Accéder au contenu.
Menu Sympa
starpu-devel - Re: [Starpu-devel] [MACOSX] problem with examples
Archives de la liste
Chronologique Discussions
  • From: Nathalie Furmento <nathalie.furmento@labri.fr>
  • To: tog <guillaume.alleon@gmail.com>
  • Cc: starpu-devel@lists.gforge.inria.fr
  • Subject: Re: [Starpu-devel] [MACOSX] problem with examples
  • Date: Wed, 06 Apr 2011 13:39:36 +0200
  • List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel>
  • List-id: "Developers list. For discussion of new features, code changes, etc." <starpu-devel.lists.gforge.inria.fr>
Hi,
I tested on a MacOS with mpi and cuda, it is all working for me.
Could you please check the file mpi/tests/ring_kernel.cu is available. And could you also please send the output of "make V=1".
Thanks,
Nathalie
On 05/04/2011 13:51, tog wrote:
Hi,
Yes similar problems are there.
For examples, the mismatch between i386 and x86_64 can be solved by
adding the -m64 flag to nvcc (looks like mpicc generates 64 bits
objects, white the default for nvcc is 32 bits).
It might also be solved by adding -m32 to mpicc (not tested) - however
my machine is running 64 bits.
Best Regards
Guillaume
On Tue, Apr 5, 2011 at 4:30 PM, Nathalie Furmento
<nathalie.furmento@labri.fr> wrote:
Hi,
ring_kernel.o is build from ring_kernel.cu. The rule to build a .o from a
.cu is in Makefile.am.
Could you see if you also have the problems when building the tests or the
examples (make -C tests or make -C examples)
Thanks,
Nathalie
On 05/04/2011 12:35, tog wrote:
Hi,
I still have a problem with the build in the mpi tests.
if /usr/bin/mpicc -DHAVE_CONFIG_H -I. -I. -I../src/common -I../include
-I../gcc-plugin/src -I../include/ -I../mpi/ -I../src/ -I../examples/
-I../src -I../include -D_GNU_SOURCE -Wall -I/usr/local/cuda/include
-O3 -gdwarf-2 -g3 -MT ring.o -MD -MP -MF ".deps/ring.Tpo" -c -o
ring.o `test -f 'tests/ring.c' || echo './'`tests/ring.c; \
then mv -f ".deps/ring.Tpo" ".deps/ring.Po"; else rm -f
".deps/ring.Tpo"; exit 1; fi
make[2]: *** No rule to make target `ring_kernel.o', needed by
`tests/ring'. Stop.
make[1]: *** [all] Error 2
make: *** [all-recursive] Error 1
Any idea of what is wrong ?
Best Regards
Guillaume
Haut de le page
