Archives de la liste
- To: Nathalie Furmento <nathalie.furmento@labri.fr>
- Cc: starpu-devel@lists.gforge.inria.fr
- Subject: Re: [Starpu-devel] [MACOSX] problem with examples
- Date: Thu, 7 Apr 2011 15:41:04 +0530
- Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=mime-version:in-reply-to:references:date:message-id:subject:from:to :cc:content-type:content-transfer-encoding; b=QTwPy24061IeuThOSNgrUev0Uttg8oAKvWVIleDm8QgiGlrKNyji/PWIRZNJ9m//+2 95i33VdKVxzYH3RUWLohZ8zQkc3SJnrFjXT8fYOjlVBJXRVEZPMr2FCepoPLfwBYovDZ ORoUf5YWabCMw+9l78TcYP/41xO3S+Q+6trRM=
- List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel>
Ok, this is better. We are now in the problem I was anticipating earlier ...
mpicc is generating 64 bits while nvcc is generationg 32 bits
Is there a way to trigger nvcc compiler flags ?
My automake version:
oggy:oce alleon$ automake --version
automake (GNU automake) 1.9.6
Written by Tom Tromey <tromey@redhat.com>.
Best Regards
Guillaume
CCLD tests/mpi_irecv
CC mpi_isend_detached.o
CCLD tests/mpi_isend_detached
CC mpi_irecv_detached.o
CCLD tests/mpi_irecv_detached
CC mpi_detached_tag.o
CCLD tests/mpi_detached_tag
CC ring.o
/usr/local/cuda/bin/nvcc tests/ring_kernel.cu -c -o
tests/ring_kernel.o --compiler-options -fno-strict-aliasing
-I/usr/local/cuda/include -I../include/ -I../include -I../include/
-I../include/
CCLD tests/ring
ld: warning: in tests/ring_kernel.o, file was built for i386 which is
not the architecture being linked (x86_64)
Undefined symbols:
"_increment_cuda", referenced from:
_increment_cl in ring.o
ld: symbol(s) not found
collect2: ld returned 1 exit status
make[2]: *** [tests/ring] Error 1
make[1]: *** [all] Error 2
make: *** [all-recursive] Error 1
On Thu, Apr 7, 2011 at 3:17 PM, Nathalie Furmento
<nathalie.furmento@labri.fr> wrote:
> I tried with autoconf 2.63, and i was not able to reproduce the problem.
> Which version of automake are you using ?
> There might be another solution to allow you to use StarPU. You could --
> instead of using the Subversion code -- use the latest nightly snapshot
> available here :
> http://starpu.gforge.inria.fr/testing/
> It means you do not need to run autogen.sh, just run configure and make,
> and you will get the Makefiles as they have been generated on our system.
> Regards,
> Nathalie
> On 07/04/2011 11:05, tog wrote:
>> Hi,
>> I am using autotools 2.63.
>> I have applied your second patch but I am sorry to report that I am
>> still having a problem:
>> libtool: link: /usr/bin/mpicc -Wall -I/usr/local/cuda/include -O3
>> -gdwarf-2 -g3 -o tests/.libs/mpi_detached_tag mpi_detached_tag.o
>> -L/usr/local/cuda/lib ./.libs/libstarpumpi.dylib
>> /Users/alleon/PROJECTS/starpu/src/.libs/libstarpu.dylib
>> ../src/.libs/libstarpu.dylib -lm -lcudart -lcublas -lcuda -lcufft
>> -lgfortran -lcurand -lstdc++ -lblas -lpthread
>> if /usr/bin/mpicc -DHAVE_CONFIG_H -I. -I. -I../src/common -I../include
>> -I../gcc-plugin/src -I../include/ -I../mpi/ -I../src/ -I../examples/
>> -I../src -I../include -D_GNU_SOURCE -Wall -I/usr/local/cuda/include
>> -O3 -gdwarf-2 -g3 -MT ring.o -MD -MP -MF ".deps/ring.Tpo" -c -o
>> ring.o `test -f 'tests/ring.c' || echo './'`tests/ring.c; \
>> then mv -f ".deps/ring.Tpo" ".deps/ring.Po"; else rm -f
>> ".deps/ring.Tpo"; exit 1; fi
>> make[2]: *** No rule to make target `ring_kernel.o', needed by
>> `tests/ring'. Stop.
