Accéder au contenu.
Menu Sympa
starpu-devel - Re: [Starpu-devel] [MACOSX] problem with examples
Archives de la liste
Chronologique Discussions
  • To: Nathalie Furmento <nathalie.furmento@labri.fr>
  • Cc: starpu-devel@lists.gforge.inria.fr
  • Subject: Re: [Starpu-devel] [MACOSX] problem with examples
  • Date: Wed, 6 Apr 2011 20:20:13 +0530
  • Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=mime-version:in-reply-to:references:date:message-id:subject:from:to :cc:content-type; b=YXuuaWwnxufiNPoFG7vetLzOYb0BHpzfLQuX9m9XtQrwdOrS40nL+2svh9tDJ17nQ4 txgTLuN192gyJzzsVr1zt2r4niI85mz71t2CCr6TMMtlvol0bwdI1dCaCE3WcdykQj7G GBr5T9eRF1Z/5YFs9cfw8CgvARUT2x5SYYj2A=
  • List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel>
  • List-id: "Developers list. For discussion of new features, code changes, etc." <starpu-devel.lists.gforge.inria.fr>
Here is the file.
Best Regards
Guillaume
On Wed, Apr 6, 2011 at 6:31 PM, Nathalie Furmento
<nathalie.furmento@labri.fr> wrote:
> I think i just overlooked the fact it is looking for ring_kernel.o instead
> of tests/ring_kernel.o
> Could you please send me your build/mpi/Makefile file ?
> Regards,
> Nathalie
> On 06/04/2011 14:53, tog wrote:
>> I know from make -C examples that we will have 64 bits related issues.
>> I did apply your patch and have the following behavior:
>> obelix:starpu alleon$ VERBOSE=1 make -C mpi tests/ring_kernel.o
>> /usr/local/cuda/bin/nvcc tests/ring_kernel.cu -c -o
>> tests/ring_kernel.o --compiler-options -fno-strict-aliasing
>> -I/usr/local/cuda/include -I../include/ -I../include  -I../include/
>> -I../include/
>> which is fine but ...
>> Making all in src
>> make[2]: Nothing to be done for `all-am'.
>> Making all in mpi
>> make  all-am
>> make[2]: *** No rule to make target `ring_kernel.o', needed by
>> `tests/ring'.  Stop.
>> make[1]: *** [all] Error 2
>> make: *** [all-recursive] Error 1
>> If your machine is running Snow Leopard the pressing the 6&  4 keys at
>> boot time will load the 64 bits kernel extensions.
>> Best Regards
>> Guillaume
>> On Wed, Apr 6, 2011 at 6:03 PM, Nathalie Furmento
>>> Could you please try to recompile with the attached patch. If it is still
>>> failing, could you then try from your build directory to start:
>>> % make -C mpi V=1 tests/ring_kernel.o
>>> And then run make again.
>>> If all of that fails, please send me the file build/mpi/Makefile
>>> Concerning OpenCL, configure looks for it in different locations
>>> ("/usr/local/cuda" "/c/cuda" "/cygdrive/c/cuda" "/opt/cuda"). If your
>>> installation is in another directory, you can specify
>>> --with-opencl-dir=<directory>  when calling configure.
>>> I do not think your problem is related to 64 bits. I do not have right
>>> now a
>>> 64 bits MacOS machine to start. I should be able to get one shortly.
>>> Regards,
>>> Nathalie
>>> On 06/04/2011 14:06, tog wrote:
>>>> Hi,
>>>> Few things that might be different on my machine. It is running 64
>>>> bits i.e.  in the menu About This Mac ->    More info ... ->
>>>>  Software, I
>>>> have
>>>>   64-bit Kernel and Extensions:        Yes
>>>> obelix:starpu alleon$ uname -a
>>>> Darwin oggy.lan 10.7.0 Darwin Kernel Version 10.7.0: Sat Jan 29
>>>> 15:16:10 PST 2011; root:xnu-1504.9.37~1/RELEASE_X86_64 x86_64
>>>> Then the answers to your questions:
>>>> obelix:starpu alleon$ ls -lrt mpi/tests/ring_kernel.cu
>>>> -rw-r--r--  1 alleon  staff  1125 Mar 29 14:14 mpi/tests/ring_kernel.cu
>>>> The output is attached.
>>>> Do you know how to enable OpenCL on the Mac ?
>>>> Best Regards
>>>> Guillaume
>>>> On Wed, Apr 6, 2011 at 5:09 PM, Nathalie Furmento
>>>>> Hi,
>>>>> I tested on a MacOS with mpi and cuda, it is all working for me.
>>>>> Could you please check the file mpi/tests/ring_kernel.cu is available.
>>>>> And
>>>>> could you also please send the output of "make V=1".
>>>>> Thanks,
>>>>> Nathalie
>>>>> On 05/04/2011 13:51, tog wrote:
>>>>>> Hi,
>>>>>> Yes similar problems are there.
>>>>>> For examples, the mismatch between i386 and x86_64 can be solved by
>>>>>> adding the -m64 flag to nvcc (looks like mpicc generates 64 bits
>>>>>> objects, white the default for nvcc is 32 bits).
>>>>>> It might also be solved by adding -m32 to mpicc (not tested) - however
>>>>>> my machine is running 64 bits.
>>>>>> Best Regards
>>>>>> Guillaume
>>>>>> On Tue, Apr 5, 2011 at 4:30 PM, Nathalie Furmento
>>>>>>> Hi,
>>>>>>> ring_kernel.o is build from ring_kernel.cu. The rule to build a .o
>>>>>>> from
>>>>>>> a
>>>>>>> .cu is in Makefile.am.
>>>>>>> Could you see if you also have the problems when building the tests
>>>>>>> or
>>>>>>> the
>>>>>>> examples (make -C tests or make -C examples)
>>>>>>> Thanks,
>>>>>>> Nathalie
>>>>>>> On 05/04/2011 12:35, tog wrote:
>>>>>>>> Hi,
>>>>>>>> I still have a problem with the build in the mpi tests.
>>>>>>>> if /usr/bin/mpicc -DHAVE_CONFIG_H -I. -I. -I../src/common
>>>>>>>> -I../include
>>>>>>>> -I../gcc-plugin/src  -I../include/ -I../mpi/ -I../src/
>>>>>>>>  -I../examples/
>>>>>>>> -I../src -I../include -D_GNU_SOURCE    -Wall
>>>>>>>>  -O3  -gdwarf-2 -g3  -MT ring.o -MD -MP -MF ".deps/ring.Tpo" -c -o
>>>>>>>> ring.o `test -f 'tests/ring.c' || echo './'`tests/ring.c; \
>>>>>>>>        then mv -f ".deps/ring.Tpo" ".deps/ring.Po"; else rm -f
>>>>>>>> ".deps/ring.Tpo"; exit 1; fi
>>>>>>>> `tests/ring'.  Stop.
>>>>>>>> Any idea of what is wrong ?
>>>>>>>> Best Regards
>>>>>>>> Guillaume
PGP KeyID: 2048R/EA31CFC9  subkeys.pgp.net
Attachment: Makefile
Description: Binary data
Haut de le page
