coq-club - Re: [Coq-Club] Formalization of the syntax of first-order logic: binders
  • From: Dominik Kirst <dominik.kirst AT cs.uni-saarland.de>
  • To: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] Formalization of the syntax of first-order logic: binders
  • Date: Tue, 12 Oct 2021 17:38:59 +0200
  • Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=dominik.kirst AT cs.uni-saarland.de; spf=Pass smtp.mailfrom=dominik.kirst AT cs.uni-saarland.de; spf=None smtp.helo=postmaster AT theia.rz.uni-saarland.de
  • Ironport-hdrordr: A9a23:MYqUZ69zMxbIo/3YGf1uk+DJI+orL9Y04lQ7vn2ZOiYlF/Bw9vre/sjzuiWUtN98Yh0dcLO7Scq9qBHnm6KdiLN5VdyftW/d0ldAR7sM0WKN+VDd8mHFltJg6Q==
  • Ironport-phdr: A9a23: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
Just to add one more option: there is also Olivier Laurent’s anti-locally-nameless approach.
https://popl21.sigplan.org/details/CPP-2021/17/An-Anti-Locally-Nameless-Approach-to-Formalizing-Quantifiers
Best,
Dominik
On 12. Oct 2021, at 09:04, Alan Schmitt <alan.schmitt AT polytechnique.org> wrote:
On 2021-10-12 02:13, Jason Hu <fdhzs2010 AT hotmail.com> writes:
I would like to add that IMO, de Bruijn indices reflect the paper
proof the most faithfully, among the three methods mentioned here and
probably others.
We compared several methods (locally nameless, nominal, weak HOAS, and
full de Bruijn) in a completely different setting (a process calculus
with two kinds of binders and scope extrusion), and we found the most
concise method was de Bruijn, although they each have some advantages
and drawbacks. The work is available at
https://hal.inria.fr/hal-02536463v2/file/jar.pdf
Best,
Alan
