coq-club - Re: [Coq-Club] Formalization of the syntax of first-order logic: binders
  • To: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] Formalization of the syntax of first-order logic: binders
  • Date: Mon, 11 Oct 2021 13:53:43 +0500
  • Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=wilayatk AT gmail.com; spf=Pass smtp.mailfrom=wilayatk AT gmail.com; spf=None smtp.helo=postmaster AT mail-vk1-f182.google.com
  • Ironport-hdrordr: A9a23:C9GYGK7X7V/8k8aD8APXwMfXdLJyesId70hD6qkRc20yTiX8raqTdZsgpH3JYVoqOE3I+urwW5VoI0mskKKdiLN5VdzCYOCMghrNEGgN1/qE/9QiIUHDHyxmuJuIv5IQNDQ4NzZHsfo=
  • Ironport-phdr: A9a23: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
Hi Ian
In the past, I have used both in formalising Android type system.  In locally nameless representation, bound variables are represented with de Bruijn indices. You might be interested to have a look at our paper, in particular the Section II-D and Coq formalization.
Best,
Wilayat
On Mon, Oct 11, 2021 at 1:42 PM Ian Shillito <Ian.Shillito AT anu.edu.au> wrote:
Hi all,
I am about to start the formalisation of a proof of completeness for an extension of first-order intuitionistic logic. As a consequence I need to find a way to formalise the quantifiers of the FO syntax, and thus formalise binders.
It seems that there are already some approaches in the literature using:
Are there arguments for using the one over the other? Are there other approaches? Do you have any experience to share about the formalisation of FO syntax?
Thanks in advance for your comments and thoughts!
Best,
Ian
