- From: "jonikelee AT gmail.com" <jonikelee AT gmail.com>
- To: Junyoung Clare Jang <jjc9310 AT gmail.com>
- Cc: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Is there a measure for these functions?
- Date: Mon, 3 Aug 2020 16:32:05 -0400
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=jonikelee AT gmail.com; spf=Pass smtp.mailfrom=jonikelee AT gmail.com; spf=None smtp.helo=postmaster AT mail-qv1-f45.google.com
- Ironport-phdr: 9a23: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
It looks to me like substSub is structurally recursive on s', and
substTy is recursive and terminating because t''' is an indirect
subcomponent of t'. I think you might be able to convince Coq that
these all terminate by defining them in continuation-passing style
instead of by mutual recursion. I think Coq's mutual recursion "with"
clause is very limited in that all functions involved have to recurse in
a structurally similar way.
If you separate out the "match nth..." component from substTy and turn
that also into continuation-passing style, then I think all of
these functions can be defined to be structurally recursive.
Also, it looks like that "match nth..." part needs a TUnit case.
On Mon, 3 Aug 2020 15:22:22 -0400
Junyoung Clare Jang <jjc9310 AT gmail.com> wrote:
> Dear All,
> While I am trying to prove some properties of my language, the
> following functions come up.
> Inductive Sub : Set :=
> | NullS : Sub
> | SnocS : Sub -> Ty -> Sub
> with Ty : Set :=
> | TUnit : Ty
> | TBox : Ty -> Ty
> | TUnbox : nat -> nat -> Sub -> Ty
> Fixpoint nth (s : Sub) (x : nat) : Ty :=
> match s with
> | NullS => TUnit
> | SnocS s' t' =>
> match x with
> | O => t'
> | S x' => nth s' x'
> end
> end
> Fixpoint substSub (s : Sub) (n : nat) (s' : Sub) : Sub :=
> match s' with
> | NullS => NullS
> | SnocS s'' t'' => SnocS (substSub s n s'') (substTy s n t'')
> end
> with substTy (s : Sub) (n : nat) (t' : Ty) : Ty :=
> match t' with
> | TUnit => TUnit
> | TBox t'' => TBox (substTy s n t'')
> | TUnbox x'' d'' s'' =>
> if eq_dec d'' n
> then
> match nth s x'' with
> | TBox t''' => substTy (substSub s n s'') d'' t'''
> | t''' => TUnit
> end
> else
> TUnbox x'' d'' (substSub s n s'')
> end
> (I simplified the actual version a little)
> However, substSub and substTy are clearly not structurally recursive,
> so I tried several measures in order to define them, but none of
> those worked. I also attempted to find a looping example, and that
> was also unsuccessful. Do these functions terminate? I will
> appreciate any helps to show these functions are terminating or
> non-terminating...
> Thanks,
> Clare Jang
- [Coq-Club] Is there a measure for these functions?, Junyoung Clare Jang, 08/03/2020
- Re: [Coq-Club] Is there a measure for these functions?, Dominique Larchey-Wendling, 08/03/2020
- Re: [Coq-Club] Is there a measure for these functions?, Junyoung Clare Jang, 08/03/2020
- Re: [Coq-Club] Is there a measure for these functions?, jonikelee AT gmail.com, 08/03/2020
- <Possible follow-up(s)>
- Re: [Coq-Club] Is there a measure for these functions?, Dominique Larchey-Wendling, 08/11/2020
- Re: [Coq-Club] Is there a measure for these functions?, Dominique Larchey-Wendling, 08/12/2020