>> Regards
>> Guillaume
>> On Thu, Apr 7, 2011 at 2:05 PM, Nathalie Furmento
>>> Hi,
>>> I looked at your Makefile, autotools on your machine clearly has a
>>> different
>>> behaviour when handling object files. I am not sure if the problem comes
>>> from the way we wrote mpi/Makefile.am or from autotools. In the meantime,
>>> could you please try the attached patch (after reverting the previous
>>> ones).
>>> Thanks,
>>> Nathalie
>>> On 06/04/2011 16:50, tog wrote:
>>>> Here is the file.
>>>> Best Regards
>>>> Guillaume
>>>> On Wed, Apr 6, 2011 at 6:31 PM, Nathalie Furmento
>>>>> I think i just overlooked the fact it is looking for ring_kernel.o
>>>>> instead
>>>>> of tests/ring_kernel.o
>>>>> Could you please send me your build/mpi/Makefile file ?
>>>>> Regards,
>>>>> Nathalie
>>>>> On 06/04/2011 14:53, tog wrote:
>>>>>> I know from make -C examples that we will have 64 bits related issues.
>>>>>> I did apply your patch and have the following behavior:
>>>>>> obelix:starpu alleon$ VERBOSE=1 make -C mpi tests/ring_kernel.o
>>>>>> -I../include/
>>>>>> which is fine but ...
>>>>>> Making all in src
>>>>>> make[2]: Nothing to be done for `all-am'.
>>>>>> Making all in mpi
>>>>>> make all-am
>>>>>> `tests/ring'. Stop.
>>>>>> If your machine is running Snow Leopard the pressing the 6& 4
>>>>>> keys at
>>>>>> boot time will load the 64 bits kernel extensions.
>>>>>> Best Regards
>>>>>> Guillaume
>>>>>> On Wed, Apr 6, 2011 at 6:03 PM, Nathalie Furmento
>>>>>>> Could you please try to recompile with the attached patch. If it is
>>>>>>> still
>>>>>>> failing, could you then try from your build directory to start:
>>>>>>> % make -C mpi V=1 tests/ring_kernel.o
>>>>>>> And then run make again.
>>>>>>> If all of that fails, please send me the file build/mpi/Makefile
>>>>>>> Concerning OpenCL, configure looks for it in different locations
>>>>>>> ("/usr/local/cuda" "/c/cuda" "/cygdrive/c/cuda" "/opt/cuda"). If your
>>>>>>> installation is in another directory, you can specify
>>>>>>> --with-opencl-dir=<directory> when calling configure.
>>>>>>> I do not think your problem is related to 64 bits. I do not have
>>>>>>> right
>>>>>>> now a
>>>>>>> 64 bits MacOS machine to start. I should be able to get one shortly.
>>>>>>> Regards,
>>>>>>> Nathalie
>>>>>>> On 06/04/2011 14:06, tog wrote:
>>>>>>>> Hi,
>>>>>>>> Few things that might be different on my machine. It is running 64
>>>>>>>> bits i.e. in the menu About This Mac -> More info ... ->
>>>>>>>> Software, I
>>>>>>>> have
>>>>>>>> 64-bit Kernel and Extensions: Yes
>>>>>>>> obelix:starpu alleon$ uname -a
>>>>>>>> Darwin oggy.lan 10.7.0 Darwin Kernel Version 10.7.0: Sat Jan 29
>>>>>>>> 15:16:10 PST 2011; root:xnu-1504.9.37~1/RELEASE_X86_64 x86_64
>>>>>>>> Then the answers to your questions:
>>>>>>>> obelix:starpu alleon$ ls -lrt mpi/tests/ring_kernel.cu
>>>>>>>> -rw-r--r-- 1 alleon staff 1125 Mar 29 14:14
>>>>>>>> The output is attached.
