that:
> X ≤ Z (* all inhabitants of X are also inhabitants of Z *)
> from the following two universe constraints:
> X ≤ Y (* all inhabitants of X are also inhabitants of Y *)
> Y ≤ Z (* all inhabitants of Y are also inhabitants of Z *)
> Similarly, no surprise when it concludes:
> X = Y (* X and Y have the same inhabitants *)
> from these constraints:
> Y ≤ X (* all inhabitants of Y are also inhabitants of X *)
> However, when you claim that Coq can conclude
> Prop = Set (* Prop and Set have the same inhabitants *)
> from, and solely from:
> Prop ≤ Set (* all inhabitants of Prop are also inhabitants of Set *)
> isn't that counterintuitive for the user?
> Did I understand you correctly when you said that this could really
> happen (if we imagine that "Prop < Set" was relaxed to "Prop ≤ Set") ?
> Would Coq do this only in case of Prop and Set or in general for any
> two universes?
Matej Košík
- [Coq-Club] anonymous inductives (was Re: Why do we have "Prop < Set" ? Why not just "Prop ≤ Set" ?), (continued)
- [Coq-Club] anonymous inductives (was Re: Why do we have "Prop < Set" ? Why not just "Prop ≤ Set" ?), Jonathan Leivent, 01/19/2017
- Re: [Coq-Club] Why do we have "Prop < Set" ? Why not just "Prop ≤ Set" ?, Matej Kosik, 01/19/2017
- Re: [Coq-Club] Why do we have "Prop < Set" ? Why not just "Prop ≤ Set" ?, Dan Frumin, 01/20/2017
- Re: [Coq-Club] Why do we have "Prop < Set" ? Why not just "Prop ≤ Set" ?, Pierre Courtieu, 01/20/2017
- Re: [Coq-Club] Why do we have "Prop < Set" ? Why not just "Prop ≤ Set" ?, Jason Gross, 01/20/2017
- Re: [Coq-Club] Why do we have "Prop < Set" ? Why not just "Prop ≤ Set" ?, Matej Kosik, 01/21/2017
- Re: [Coq-Club] Why do we have "Prop < Set" ? Why not just "Prop ≤ Set" ?, Jason Gross, 01/21/2017
- Re: [Coq-Club] Why do we have "Prop < Set" ? Why not just "Prop ≤ Set" ?, Gaetan Gilbert, 01/21/2017
- Re: [Coq-Club] Why do we have "Prop < Set" ? Why not just "Prop ≤ Set" ?, Matej Košík, 01/22/2017
- Re: [Coq-Club] Why do we have "Prop < Set" ? Why not just "Prop ≤ Set" ?, Théo Zimmermann, 01/23/2017
- Re: [Coq-Club] Why do we have "Prop < Set" ? Why not just "Prop ≤ Set" ?, Matthieu Sozeau, 01/23/2017
