- From: Dominique Larchey-Wendling <dominique.larchey-wendling AT loria.fr>
- To: coq-club <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] Is there a measure for these functions?
- Date: Tue, 11 Aug 2020 22:09:05 +0200 (CEST)
Dear Clare Jang,
As hinted in private before, you can use the Braga method to approach the study of your
complex *mutual and nested* recursive scheme. I did the exercise for you but having no
idea of what this algorithm computes, I cannot establish partial correctness results.
You would need to figure that out yourself.
However, below are all the tool you might need to prove those results in the form
of a proof-irrelevant Inductive-Recursive scheme, provided that you know what
property you want to establish for subst[Sub,Ty]. You can show partial correctness
results use the domain recursors DsS & DsT but you need to establish properties
simultaneously for subst[Sub,Ty] because of the mutual scheme.
Good luck,
Dominique
(* Copyright Dominique Larchey-Wendling [*] *)
(* [*] Affiliation LORIA -- CNRS *)
(* This file is distributed under the terms of the *)
(* CeCILL v2 FREE SOFTWARE LICENSE AGREEMENT *)
Require Import Arith.
An implementation of the following mutual and nested
recursive schemes using the Braga method
Fixpoint substSub (s : Sub) (n : nat) (s' : Sub) : Sub :=
match s' with
| NullS => NullS
| SnocS s'' t'' => SnocS (substSub s n s'') (substTy s n t'')
end
with substTy (s : Sub) (n : nat) (t' : Ty) : Ty :=
match t' with
| TUnit => TUnit
| TBox t'' => TBox (substTy s n t'')
| TUnbox x'' d'' s'' =>
if eq_nat_dec d'' n
then
match nth s x'' with
| TBox t''' => substTy (substSub s n s'') d'' t'''
| t''' => TUnit
end
else
TUnbox x'' d'' (substSub s n s'')
end
Section nested_and_mutual.
Inductive Sub : Set :=
| NullS : Sub
| SnocS : Sub -> Ty -> Sub
with Ty : Set :=
| TUnit : Ty
| TBox : Ty -> Ty
| TUnbox : nat -> nat -> Sub -> Ty
Fixpoint nth (s : Sub) (x : nat) : Ty :=
match s with
| NullS => TUnit
| SnocS s' t' =>
match x with
| O => t'
| S x' => nth s' x'
end
end.
(* The graphs of subst[Sub,Ty] linking the inputs and outputs *)
Inductive g_substSub : Sub -> nat -> Sub -> Sub -> Prop :=
| in_gsS_N s n : g_substSub s n NullS NullS
| in_gsS_S s n s' t' rs rt : g_substSub s n s' rs
-> g_substTy s n t' rt
-> g_substSub s n (SnocS s' t') (SnocS rs rt)
with g_substTy : Sub -> nat -> Ty -> Ty -> Prop :=
| in_gsT_u s n : g_substTy s n TUnit TUnit
| in_gsT_B s n t' rt : g_substTy s n t' rt -> g_substTy s n (TBox t') (TBox rt)
| in_gsT_U1 s n x d s' t' rs rt : d = n
-> nth s x = TBox t'
-> g_substSub s n s' rs
-> g_substTy rs d t' rt
-> g_substTy s n (TUnbox x d s') rt
| in_gsT_U2 s n x d s' : d = n
-> (~ exists t', nth s x = TBox t')
-> g_substTy s n (TUnbox x d s') TUnit
| in_gsT_U3 s n x d s' rs : d <> n
-> g_substTy s n (TUnbox x d s') (TUnbox x d rs)
(* The graphs are functional/deterministic *)
Fixpoint g_substSub_fun s n s' o1 (H1 : g_substSub s n s' o1) : forall o2, g_substSub s n s' o2 -> o1 = o2
with g_substTy_fun s n t' o1 (H1 : g_substTy s n t' o1) : forall o2, g_substTy s n t' o2 -> o1 = o2.
Proof.
+ destruct H1 as [s n | s n s' t' rs rt H1 H2 ].
* inversion 1; trivial.
* inversion 1; f_equal.
- apply g_substSub_fun with (1 := H1); assumption.
- apply g_substTy_fun with (1 := H2); assumption.
+ destruct H1 as [ s n | s n t' rt H1 | s n x d s' t' rs rt H1 H2 H3 H4 | s n x d s' H1 H2 | s n x d s' rs H1 H2 ].
apply g_substTy_fun with (1 := H1); assumption.
