- To: "jonikelee AT gmail.com" <jonikelee AT gmail.com>
- Cc: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Is there a measure for these functions?
- Date: Mon, 3 Aug 2020 17:52:47 -0400
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=jjc9310 AT gmail.com; spf=Pass smtp.mailfrom=jjc9310 AT gmail.com; spf=None smtp.helo=postmaster AT mail-yb1-f182.google.com
- Ironport-phdr: 9a23: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
Hi,
Thank you for having an interest on my question. Sadly, t''' is a subterm of s, not t', and therefore I cannot use a subterm relation (whether direct or indirect) as a measure...
Is CPS conversion still worth its own? If so, I can try something similar.
Thanks,
Clare Jang
It looks to me like substSub is structurally recursive on s', and
substTy is recursive and terminating because t''' is an indirect
subcomponent of t'. I think you might be able to convince Coq that
these all terminate by defining them in continuation-passing style
instead of by mutual recursion. I think Coq's mutual recursion "with"
clause is very limited in that all functions involved have to recurse in
a structurally similar way.
If you separate out the "match nth..." component from substTy and turn
that also into continuation-passing style, then I think all of
these functions can be defined to be structurally recursive.
Also, it looks like that "match nth..." part needs a TUnit case.
On Mon, 3 Aug 2020 15:22:22 -0400
Junyoung Clare Jang <jjc9310 AT gmail.com> wrote:
> Dear All,
> While I am trying to prove some properties of my language, the
> following functions come up.
> Inductive Sub : Set :=
> | NullS : Sub
> | SnocS : Sub -> Ty -> Sub
> with Ty : Set :=
> | TUnit : Ty
> | TBox : Ty -> Ty
> | TUnbox : nat -> nat -> Sub -> Ty
> Fixpoint nth (s : Sub) (x : nat) : Ty :=
> match s with
> | NullS => TUnit
> | SnocS s' t' =>
> match x with
> | O => t'
> | S x' => nth s' x'
> end
> end
> Fixpoint substSub (s : Sub) (n : nat) (s' : Sub) : Sub :=
> match s' with
> | NullS => NullS
> | SnocS s'' t'' => SnocS (substSub s n s'') (substTy s n t'')
> end
> with substTy (s : Sub) (n : nat) (t' : Ty) : Ty :=
> match t' with
> | TUnit => TUnit
> | TBox t'' => TBox (substTy s n t'')
> | TUnbox x'' d'' s'' =>
> if eq_dec d'' n
> then
> match nth s x'' with
> | TBox t''' => substTy (substSub s n s'') d'' t'''
> | t''' => TUnit
> end
> else
> TUnbox x'' d'' (substSub s n s'')
> end
> (I simplified the actual version a little)
> However, substSub and substTy are clearly not structurally recursive,
> so I tried several measures in order to define them, but none of
> those worked. I also attempted to find a looping example, and that
> was also unsuccessful. Do these functions terminate? I will
> appreciate any helps to show these functions are terminating or
> non-terminating...
> Thanks,
> Clare Jang
Best,
Junyoung Clare Jang
- [Coq-Club] Is there a measure for these functions?, Junyoung Clare Jang, 08/03/2020
- Re: [Coq-Club] Is there a measure for these functions?, Dominique Larchey-Wendling, 08/03/2020
- Re: [Coq-Club] Is there a measure for these functions?, Junyoung Clare Jang, 08/03/2020
- Re: [Coq-Club] Is there a measure for these functions?, jonikelee AT gmail.com, 08/03/2020
- <Possible follow-up(s)>
- Re: [Coq-Club] Is there a measure for these functions?, Dominique Larchey-Wendling, 08/11/2020
- Re: [Coq-Club] Is there a measure for these functions?, Dominique Larchey-Wendling, 08/12/2020
