- From: Dominique Larchey-Wendling <dominique.larchey-wendling AT loria.fr>
- To: coq-club <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] Is there a measure for these functions?
- Date: Mon, 3 Aug 2020 22:20:14 +0200 (CEST)
Hi,
To me the only non-structural case seems to be
the call on the match on the nth sub-term of our
snoc list sub-structure. Its size is smaller though.
It is actually a real sub-term but convincing Coq
that it is so could be very hard indeed.
In such a case, I do not see why a measure based
on the linear size would not work, in each Fixpoint on
the third argument. May be you struggle trying to
define mutual Fixpoints based on measures ?
Also if I may (and if possible), I would suggest that
you implement your type Ty so that snoc lists are
actual list as in eg
Inductive Ty : Set :=
| TUnit : Ty
| TBox : Ty -> Ty
| TUnbox : nat -> nat -> list Ty -> Ty
| TUnit : Ty
| TBox : Ty -> Ty
Definition Sub := list Ty.
Hence you could use the List library on
your type instead of having to recreate one. A snoc
notation could help if you want to see the list reversed.
You would switch mutual inductives with nested inductives
and would have to design a suitable recursor but once
done, you will find it easy to work with.
Best,
Dominique
De: "Junyoung Clare Jang" <jjc9310 AT gmail.com>
À: "coq-club" <coq-club AT inria.fr>
Envoyé: Lundi 3 Août 2020 21:22:22
Objet: [Coq-Club] Is there a measure for these functions?
Dear All,While I am trying to prove some properties of my language, the following functions come up.
Inductive Sub : Set :=
| NullS : Sub
| SnocS : Sub -> Ty -> Sub
with Ty : Set :=
| TUnit : Ty
| TBox : Ty -> Ty
| TUnbox : nat -> nat -> Sub -> Ty
Fixpoint nth (s : Sub) (x : nat) : Ty :=
match s with
| NullS => TUnit
| SnocS s' t' =>
match x with
| O => t'
| S x' => nth s' x'
end
end
Fixpoint substSub (s : Sub) (n : nat) (s' : Sub) : Sub :=
match s' with
| NullS => NullS
| SnocS s'' t'' => SnocS (substSub s n s'') (substTy s n t'')
end
with substTy (s : Sub) (n : nat) (t' : Ty) : Ty :=
match t' with
| TUnit => TUnit
| TBox t'' => TBox (substTy s n t'')
| TUnbox x'' d'' s'' =>
if eq_dec d'' n
then
match nth s x'' with
| TBox t''' => substTy (substSub s n s'') d'' t'''
| t''' => TUnit
end
else
TUnbox x'' d'' (substSub s n s'')
end
.(I simplified the actual version a little)However, substSub and substTy are clearly not structurally recursive, so I tried several measures in order to define them, but none of those worked. I also attempted to find a looping example, and that was also unsuccessful. Do these functions terminate? I will appreciate any helps to show these functions are terminating or non-terminating...Thanks,Clare Jang
- [Coq-Club] Is there a measure for these functions?, Junyoung Clare Jang, 08/03/2020
- Re: [Coq-Club] Is there a measure for these functions?, Dominique Larchey-Wendling, 08/03/2020
- Re: [Coq-Club] Is there a measure for these functions?, Junyoung Clare Jang, 08/03/2020
- Re: [Coq-Club] Is there a measure for these functions?, jonikelee AT gmail.com, 08/03/2020
- <Possible follow-up(s)>
- Re: [Coq-Club] Is there a measure for these functions?, Dominique Larchey-Wendling, 08/11/2020
- Re: [Coq-Club] Is there a measure for these functions?, Dominique Larchey-Wendling, 08/12/2020
