coq-club - Re: [Coq-Club] Why is the Coq logo made to look like a penis?
  • To: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] Why is the Coq logo made to look like a penis?
  • Date: Thu, 8 Apr 2021 20:11:09 -0400
  • Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=comar AT umich.edu; spf=Pass smtp.mailfrom=comar AT umich.edu; spf=None smtp.helo=postmaster AT foolish-myrddin.relay-egress.a.mail.umich.edu
  • Ironport-hdrordr: A9a23:JmLH9K0B8q1UoHustbtKGwqjBC8kLtp033Aq2lEZdDV+dMuEm8ey2OkKzBOcskd0ZFgMkc2NUZPwJk/02oVy5eAqU4uKeCnDlC+WIJp57Y3kqgeQfhHW0uJGz69vf+xfBbTLfDtHpP336gW5DNosqePvmMvDuc7kw25pXUVWbchbjjtRMBqREUF9WWB9aaYRKZz03Kd6jgvlVnQTYv62AXQIRKz/vNXNjp3renc9aCIP2U2gjTal8rL8HhSCmj0ZVC5C0KpKywj4uj28wq2itv2hoyWstVPu0w==
  • Ironport-phdr: A9a23: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
How about Coqo (pronounced "coco")?
The trailing "o" reflects that there is no formal definition of what Coq (as a whole distinct from Gallina, Ltac, and the rest, which already have fine names) is, apart from its OCaml implementation.
Coco is a common French name, so French speakers will find it familiar I suppose. In English, it will probably be heard as "cocoa" as in "hot cocoa", a delicious winter beverage, or perhaps bring to mind Coco Chanel, the famous French fashion designer.
Still embeds "Coq" so it will probably be clear when someone reads a prior paper mentioning Coq that it is connected to what is now known as Coqo.
On Thu, Apr 8, 2021 at 7:16 PM Sam Kuper <sampablokuper AT posteo.net> wrote:
On Thu, Apr 08, 2021 at 01:52:35PM -0400, Hadas Zeilberger wrote:
> The probability of a word like "Go" leading to harassment is
> significantly lower than the word "Coq". Therefore, it is meaningless
> to use that example as a reason for why not to change the name
Sorry if I was unclear.  My core points were:
1.  In a world where programming environments sometimes have imperfect
though reasonable names[1], but people often exhibit imperfect *and*
unreasonable behaviour, then please let's address that behaviour.
I.e.  much as we teach people *not* to take a person's clothing (or
given name, or other irrelevant properties) as an indication of consent
for puerility or worse, we should teach people that Coq is a
professional matter, not an open invitation for misbehaviour.
Whether you work in a crop-top, or work in Coq, or both, you shouldn't
be harassed for doing so.
2.  Naming things is hard.  If the community succeeds in avoiding
innuendo internationally, while retaining some or all positive aspects
of the extant name (reference to symbol of academic community/country of
origin; reference to name of relevant person; reference to name of
relevant part of maths; easy to spell; easy to remember; reasonably easy
to pronounce; continuity with published research) then great.
It just might be more difficult than some contributors seem to expect.
Several of the suggested replacement names so far are also problematic.
3.  The Coq website should explain the name, logo, and suggested
pronunciation, to minimise misunderstanding or abuse.
Best wishes,
Sam
[1]: If Go does not seem imperfect to you, great, but also see e.g.
https://en.wiktionary.org/wiki/bash#Verb or
https://en.wiktionary.org/wiki/python#Noun or
https://en.wiktionary.org/wiki/pearl#Noun (cognate with Perl).
I expect there are others.  English slang is *extensive*:
https://www.salon.com/2014/10/05/tickle_gizzard_and_the_pleasure_pivot_a_history_of_sex_slang_and_the_coolest_ancient_dirty_words/
https://www.fastcompany.com/1673314/2600-historic-slang-terms-for-genitalia
https://www.dea.gov/sites/default/files/2018-07/DIR-020-17%20Drug%20Slang%20Code%20Words.pdf
A: When it messes up the order in which people normally read text.
Q: When is top-posting a bad thing?
()  ASCII ribbon campaign. Please avoid HTML emails & proprietary
/\  file formats. (Why? See e.g. https://v.gd/jrmGbS ). Thank you.