* inversion 1.
- generalize (g_substSub_fun _ _ _ _ H3 _ H12); intro; subst rs0.
rewrite H2 in H10; inversion H10; subst t'0.
apply (g_substTy_fun _ _ _ _ H4 _ H13).
- destruct H11; exists t'; trivial.
- destruct H10; trivial.
* inversion 1.
- destruct H2; exists t'; trivial.
- trivial.
- destruct H8; trivial.
* inversion 1.
- destruct H1; trivial.
- f_equal.
apply g_substSub_fun with (1 := H2); assumption.
Qed.
(* Characterization of the domains using the subcall/call relation *)
Let Call := ((Sub * nat * Sub) + (Sub * nat * Ty))%type.
Reserved Notation "x '<sc' y" (at level 70).
Inductive Ds_subcall : Call -> Call -> Prop :=
| in_sc_0 s n s' t' : inl (s,n,s') <sc inl (s,n,SnocS s' t')
| in_sc_1 s n s' t' : inr (s,n,t') <sc inl (s,n,SnocS s' t')
| in_sc_2 s n t' : inr (s,n,t') <sc inr (s,n,TBox t')
| in_sc_3 s n x d s' t' : d = n -> nth s x = TBox t' -> inl (s,n,s') <sc inr (s,n,TUnbox x d s')
| in_sc_4 s n x d s' t' rs : d = n -> nth s x = TBox t' -> g_substSub s n s' rs -> inr (rs,d,t') <sc inr (s,n,TUnbox x d s')
| in_sc_5 s n x d s' : d <> n -> inl (s,n,s') <sc inr (s,n,TUnbox x d s')
where "x '<sc' y" := (Ds_subcall x y).
Definition DsS s n s' := Acc Ds_subcall (inl (s,n,s')).
Definition DsT s n t' := Acc Ds_subcall (inr (s,n,t')).
(* The subst[Sub,Ty] packed with conformity certificate wrt the their graphs *)
Let Fixpoint substSub_pwc s n s' (D : DsS s n s') { struct D } : sig (g_substSub s n s')
with substTy_pwc s n t' (D : DsT s n t') { struct D } : sig (g_substTy s n t').
Proof.
+ revert D; refine (match s' with
| NullS => fun _ => exist _ NullS _
| SnocS s' t' => fun D => let (s1,S1) := substSub_pwc s n s' _ in
let (t1,T1) := substTy_pwc s n t' _
in exist _ (SnocS s1 t1) _
end).
* constructor.
* apply Acc_inv with (1 := D); constructor.
* constructor; assumption.
+ revert D; refine (match t' with
| TUnit => fun _ => exist _ TUnit _
| TBox t' => fun D => let (t1,T1) := substTy_pwc s n t' _
in exist _ (TBox t1) _
| TUnbox x d s' => fun D =>
match eq_nat_dec d n with
| left H => match nth s x as u return nth s x = u -> _ with
| TBox t' => fun E => let (s1,S1) := substSub_pwc s n s' _ in
let (t1,T1) := substTy_pwc s1 d t' _
in exist _ t1 _
| _ => fun _ => exist _ TUnit _
end eq_refl
| right H => let (s1,S1) := substSub_pwc s n s' _
in exist _ (TUnbox x d s1) _
end
end).
* constructor.
* constructor; trivial.
intros (t1 & E); now rewrite E in *.
* apply Acc_inv with (1 := D); constructor 4 with t'; trivial.
* apply Acc_inv with (1 := D); constructor 5; trivial.
* constructor 3 with t' s1; trivial.
* constructor 4; trivial.
* apply Acc_inv with (1 := D); constructor; trivial.
Qed.
(* Now the partial functions, by projection *)
Definition substSub s n s' D := proj1_sig (substSub_pwc s n s' D).
Definition substTy s n t' D := proj1_sig (substTy_pwc s n t' D).
(* And their specs, conformity with their graphs *)
Fact substSub_spec s n s' D : g_substSub s n s' (substSub s n s' D).
Proof. apply (proj2_sig _). Qed.
Fact substTy_spec s n t' D : g_substTy s n t' (substTy s n t' D).
(** Proof irrelevance *)
Fact substSub_pirr s n s' D1 D2 : substSub s n s' D1 = substSub s n s' D2.
