- To: dominique.larchey-wendling AT loria.fr
- Cc: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Is there a measure for these functions?
- Date: Mon, 3 Aug 2020 17:56:26 -0400
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=jjc9310 AT gmail.com; spf=Pass smtp.mailfrom=jjc9310 AT gmail.com; spf=None smtp.helo=postmaster AT mail-yb1-f172.google.com
- Ironport-phdr: 9a23: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
Sorry, I mean "at least", not "at list" in " Maybe it's better to have used a list at list for this simplified version.".
Best,
Clare Jang
2020년 8월 3일 (월) 오후 5:48, Junyoung Clare Jang <jjc9310 AT gmail.com>님이 작성:
Hi,Thank you for the answer. However, I think the problem is more subtle. In the recursive callsubstTy (substSub s n s'') d'' t'''t''' comes from the first argument, so it's not necessarily smaller than t' (the third argument).I cannot do anything just with first or third argument as this recursive call uses substSub s n s'' as the first argument where s'' is a subterm of the third, and t''' as the third that is a subterm of the first.I tried to combine those two, but the first argument is not just s'' but substSub s n s'', so I need some facts that involves substSub.Even if I can use something like that in my measure, all such sizes I have tried give me less than or equal to, not just less than...And thank you for the suggestion. Unfortunately, my actual case is more complex, so I cannot use just a list for a sub(stitution). Maybe it's better to have used a list at list for this simplified version.Best,Clare Jang2020년 8월 3일 (월) 오후 4:20, Dominique Larchey-Wendling <dominique.larchey-wendling AT loria.fr>님이 작성:Hi,To me the only non-structural case seems to bethe call on the match on the nth sub-term of oursnoc list sub-structure. Its size is smaller though.It is actually a real sub-term but convincing Coqthat it is so could be very hard indeed.In such a case, I do not see why a measure basedon the linear size would not work, in each Fixpoint onthe third argument. May be you struggle trying todefine mutual Fixpoints based on measures ?Also if I may (and if possible), I would suggest thatyou implement your type Ty so that snoc lists areactual list as in egInductive Ty : Set :=
| TUnit : Ty
| TBox : Ty -> Ty
| TUnbox : nat -> nat -> list Ty -> TyDefinition Sub := list Ty.Hence you could use the List library onyour type instead of having to recreate one. A snocnotation could help if you want to see the list reversed.You would switch mutual inductives with nested inductivesand would have to design a suitable recursor but oncedone, you will find it easy to work with.Best,DominiqueDe: "Junyoung Clare Jang" <jjc9310 AT gmail.com>
À: "coq-club" <coq-club AT inria.fr>
Envoyé: Lundi 3 Août 2020 21:22:22
Objet: [Coq-Club] Is there a measure for these functions?Dear All,While I am trying to prove some properties of my language, the following functions come up.
Inductive Sub : Set :=
| NullS : Sub
| SnocS : Sub -> Ty -> Sub
with Ty : Set :=
| TUnit : Ty
| TBox : Ty -> Ty
| TUnbox : nat -> nat -> Sub -> Ty
Fixpoint nth (s : Sub) (x : nat) : Ty :=
match s with
| NullS => TUnit
| SnocS s' t' =>
match x with
| O => t'
| S x' => nth s' x'
end
end
Fixpoint substSub (s : Sub) (n : nat) (s' : Sub) : Sub :=
match s' with
| NullS => NullS
| SnocS s'' t'' => SnocS (substSub s n s'') (substTy s n t'')
end
with substTy (s : Sub) (n : nat) (t' : Ty) : Ty :=
match t' with
| TUnit => TUnit
| TBox t'' => TBox (substTy s n t'')
| TUnbox x'' d'' s'' =>
if eq_dec d'' n
then
match nth s x'' with
| TBox t''' => substTy (substSub s n s'') d'' t'''
| t''' => TUnit
end
else
TUnbox x'' d'' (substSub s n s'')
end
.(I simplified the actual version a little)However, substSub and substTy are clearly not structurally recursive, so I tried several measures in order to define them, but none of those worked. I also attempted to find a looping example, and that was also unsuccessful. Do these functions terminate? I will appreciate any helps to show these functions are terminating or non-terminating...Thanks,Clare Jang
--Best,Junyoung Clare Jang
Best,
Junyoung Clare Jang
- [Coq-Club] Is there a measure for these functions?, Junyoung Clare Jang, 08/03/2020
- Re: [Coq-Club] Is there a measure for these functions?, Dominique Larchey-Wendling, 08/03/2020
- Re: [Coq-Club] Is there a measure for these functions?, Junyoung Clare Jang, 08/03/2020
- Re: [Coq-Club] Is there a measure for these functions?, jonikelee AT gmail.com, 08/03/2020
- <Possible follow-up(s)>
- Re: [Coq-Club] Is there a measure for these functions?, Dominique Larchey-Wendling, 08/11/2020
- Re: [Coq-Club] Is there a measure for these functions?, Dominique Larchey-Wendling, 08/12/2020
