coq-club - Re: [Coq-Club] Why is the Coq logo made to look like a penis?
  • From: Kevin Sullivan <sullivan.kevinj AT gmail.com>
  • To: coq-club AT inria.fr
  • Cc: Andrew Appel <appel AT princeton.edu>
  • Subject: Re: [Coq-Club] Why is the Coq logo made to look like a penis?
  • Date: Tue, 6 Apr 2021 15:58:50 -0400
  • Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=sullivan.kevinj AT gmail.com; spf=Pass smtp.mailfrom=sullivan.kevinj AT gmail.com; spf=None smtp.helo=postmaster AT mail-ej1-f53.google.com
  • Ironport-hdrordr: A9a23:uNdmFKw4gzZU6Odu2nyGKrPxeuskLtp033Aq2lEZdDV+eKWj5rmTtd4c0gL5jytUZWE4lbm7SdG9aF7/1bow24keOr++QBLr0VHDEKhO5ZbvqgeQfhHW2fVa0c5bAspDIf32SWN3lMPrpDS/euxQo+Wv1ICNqaPgw2x2TQdsApsA0y5cBhyAGkN7AClqbKBJcKa03cZMqzq+dXl/VK3SbUUtZOTNq8bGk5jre3c9ZyIP0hWEjj+j9dfBYn+l9yoZOgk/p4sKwCzql0jc6r+4u/+2jiXA33Lehq47pPLRjvVEAsKIhow5CBXJzjypaoNoRqGYsFkOzd2H2RIFlt/DphtlBcBv8jfqeH2vqxeF4Wbd+Qdr0HPpxV+GjXaLm6LEeA4=
  • Ironport-phdr: A9a23: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
Another data point: I for one am very uncomfortable every time I have to pronounce the name of the system in front of a class of undergraduate young men and women, or even graduate students. There can be no question that it makes many people uncomfortable enough to be harmful. We're now in a world in which we're working hard to improve diversity and the inclusion of historically under-represented groups in our field *because it makes our field stronger*. We *really, really, really* should find a way to avoid having to repeat what too many people hear as an offensive juvenile male sex joke as part of our professional activites.  It's past time to change the name. "Coke" never really caught on. If the muses speak to me, I'll add a suggestion or two to the Wiki page. I understand and can laugh at the humor with the best of them, but there's a place for that kind of humor, and really the classroom isn't it.
On Tue, Apr 6, 2021 at 3:30 PM Talia Ringer <tringer AT cs.washington.edu> wrote:
My favorite suggestions in the wiki are the ones that include Coq as a substring, so that you can keep referring to it as Coq in French, and just elaborate in English.
Also, I'm really happy to see so many suggestions and so much constructive feedback in the Wiki! I would expect this community to be constructive ;)
On Tue, Apr 6, 2021 at 11:45 AM Emilio Jesús Gallego Arias <e AT x80.org> wrote:
Andrew Appel <appel AT princeton.edu> writes:
> So I propose a solution for discussion: keep the name Coq and explain
> that the correct pronunciation in English of the tool name is "Coke"
> (and this pronunciation has nothing to do with the pronunciation of
> coq in French or cock in English). But for this solution to work, the
> whole (anglophone) community has to adopt it.
Indeed, at the very least the Coq team should officially recommend to
pronounce "Coq" as "coke" in English; this is a solution not exempt of
flaws, but it seems to me that it is the only-short term viable
workaround for now.
I will make the point on the next Coq dev meeting.
My impression is that the Coq team would be happy to consider a name
change would a good replacement come up, there is indeed great concern
w.r.t. the side-effects of the current name.
We don't get reminded often of it tho, I'd say mainly due to two reasons:
- IAANM, there is not native English speaker in the Coq team
- Research and work in France happens mostly in French, and it turns out
  that "Coq" is a superb name in French! It is easily associated to
  "national pride", which really helps (subconsciously) in national
  funding contexts for example.
Brainstorming a bit, a possibility to try to keep the best of both
worlds is to keep "The Coq Project" as the official name of the project,
however name the particular implementation distributed by the project in
a different way.
Kind regards,
E.
