Accéder au contenu.
Menu Sympa
starpu-devel - Re: [Starpu-devel] [MACOSX] problem with examples
Archives de la liste
Chronologique Discussions
  • To: Nathalie Furmento <nathalie.furmento@labri.fr>
  • Cc: starpu-devel@lists.gforge.inria.fr
  • Subject: Re: [Starpu-devel] [MACOSX] problem with examples
  • Date: Fri, 8 Apr 2011 15:14:50 +0530
  • Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=mime-version:in-reply-to:references:date:message-id:subject:from:to :cc:content-type:content-transfer-encoding; b=BA0c1Z6Y8U49YLlWvKSsxoDA+4cr8UHM3uAIowKc9MToQnF7QW07bbbkoVML1d5zoJ B0Lj71k032uwI7uia6QpKTv640ovjYm3Qp5Ty9/DdnGPmR7i9ckJ7833U1KyAsbtfT3E XjYO7XtxQm0/bDtnKma4D9pBxh7qqJDj6DOPw=
  • List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel>
  • List-id: "Developers list. For discussion of new features, code changes, etc." <starpu-devel.lists.gforge.inria.fr>
I am back :-)
Here is the output with the requested options:
obelix:basic_examples alleon$ ./hello_world
No performance model for the bus,
calibrating...[starpu][benchmark_all_gpu_devices] Benchmarking the
speed of the bus
Assertion failed: (d_buffer), function
measure_bandwidth_between_host_and_dev_on_cpu_with_cuda, file
core/perfmodel/perfmodel_bus.c, line 105.
Abort trap
I have updated my system so I might be able to switch to repo
Best Regards
Guillaume
obelix:basic_examples alleon$ automake --version
automake (GNU automake) 1.11.1
Copyright (C) 2009 Free Software Foundation, Inc.
License GPLv2+: GNU GPL version 2 or later
<http://gnu.org/licenses/gpl-2.0.html>
This is free software: you are free to change and redistribute it.
There is NO WARRANTY, to the extent permitted by law.
Written by Tom Tromey <tromey@redhat.com>
and Alexandre Duret-Lutz <adl@gnu.org>.
obelix:basic_examples alleon$ autoconf --version
autoconf (GNU Autoconf) 2.63
Copyright (C) 2008 Free Software Foundation, Inc.
<http://gnu.org/licenses/old-licenses/gpl-2.0.html>
Written by David J. MacKenzie and Akim Demaille.
On Thu, Apr 7, 2011 at 5:07 PM, Nathalie Furmento
<nathalie.furmento@labri.fr> wrote:
> Could you try to recompile with
> ./configure --enable-debug --enable-verbose
> Thanks,
> Nathalie
> On 07/04/2011 12:46, tog wrote:
>> ./configure NVCCFLAGS=-m64 is working fine
>> Nevertheless all the examples I run lead to a Bus error
>> No performance model for the bus, calibrating...Bus error
>> Regards
>> Guillaume
>> On Thu, Apr 7, 2011 at 3:48 PM, Nathalie Furmento
>>> You can use the environment variable NVCCFLAGS to pass specific options
>>> to
>>> nvcc.
>>> Regards,
>>> Nathalie
>>> On 07/04/2011 12:11, tog wrote:
>>>> Ok, this is better. We are now in the problem I was anticipating earlier
>>>> mpicc is generating 64 bits while nvcc is generationg 32 bits
>>>> Is there a way to trigger nvcc compiler flags ?
>>>> My automake version:
>>>> oggy:oce alleon$ automake --version
>>>> automake (GNU automake) 1.9.6
>>>> Written by Tom Tromey<tromey@redhat.com>.
>>>> Best Regards
>>>> Guillaume
>>>>   CCLD   tests/mpi_irecv
>>>>   CC     mpi_isend_detached.o
>>>>   CCLD   tests/mpi_isend_detached
>>>>   CC     mpi_irecv_detached.o
>>>>   CCLD   tests/mpi_irecv_detached
>>>>   CC     mpi_detached_tag.o
>>>>   CCLD   tests/mpi_detached_tag
>>>>   CC     ring.o
>>>> /usr/local/cuda/bin/nvcc tests/ring_kernel.cu -c -o
>>>> tests/ring_kernel.o --compiler-options -fno-strict-aliasing
>>>> -I/usr/local/cuda/include -I../include/ -I../include  -I../include/
>>>> -I../include/
>>>>   CCLD   tests/ring
>>>> ld: warning: in tests/ring_kernel.o, file was built for i386 which is
>>>> not the architecture being linked (x86_64)
>>>> Undefined symbols:
>>>>   "_increment_cuda", referenced from:
>>>>       _increment_cl in ring.o
>>>> ld: symbol(s) not found
>>>> collect2: ld returned 1 exit status
>>>> make[2]: *** [tests/ring] Error 1
>>>> make[1]: *** [all] Error 2
>>>> make: *** [all-recursive] Error 1
PGP KeyID: 2048R/EA31CFC9  subkeys.pgp.net
Haut de le page
