Archives de la liste
- To: Nathalie Furmento <nathalie.furmento@labri.fr>
- Cc: starpu-devel@lists.gforge.inria.fr
- Subject: Re: [Starpu-devel] [MACOSX] problem with examples
- Date: Wed, 6 Apr 2011 18:23:07 +0530
- Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=mime-version:in-reply-to:references:date:message-id:subject:from:to :cc:content-type:content-transfer-encoding; b=h1zKVomBfurHJPb7orfidy7s/wbaSF7W5As7zD6eRrJTygH4O2PE92nPe+oJ28802i gE1zThYDwUQIKGeI/eyz1clnj5D3mauzhfV2W02BbCNixBkiCrpemwRU0Jyh20VWT3gM WDe0AOJwhb89HL4V6/effMwV0yNNJqIT0gbfY=
- List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel>
I know from make -C examples that we will have 64 bits related issues.
I did apply your patch and have the following behavior:
obelix:starpu alleon$ VERBOSE=1 make -C mpi tests/ring_kernel.o
/usr/local/cuda/bin/nvcc tests/ring_kernel.cu -c -o
tests/ring_kernel.o --compiler-options -fno-strict-aliasing
-I/usr/local/cuda/include -I../include/ -I../include -I../include/
-I../include/
which is fine but ...
Making all in src
make[2]: Nothing to be done for `all-am'.
Making all in mpi
make all-am
make[2]: *** No rule to make target `ring_kernel.o', needed by
`tests/ring'. Stop.
make[1]: *** [all] Error 2
make: *** [all-recursive] Error 1
If your machine is running Snow Leopard the pressing the 6 & 4 keys at
boot time will load the 64 bits kernel extensions.
Best Regards
Guillaume
On Wed, Apr 6, 2011 at 6:03 PM, Nathalie Furmento
<nathalie.furmento@labri.fr> wrote:
> Could you please try to recompile with the attached patch. If it is still
> failing, could you then try from your build directory to start:
> % make -C mpi V=1 tests/ring_kernel.o
> And then run make again.
> If all of that fails, please send me the file build/mpi/Makefile
> Concerning OpenCL, configure looks for it in different locations
> ("/usr/local/cuda" "/c/cuda" "/cygdrive/c/cuda" "/opt/cuda"). If your
> installation is in another directory, you can specify
> --with-opencl-dir=<directory> when calling configure.
> I do not think your problem is related to 64 bits. I do not have right now a
> 64 bits MacOS machine to start. I should be able to get one shortly.
> Regards,
> Nathalie
> On 06/04/2011 14:06, tog wrote:
>> Hi,
>> Few things that might be different on my machine. It is running 64
>> bits i.e. in the menu About This Mac -> More info ... -> Software, I
>> have
>> 64-bit Kernel and Extensions: Yes
>> obelix:starpu alleon$ uname -a
>> Darwin oggy.lan 10.7.0 Darwin Kernel Version 10.7.0: Sat Jan 29
>> 15:16:10 PST 2011; root:xnu-1504.9.37~1/RELEASE_X86_64 x86_64
>> Then the answers to your questions:
>> obelix:starpu alleon$ ls -lrt mpi/tests/ring_kernel.cu
>> -rw-r--r-- 1 alleon staff 1125 Mar 29 14:14 mpi/tests/ring_kernel.cu
>> The output is attached.
>> Do you know how to enable OpenCL on the Mac ?
>> Best Regards
>> Guillaume
>> On Wed, Apr 6, 2011 at 5:09 PM, Nathalie Furmento
>>> Hi,
>>> I tested on a MacOS with mpi and cuda, it is all working for me.
>>> Could you please check the file mpi/tests/ring_kernel.cu is available.
>>> And
>>> could you also please send the output of "make V=1".
>>> Thanks,
>>> Nathalie
>>> On 05/04/2011 13:51, tog wrote:
>>>> Hi,
>>>> Yes similar problems are there.
>>>> For examples, the mismatch between i386 and x86_64 can be solved by
>>>> adding the -m64 flag to nvcc (looks like mpicc generates 64 bits
>>>> objects, white the default for nvcc is 32 bits).
>>>> It might also be solved by adding -m32 to mpicc (not tested) - however
>>>> my machine is running 64 bits.
>>>> Best Regards
>>>> Guillaume
>>>> On Tue, Apr 5, 2011 at 4:30 PM, Nathalie Furmento
>>>>> Hi,
>>>>> ring_kernel.o is build from ring_kernel.cu. The rule to build a .o from
>>>>> a
>>>>> .cu is in Makefile.am.
>>>>> Could you see if you also have the problems when building the tests or
>>>>> the
>>>>> examples (make -C tests or make -C examples)
>>>>> Thanks,
>>>>> Nathalie
>>>>> On 05/04/2011 12:35, tog wrote:
>>>>>> Hi,
>>>>>> I still have a problem with the build in the mpi tests.
>>>>>> if /usr/bin/mpicc -DHAVE_CONFIG_H -I. -I. -I../src/common -I../include
>>>>>> -I../gcc-plugin/src -I../include/ -I../mpi/ -I../src/ -I../examples/
>>>>>> -I../src -I../include -D_GNU_SOURCE -Wall -I/usr/local/cuda/include
>>>>>> -O3 -gdwarf-2 -g3 -MT ring.o -MD -MP -MF ".deps/ring.Tpo" -c -o
>>>>>> ring.o `test -f 'tests/ring.c' || echo './'`tests/ring.c; \
>>>>>> then mv -f ".deps/ring.Tpo" ".deps/ring.Po"; else rm -f
>>>>>> ".deps/ring.Tpo"; exit 1; fi
>>>>>> `tests/ring'. Stop.
>>>>>> Any idea of what is wrong ?
>>>>>> Best Regards
>>>>>> Guillaume
PGP KeyID: 2048R/EA31CFC9 subkeys.pgp.net
- [Starpu-devel] [MACOSX] problem with examples, tog, 05/04/2011
- Re: [Starpu-devel] [MACOSX] problem with examples, Nathalie Furmento, 05/04/2011
- Re: [Starpu-devel] [MACOSX] problem with examples, tog, 05/04/2011
- Re: [Starpu-devel] [MACOSX] problem with examples, Nathalie Furmento, 06/04/2011
- Re: [Starpu-devel] [MACOSX] problem with examples, tog, 06/04/2011
- Re: [Starpu-devel] [MACOSX] problem with examples, Nathalie Furmento, 07/04/2011
- Message indisponible
- Re: [Starpu-devel] [MACOSX] problem with examples, tog, 07/04/2011
- Re: [Starpu-devel] [MACOSX] problem with examples, tog, 08/04/2011
- Re: [Starpu-devel] [MACOSX] problem with examples, Nathalie Furmento, 08/04/2011
- Re: [Starpu-devel] [MACOSX] problem with examples, Nathalie Furmento, 13/04/2011