Proof. apply g_substSub_fun with s n s'; apply substSub_spec. Qed.
Fact substTy_pirr s n t' D1 D2 : substTy s n t' D1 = substTy s n t' D2.
Proof. apply g_substTy_fun with s n t'; apply substTy_spec. Qed.
(** Domain constructors Induction-Recursion style *)
Fact DsS_0 s n : DsS s n NullS.
Proof. constructor; inversion 1. Qed.
Fact DsS_1 s n s' t' : DsS s n s' -> DsT s n t' -> DsS s n (SnocS s' t').
Proof. intros H1 H2; constructor; inversion 1; auto. Qed.
Fact DsT_0 s n : DsT s n TUnit.
Fact DsT_1 s n t' : DsT s n t' -> DsT s n (TBox t').
Proof. intros H; constructor; inversion 1; auto. Qed.
Fact DsT_2 s n x d s' t' : d = n -> nth s x = TBox t' -> forall D : DsS s n s', DsT (substSub s n s' D) d t' -> DsT s n (TUnbox x d s').
Proof.
intros H1 H2 D HD.
constructor; inversion 1; subst.
+ apply D.
+ rewrite (g_substSub_fun _ _ _ _ H10 _ (substSub_spec _ _ _ D)).
rewrite H2 in H9; inversion H9; subst; trivial.
+ destruct H4; trivial.
Qed.
Fact DsT_3 s n x d s' : d = n -> (~ exists t', nth s x = TBox t') -> DsT s n (TUnbox x d s').
Proof.
intros H1 H2.
+ destruct H2; exists t'; trivial.
Qed.
Fact DsT_4 s n x d s' : d <> n -> DsS s n s' -> DsT s n (TUnbox x d s').
Proof.
intros H1 H2.
constructor; inversion 1; subst; now auto.
Qed.
(** Fixpoint equations *)
Hint Resolve substSub_spec substTy_spec : core.
Hint Constructors g_substSub g_substTy : core.
Fact substSub_fix_0 s n : substSub s n NullS (DsS_0 s n) = NullS.
Proof. apply g_substSub_fun with s n NullS; auto. Qed.
Fact substSub_fix_1 s n s' t' D1 D2 :
substSub s n (SnocS s' t') (DsS_1 s n s' t' D1 D2)
= SnocS (substSub s n s' D1) (substTy s n t' D2).
Proof. apply g_substSub_fun with s n (SnocS s' t'); auto. Qed.
Fact substTy_fix_0 s n : substTy s n TUnit (DsT_0 s n) = TUnit.
Proof. apply g_substTy_fun with s n TUnit; auto. Qed.
Fact substTy_fix_1 s n t' D :
substTy s n (TBox t') (DsT_1 s n t' D)
= TBox (substTy s n t' D).
Proof. apply g_substTy_fun with s n (TBox t'); auto. Qed.
Fact substTy_fix_2 s n x d s' t' E H D1 D2 :
substTy s n (TUnbox x d s') (DsT_2 s n x d s' t' E H D1 D2)
= substTy (substSub s n s' D1) d t' D2.
Proof.
apply g_substTy_fun with s n (TUnbox x d s'); auto.
constructor 3 with t' (substSub s n s' D1); auto.
Qed.
Fact substTy_fix_3 s n x d s' E H :
substTy s n (TUnbox x d s') (DsT_3 s n x d s' E H)
= TUnit.
Proof. apply g_substTy_fun with s n (TUnbox x d s'); auto. Qed.
Fact substTy_fix_4 s n x d s' E D :
substTy s n (TUnbox x d s') (DsT_4 s n x d s' E D)
= TUnbox x d (substSub s n s' D).
Section mutual_recursors.
