- To: "coq-club AT inria.fr" <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] Formalization of the syntax of first-order logic: binders
- Date: Wed, 13 Oct 2021 22:26:27 +0000
- Accept-language: en-AU, en-US
- Arc-authentication-results: i=1; mx.microsoft.com 1; spf=pass smtp.mailfrom=anu.edu.au; dmarc=pass action=none header.from=anu.edu.au; dkim=pass header.d=anu.edu.au; arc=none
- Arc-message-signature: i=1; a=rsa-sha256; c=relaxed/relaxed; d=microsoft.com; s=arcselector9901; h=From:Date:Subject:Message-ID:Content-Type:MIME-Version:X-MS-Exchange-AntiSpam-MessageData-ChunkCount:X-MS-Exchange-AntiSpam-MessageData-0:X-MS-Exchange-AntiSpam-MessageData-1; bh=puVnmipzutlj4l7rBkTfhPnqzXeh0G3QuJOx0q9looQ=; b=oUwGGY8kXt00lvnxB1kecBYrUXvSKPXaVUSnAuA+/J0FXUERsT1h+wn+UrLwh+y/DBOlrXeQKH9WF6SpCzcO79jyRx6xiTAhup3U78IsE8lXE2rVKY7KPExHw3J25mGRI83dzX7UJaEi60f/azQ+eNo9T87jQe5VWD9mQD6k0qvIYkm0sFEMigK7zPrTd6iLfRpjxH6Q8VZpIM+AXUBtkSHxRD4t3WEsK0xDofoHfwGONi9jcevTo1woXTIf3PcwRdZmsvVHT5CvtcUgWxXP637rG151lmnGk08teVaPQY6ipp8GEcJs07vryS0eLWsv6qCYjBqqHpzsIFFL+Y01Dw==
- Arc-seal: i=1; a=rsa-sha256; s=arcselector9901; d=microsoft.com; cv=none; b=cMbFFm/TYf1ce6b1CbnybOcK6qTZwI7wy/5OGlWBJqW9i7PH/GF1dOHI7W54lE77M5zrhZTra8vXcWU5tJcgMhZole6WvZiY6dbxFhe6jQp899rq2qMxidugoqOF1y6l/Q9ONLlhqf/HJeoiQaPvj+QJceJUEWmJPRKJnOGmqMsVzAyi2EsXedwrh2pDxkTwTLwa9xhGn+yywHp4QtP8ZoS8spgjZWhY/X63DsmYJUrnv8dUcmYZi9NLr0l96QwF4UAXOQorixTQvo1qNaXqre4Ikxz0g2x/sOU08C9XNPeRMGzExiPWLKs/T3Sza5CaZ0cKhZDkO2QL0TR7AQViUQ==
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=Ian.Shillito AT anu.edu.au; spf=Pass smtp.mailfrom=Ian.Shillito AT anu.edu.au; spf=Pass smtp.helo=postmaster AT AUS01-ME3-obe.outbound.protection.outlook.com
- Ironport-hdrordr: A9a23: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
- Ironport-phdr: A9a23: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
- Suggested_attachment_session_id: e1f56faa-8f18-c29c-47dd-8fac10b4f792
Hi Jason, Alan and Dominik,
Jason: thank you for your detailed explanation. The phenomenon you describe is indeed one I would like to avoid, as I intend to do some work on the proof theoretical aspect of the logic I am considering. De Bruijn indices seem to be the way to go!
Alan: I will have a look at your comparison. This sounds very interesting.
Dominik: thanks for the pointer! 🙂
Thank you all for your contributions!
Best,
Ian
From: coq-club-request AT inria.fr <coq-club-request AT inria.fr> on behalf of Dominik Kirst <dominik.kirst AT cs.uni-saarland.de>
Sent: Wednesday, 13 October 2021 2:38 AM
To: coq-club AT inria.fr <coq-club AT inria.fr>
Just to add one more option: there is also Olivier Laurent’s anti-locally-nameless approach.
Best,
Dominik
On 12. Oct 2021, at 09:04, Alan Schmitt <alan.schmitt AT polytechnique.org> wrote:
On 2021-10-12 02:13, Jason Hu <fdhzs2010 AT hotmail.com> writes:
I would like to add that IMO, de Bruijn indices reflect the paper
proof the most faithfully, among the three methods mentioned here and
probably others.
We compared several methods (locally nameless, nominal, weak HOAS, and
full de Bruijn) in a completely different setting (a process calculus
with two kinds of binders and scope extrusion), and we found the most
concise method was de Bruijn, although they each have some advantages
and drawbacks. The work is available at
https://hal.inria.fr/hal-02536463v2/file/jar.pdf
Best,
Alan
- [Coq-Club] Formalization of the syntax of first-order logic: binders, Ian Shillito, 10/11/2021
- Re: [Coq-Club] Formalization of the syntax of first-order logic: binders, Wilayat Khan, 10/11/2021
- Re: [Coq-Club] Formalization of the syntax of first-order logic: binders, Pierre Courtieu, 10/11/2021
- Re: [Coq-Club] Formalization of the syntax of first-order logic: binders, Carlos Olarte, 10/11/2021
- Re: [Coq-Club] Formalization of the syntax of first-order logic: binders, Ian Shillito, 10/12/2021
- RE: [Coq-Club] Formalization of the syntax of first-order logic: binders, Jason Hu, 10/12/2021
- RE: [Coq-Club] Formalization of the syntax of first-order logic: binders, Alan Schmitt, 10/12/2021
- Re: [Coq-Club] Formalization of the syntax of first-order logic: binders, Dominik Kirst, 10/12/2021
- Re: [Coq-Club] Formalization of the syntax of first-order logic: binders, Ian Shillito, 10/14/2021