>>>>>>>> Do you know how to enable OpenCL on the Mac ?
>>>>>>>> Best Regards
>>>>>>>> Guillaume
>>>>>>>> On Wed, Apr 6, 2011 at 5:09 PM, Nathalie Furmento
>>>>>>>>> Hi,
>>>>>>>>> I tested on a MacOS with mpi and cuda, it is all working for me.
>>>>>>>>> Could you please check the file mpi/tests/ring_kernel.cu is
>>>>>>>>> available.
>>>>>>>>> And
>>>>>>>>> could you also please send the output of "make V=1".
>>>>>>>>> Thanks,
>>>>>>>>> Nathalie
>>>>>>>>> On 05/04/2011 13:51, tog wrote:
>>>>>>>>>> Hi,
>>>>>>>>>> Yes similar problems are there.
>>>>>>>>>> For examples, the mismatch between i386 and x86_64 can be solved
>>>>>>>>>> by
>>>>>>>>>> adding the -m64 flag to nvcc (looks like mpicc generates 64 bits
>>>>>>>>>> objects, white the default for nvcc is 32 bits).
>>>>>>>>>> It might also be solved by adding -m32 to mpicc (not tested) -
>>>>>>>>>> however
>>>>>>>>>> my machine is running 64 bits.
>>>>>>>>>> Best Regards
>>>>>>>>>> Guillaume
>>>>>>>>>> On Tue, Apr 5, 2011 at 4:30 PM, Nathalie Furmento
>>>>>>>>>>> Hi,
>>>>>>>>>>> ring_kernel.o is build from ring_kernel.cu. The rule to build a
>>>>>>>>>>> .o
>>>>>>>>>>> from
>>>>>>>>>>> a
>>>>>>>>>>> .cu is in Makefile.am.
>>>>>>>>>>> Could you see if you also have the problems when building the
>>>>>>>>>>> tests
>>>>>>>>>>> or
>>>>>>>>>>> the
>>>>>>>>>>> examples (make -C tests or make -C examples)
>>>>>>>>>>> Thanks,
>>>>>>>>>>> Nathalie
>>>>>>>>>>> On 05/04/2011 12:35, tog wrote:
>>>>>>>>>>>> Hi,
>>>>>>>>>>>> I still have a problem with the build in the mpi tests.
>>>>>>>>>>>> -I../include
>>>>>>>>>>>> -I../examples/
>>>>>>>>>>>> -o
>>>>>>>>>>>> `tests/ring'. Stop.
>>>>>>>>>>>> Any idea of what is wrong ?
>>>>>>>>>>>> Best Regards
>>>>>>>>>>>> Guillaume
PGP KeyID: 2048R/EA31CFC9 subkeys.pgp.net
- Re: [Starpu-devel] [MACOSX] problem with examples, (suite)
- Re: [Starpu-devel] [MACOSX] problem with examples, Nathalie Furmento, 05/04/2011
- Re: [Starpu-devel] [MACOSX] problem with examples, tog, 05/04/2011
- Re: [Starpu-devel] [MACOSX] problem with examples, Nathalie Furmento, 06/04/2011
- Re: [Starpu-devel] [MACOSX] problem with examples, tog, 06/04/2011
- Re: [Starpu-devel] [MACOSX] problem with examples, Nathalie Furmento, 07/04/2011
- Message indisponible
- Re: [Starpu-devel] [MACOSX] problem with examples, tog, 07/04/2011
- Re: [Starpu-devel] [MACOSX] problem with examples, tog, 08/04/2011
- Re: [Starpu-devel] [MACOSX] problem with examples, Nathalie Furmento, 08/04/2011
- Re: [Starpu-devel] [MACOSX] problem with examples, Nathalie Furmento, 13/04/2011
