Archives de la liste
- From: Nathalie Furmento <nathalie.furmento@labri.fr>
- To: tog <guillaume.alleon@gmail.com>
- Cc: starpu-devel@lists.gforge.inria.fr
- Subject: Re: [Starpu-devel] [MACOSX] problem with examples
- Date: Tue, 05 Apr 2011 13:00:49 +0200
- List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel>
Hi,
ring_kernel.o is build from ring_kernel.cu. The rule to build a .o from a .cu is in Makefile.am.
Could you see if you also have the problems when building the tests or the examples (make -C tests or make -C examples)
Thanks,
Nathalie
On 05/04/2011 12:35, tog wrote:
Hi,
I still have a problem with the build in the mpi tests.
if /usr/bin/mpicc -DHAVE_CONFIG_H -I. -I. -I../src/common -I../include
-I../gcc-plugin/src -I../include/ -I../mpi/ -I../src/ -I../examples/
-I../src -I../include -D_GNU_SOURCE -Wall -I/usr/local/cuda/include
-O3 -gdwarf-2 -g3 -MT ring.o -MD -MP -MF ".deps/ring.Tpo" -c -o
ring.o `test -f 'tests/ring.c' || echo './'`tests/ring.c; \
then mv -f ".deps/ring.Tpo" ".deps/ring.Po"; else rm -f
".deps/ring.Tpo"; exit 1; fi
make[2]: *** No rule to make target `ring_kernel.o', needed by
`tests/ring'. Stop.
make[1]: *** [all] Error 2
make: *** [all-recursive] Error 1
Any idea of what is wrong ?
Best Regards
Guillaume
- [Starpu-devel] [MACOSX] problem with examples, tog, 05/04/2011
- Re: [Starpu-devel] [MACOSX] problem with examples, Nathalie Furmento, 05/04/2011
- Re: [Starpu-devel] [MACOSX] problem with examples, tog, 05/04/2011
- Re: [Starpu-devel] [MACOSX] problem with examples, Nathalie Furmento, 06/04/2011
- Re: [Starpu-devel] [MACOSX] problem with examples, tog, 06/04/2011
- Re: [Starpu-devel] [MACOSX] problem with examples, Nathalie Furmento, 07/04/2011
- Message indisponible
- Re: [Starpu-devel] [MACOSX] problem with examples, tog, 07/04/2011