Variable (P : forall s n s', DsS s n s' -> Type) (Q : forall s n t', DsT s n t' -> Type)
(HPi : forall s n s' D1 D2, P s n s' D1 -> P s n s' D2)
(HP0 : forall s n, P _ _ _ (DsS_0 s n))
(HP1 : forall s n s' t' D1 (_ : P _ _ _ D1) D2 (_ : Q _ _ _ D2), P _ _ _ (DsS_1 s n s' t' D1 D2))
(HQi : forall s n t' D1 D2, Q s n t' D1 -> Q s n t' D2)
(HQ0 : forall s n, Q _ _ _ (DsT_0 s n))
(HQ1 : forall s n t' D (_ : Q _ _ _ D), Q _ _ _ (DsT_1 s n t' D))
(HQ2 : forall s n x d s' t' E H D1 (_ : P _ _ _ D1) D2 (_ : Q _ _ _ D2), Q _ _ _ (DsT_2 s n x d s' t' E H D1 D2))
(HQ3 : forall s n x d s' E H, Q _ _ _ (DsT_3 s n x d s' E H))
(HQ4 : forall s n x d s' E D (_ : P _ _ _ D), Q _ _ _ (DsT_4 s n x d s' E D)).
Fixpoint DsS_rect s n s' D : P s n s' D
with DsT_rect s n t' D : Q s n t' D.
Proof.
+ destruct s' as [ | s' t' ].
* refine (HPi _ _ _ _ _ (HP0 _ _)).
* refine (HPi _ _ _ _ _ (HP1 _ _ _ _ _ (DsS_rect s n s' _) _ (DsT_rect s n t' _)));
+ destruct t' as [ | t' | x d s' ].
* refine (HQi _ _ _ _ _ (HQ0 _ _)).
* refine (HQi _ _ _ _ _ (HQ1 _ _ _ _ (DsT_rect s n t' _)));
* destruct (eq_nat_dec d n) as [ E | E ]; [ case_eq (nth s x) | ].
- intros H.
refine (HQi _ _ _ _ _ (HQ3 _ _ _ _ _ _ _)); auto.
intros (? & H1); now rewrite H1 in H.
- intros t' H.
assert (D1 : DsS s n s').
{ apply Acc_inv with (1 := D); constructor 4 with t'; auto. }
refine (HQi _ _ _ _ _ (HQ2 _ _ _ _ _ _ E H _ (DsS_rect s n s' D1) _ (DsT_rect _ _ _ _))); auto.
apply Acc_inv with (1 := D); constructor; auto.
- intros x' d' s'' H'.
intros (? & H1); now rewrite H1 in H'.
- refine (HQi _ _ _ _ _ (HQ4 _ _ _ _ _ _ _ (DsS_rect _ _ _ _))); auto.
Qed.
End mutual_recursors.
(** Notice that until now, we build the inductive-recursive scheme
w/o using knowledge about what subst[Sub,Ty] actually compute.
You can use DsS_rect & DsT_rect to characterise what subst[Sub,Ty]
compute on there respective domains, ie *partial correctness results*.
Then you can try to show
(a) forall s n s', DsS s n s' and (b) forall s n t', DsT s n t'
But you might need partial correctness results because of the nesting
of recursive calls
End nested_and_mutual.
match s' with
| NullS => NullS
end
match t' with
| TUnit => TUnit
if eq_nat_dec d'' n
then
| t''' => TUnit
end
else
end
| NullS : Sub
with Ty : Set :=
| TUnit : Ty
| TBox : Ty -> Ty
match s with
| NullS => TUnit
| SnocS s' t' =>
match x with
| O => t'
| S x' => nth s' x'
end
end.
Proof.
* inversion 1.
* inversion 1.
- trivial.
* inversion 1.
- f_equal.
Qed.
Proof.
end).
* constructor.
in exist _ t1 _
end eq_refl
end
end).
* constructor.
Qed.
Proof.
intros H1 H2 D HD.
+ apply D.
Qed.
Proof.
intros H1 H2.
Qed.
Proof.
intros H1 H2.
Qed.
Proof.
Qed.
= TUnit.
Proof.
- intros H.
- intros t' H.
Qed.
of recursive calls
- [Coq-Club] Is there a measure for these functions?, Junyoung Clare Jang, 08/03/2020
- Re: [Coq-Club] Is there a measure for these functions?, Dominique Larchey-Wendling, 08/03/2020
- Re: [Coq-Club] Is there a measure for these functions?, Junyoung Clare Jang, 08/03/2020
- Re: [Coq-Club] Is there a measure for these functions?, jonikelee AT gmail.com, 08/03/2020
- <Possible follow-up(s)>
- Re: [Coq-Club] Is there a measure for these functions?, Dominique Larchey-Wendling, 08/11/2020
- Re: [Coq-Club] Is there a measure for these functions?, Dominique Larchey-Wendling, 08/12/2020
