Accéder au contenu.
Menu Sympa
starpu-devel - Re: [Starpu-devel] [MACOSX] problem with examples
Archives de la liste
Chronologique Discussions
  • From: Nathalie Furmento <nathalie.furmento@labri.fr>
  • To: tog <guillaume.alleon@gmail.com>
  • Cc: starpu-devel@lists.gforge.inria.fr
  • Subject: Re: [Starpu-devel] [MACOSX] problem with examples
  • Date: Wed, 13 Apr 2011 11:08:09 +0200
  • List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel>
  • List-id: "Developers list. For discussion of new features, code changes, etc." <starpu-devel.lists.gforge.inria.fr>
Hi,
The last commit (#3500) should solve your problem. It checks the maximum size available on the CUDA device before doing the allocation.
Regards,
Nathalie
On 08/04/2011 11:51, Nathalie Furmento wrote:
Hi,
Here we are trying to malloc 32 G on the device. It looks like there is not enough memory.
I am going to look at how to update this code to deal with this kind of error.
In the meantime, you can try to decrease the value of SIZE in the file src/core/perfmodel/perfmodel_bus.c , line 43
#define SIZE (32*1024*1024*sizeof(char))
Regards,
Nathalie
It looks like On 08/04/2011 11:44, tog wrote:
I am back :-)
Here is the output with the requested options:
obelix:basic_examples alleon$ ./hello_world
No performance model for the bus,
calibrating...[starpu][benchmark_all_gpu_devices] Benchmarking the
speed of the bus
Assertion failed: (d_buffer), function
measure_bandwidth_between_host_and_dev_on_cpu_with_cuda, file
core/perfmodel/perfmodel_bus.c, line 105.
Abort trap
I have updated my system so I might be able to switch to repo
Best Regards
Guillaume
obelix:basic_examples alleon$ automake --version
automake (GNU automake) 1.11.1
Copyright (C) 2009 Free Software Foundation, Inc.
License GPLv2+: GNU GPL version 2 or later
<http://gnu.org/licenses/gpl-2.0.html>
This is free software: you are free to change and redistribute it.
There is NO WARRANTY, to the extent permitted by law.
Written by Tom Tromey<tromey@redhat.com>
and Alexandre Duret-Lutz<adl@gnu.org>.
obelix:basic_examples alleon$ autoconf --version
autoconf (GNU Autoconf) 2.63
Copyright (C) 2008 Free Software Foundation, Inc.
<http://gnu.org/licenses/old-licenses/gpl-2.0.html>
Written by David J. MacKenzie and Akim Demaille.
On Thu, Apr 7, 2011 at 5:07 PM, Nathalie Furmento
<nathalie.furmento@labri.fr> wrote:
Could you try to recompile with
./configure --enable-debug --enable-verbose
Thanks,
Nathalie
On 07/04/2011 12:46, tog wrote:
./configure NVCCFLAGS=-m64 is working fine
Nevertheless all the examples I run lead to a Bus error
No performance model for the bus, calibrating...Bus error
Regards
Guillaume
On Thu, Apr 7, 2011 at 3:48 PM, Nathalie Furmento
You can use the environment variable NVCCFLAGS to pass specific options
to
nvcc.
Regards,
Nathalie
On 07/04/2011 12:11, tog wrote:
Ok, this is better. We are now in the problem I was anticipating earlier
mpicc is generating 64 bits while nvcc is generationg 32 bits
Is there a way to trigger nvcc compiler flags ?
My automake version:
oggy:oce alleon$ automake --version
automake (GNU automake) 1.9.6
Written by Tom Tromey<tromey@redhat.com>.
Best Regards
Guillaume
CCLD tests/mpi_irecv
CC mpi_isend_detached.o
CCLD tests/mpi_isend_detached
CC mpi_irecv_detached.o
CCLD tests/mpi_irecv_detached
CC mpi_detached_tag.o
CCLD tests/mpi_detached_tag
CC ring.o
/usr/local/cuda/bin/nvcc tests/ring_kernel.cu -c -o
tests/ring_kernel.o --compiler-options -fno-strict-aliasing
-I/usr/local/cuda/include -I../include/ -I../include -I../include/
-I../include/
CCLD tests/ring
ld: warning: in tests/ring_kernel.o, file was built for i386 which is
not the architecture being linked (x86_64)
Undefined symbols:
"_increment_cuda", referenced from:
_increment_cl in ring.o
ld: symbol(s) not found
collect2: ld returned 1 exit status
make[2]: *** [tests/ring] Error 1
make[1]: *** [all] Error 2
make: *** [all-recursive] Error 1
_______________________________________________
Starpu-devel mailing list
Starpu-devel@lists.gforge.inria.fr
http://lists.gforge.inria.fr/cgi-bin/mailman/listinfo/starpu-devel
Haut de le page
