- To: "coq-club AT inria.fr" <coq-club AT inria.fr>
- Subject: [Coq-Club] Formalization of the syntax of first-order logic: binders
- Date: Mon, 11 Oct 2021 08:41:22 +0000
- Accept-language: en-AU, en-US
- Arc-authentication-results: i=1; mx.microsoft.com 1; spf=pass smtp.mailfrom=anu.edu.au; dmarc=pass action=none header.from=anu.edu.au; dkim=pass header.d=anu.edu.au; arc=none
- Arc-message-signature: i=1; a=rsa-sha256; c=relaxed/relaxed; d=microsoft.com; s=arcselector9901; h=From:Date:Subject:Message-ID:Content-Type:MIME-Version:X-MS-Exchange-AntiSpam-MessageData-ChunkCount:X-MS-Exchange-AntiSpam-MessageData-0:X-MS-Exchange-AntiSpam-MessageData-1; bh=Cu10nI9HeKzx/9cLNNIE63Vjqf9DT7zp7lRlb75MRWY=; b=VldB2XmEDowwEu8prMO7l+L3VkGl93JwvFvW9QDEKx+3MyO6TjUp2kqE/TBafYpJGm1pHezsHqT4rGKEeW4nPsKAs06CsZOaypaBT0E2kWTwnlzz5Ox2Vu/UB6JtihX71+mx9kBnrSaDTky7bFCN0oJCXct7+J2hdKQ95JQ+oEAhlm5l5KDsJGndB/3wSA5dgFggWblDVRpJH9atTq53gGjD753qhzGxGI2UJ67rmWiWOOhugkpDP9g822YfxMYWuy2zLNGiBBR2y2G2ELsWbD/hhLLjhwp29ZyMGvG76xIJdvqJM4t5608cElc6jKN+6We4QONyxxqDgUSBBtzowA==
- Arc-seal: i=1; a=rsa-sha256; s=arcselector9901; d=microsoft.com; cv=none; b=DJVF1tpT3/FbdgXe5snVdrGD+h8Mew1+H8EZoN7tReoW53xRvo7g5nd2js71WsdfLJOO/xi5e6R1a01qI0d8Lwq6XzAJSsv5D2VjLgEd5FWY3ZH5oMzDsXqAoEqkMXTNHBMZMeCGomIWYKox3tAqUy8p7O/nAqb41GI1VER2LnQzlpVJyV+yiy+DfbQ98R4Q0RYxPBEMeYqpXR2b5hJvM/ybeNDVUm7LzIyCYDYKPyzmAKDZwys2AW5NsDzRnJDIFxCLd9HaSzPeHAt50jw/Zv8J2B16cA5vMF+Mb7VTfP6gZN/CFvwbHYb2aSe8C/Td5CCoRm4SC71rNT1Hz0CL6g==
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=Ian.Shillito AT anu.edu.au; spf=Pass smtp.mailfrom=Ian.Shillito AT anu.edu.au; spf=Pass smtp.helo=postmaster AT AUS01-ME3-obe.outbound.protection.outlook.com
- Ironport-hdrordr: A9a23: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
- Ironport-phdr: A9a23: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
- Suggested_attachment_session_id: 4eac8104-a0f6-00c7-ab83-8b924c7ad1b2
Hi all,
I am about to start the formalisation of a proof of completeness for an extension of first-order intuitionistic logic. As a consequence I need to find a way to formalise the quantifiers of the FO syntax, and thus formalise binders.
It seems that there are already some approaches in the literature using:
- de Bruijn indices (https://www.ps.uni-saarland.de/autosubst/ put in action in https://www.ps.uni-saarland.de/extras/fol-completeness/)
- locally nameless (https://github.com/plclub/lngen could be used here?)
Are there arguments for using the one over the other? Are there other approaches? Do you have any experience to share about the formalisation of FO syntax?
Thanks in advance for your comments and thoughts!
Best,
Ian
- [Coq-Club] Formalization of the syntax of first-order logic: binders, Ian Shillito, 10/11/2021
- Re: [Coq-Club] Formalization of the syntax of first-order logic: binders, Wilayat Khan, 10/11/2021
- Re: [Coq-Club] Formalization of the syntax of first-order logic: binders, Pierre Courtieu, 10/11/2021
- Re: [Coq-Club] Formalization of the syntax of first-order logic: binders, Carlos Olarte, 10/11/2021
- Re: [Coq-Club] Formalization of the syntax of first-order logic: binders, Ian Shillito, 10/12/2021
- RE: [Coq-Club] Formalization of the syntax of first-order logic: binders, Jason Hu, 10/12/2021
- RE: [Coq-Club] Formalization of the syntax of first-order logic: binders, Alan Schmitt, 10/12/2021
- Re: [Coq-Club] Formalization of the syntax of first-order logic: binders, Dominik Kirst, 10/12/2021
- Re: [Coq-Club] Formalization of the syntax of first-order logic: binders, Ian Shillito, 10/14/2021
