Accéder au contenu.
Menu Sympa
starpu-devel - Re: [Starpu-devel] Assert failure with regenerate flag enabled
Archives de la liste
Chronologique Discussions
  • To: Samuel Thibault <samuel.thibault@ens-lyon.org>, Starpu-devel@lists.gforge.inria.fr
  • Subject: Re: [Starpu-devel] Assert failure with regenerate flag enabled
  • Date: Thu, 13 Nov 2014 17:39:51 -0600
  • List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel/>
  • List-id: "Developers list. For discussion of new features, code changes, etc." <starpu-devel.lists.gforge.inria.fr>
Thanks for the help!
The following command to used to retrieve the source code for testing:
"svn checkout svn://scm.gforge.inria.fr/svn/starpu/trunk StarPU"
It appears not all the tasks are being performed.  After adding some debug to regenerate_pipeline.c test code, here are my test results.
StarPU/build/tests/main$ ./regenerate_pipeline
[starpu][starpu_initialize] Warning: StarPU was configured with --with-fxt, which slows down a bit
#tasks : 65536
Stop !
Total: 0.444913 secs
Per task: 6.788840 usecs
cntA: 0
cntB: 0
cntC: 65536
Cheers,
Jeff
On Thu, Nov 13, 2014 at 10:51 AM, Samuel Thibault <samuel.thibault@ens-lyon.org> wrote:
Hello,
Samuel Thibault, le Fri 07 Nov 2014 18:24:02 +0100, a écrit :
> I could easily modify our regenerate test to raise the same assertion,
> I'll investigate and add the testcase.
I have fixed the case and added the testcase, in both 1.1 and trunk
branches.
Thanks for the report!
Samuel
/* StarPU --- Runtime system for heterogeneous multicore architectures.
 * Copyright (C) 2010-2014  Université de Bordeaux
 * Copyright (C) 2010, 2011, 2012, 2013  Centre National de la Recherche Scientifique
 * StarPU is free software; you can redistribute it and/or modify
 * it under the terms of the GNU Lesser General Public License as published by
 * the Free Software Foundation; either version 2.1 of the License, or (at
 * your option) any later version.
 * StarPU is distributed in the hope that it will be useful, but
 * WITHOUT ANY WARRANTY; without even the implied warranty of
 * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
 * See the GNU Lesser General Public License in COPYING.LGPL for more details.
#include <stdio.h>
#include <unistd.h>
#include <starpu.h>
#include "../helper.h"
#include <common/thread.h>
#ifdef STARPU_QUICK_CHECK
static unsigned ntasks = 64;
#else
static unsigned ntasks = 65536;
#endif
static unsigned cntA = 0;
static unsigned cntB = 0;
static unsigned cntC = 0;
static unsigned completed = 0;
static starpu_pthread_mutex_t mutex = STARPU_PTHREAD_MUTEX_INITIALIZER;
static starpu_pthread_cond_t cond = STARPU_PTHREAD_COND_INITIALIZER;
static
void callback(void *arg)
	struct starpu_task *task = starpu_task_get_current();
	unsigned *cnt = arg;
	unsigned res;
	res = STARPU_ATOMIC_ADD(cnt, 1);
	if (res == ntasks)
		task->regenerate = 0;
		FPRINTF(stderr, "Stop !\n");
		STARPU_PTHREAD_MUTEX_LOCK(&mutex);
		completed = 1;
		STARPU_PTHREAD_COND_SIGNAL(&cond);
		STARPU_PTHREAD_MUTEX_UNLOCK(&mutex);
void dummy_func(void *descr[] STARPU_ATTRIBUTE_UNUSED, void *arg STARPU_ATTRIBUTE_UNUSED)
static struct starpu_codelet dummy_codelet =
	.cpu_funcs = {dummy_func},
	.cuda_funcs = {dummy_func},
	.opencl_funcs = {dummy_func},
	.cpu_funcs_name = {"dummy_func"},
	.model = NULL,
	.nbuffers = 0
static void parse_args(int argc, char **argv)
	int c;
	while ((c = getopt(argc, argv, "i:")) != -1)
	switch(c)
		case 'i':
			ntasks = atoi(optarg);
			break;
int main(int argc, char **argv)
	//	unsigned i;
	double timing;
	double start;
	double end;
	int ret;
	parse_args(argc, argv);
	ret = starpu_initialize(NULL, &argc, &argv);
	if (ret == -ENODEV) return STARPU_TEST_SKIPPED;
	STARPU_CHECK_RETURN_VALUE(ret, "starpu_init");
	struct starpu_task taskA, taskB, taskC;
	struct starpu_task *taskAp = &taskA;
	struct starpu_task *taskBp = &taskB;
	starpu_task_init(&taskA);
	taskA.cl = &dummy_codelet;
	taskA.regenerate = 1;
	taskA.detach = 1;
	taskA.callback_func = callback;
	taskA.callback_arg = &cntA;
	starpu_task_init(&taskB);
	taskB.cl = &dummy_codelet;
	taskB.regenerate = 1;
	taskB.detach = 1;
	taskB.callback_func = callback;
	taskB.callback_arg = &cntB;
	starpu_task_declare_deps_array(&taskB, 1, &taskAp);
	starpu_task_init(&taskC);
	taskC.cl = &dummy_codelet;
	taskC.regenerate = 1;
	taskC.detach = 1;
	taskC.callback_func = callback;
	taskC.callback_arg = &cntC;
	starpu_task_declare_deps_array(&taskA, 1, &taskBp);
	FPRINTF(stderr, "#tasks : %u\n", ntasks);
	start = starpu_timing_now();
	ret = starpu_task_submit(&taskA);
	if (ret == -ENODEV) goto enodev;
	ret = starpu_task_submit(&taskB);
	ret = starpu_task_submit(&taskC);
	STARPU_CHECK_RETURN_VALUE(ret, "starpu_task_submit");
	if (!completed)
		STARPU_PTHREAD_COND_WAIT(&cond, &mutex);
	end = starpu_timing_now();
	timing = end - start;
	FPRINTF(stderr, "Total: %f secs\n", timing/1000000);
	FPRINTF(stderr, "Per task: %f usecs\n", timing/ntasks);
	FPRINTF(stderr, "cntA: %d \n", cntA);
	FPRINTF(stderr, "cntB: %d \n", cntB);
	FPRINTF(stderr, "cntC: %d \n", cntC);
	if(cntA == 0)
		return EXIT_FAILURE;
	if(cntB == 0)
	if(cntB == 0)
	starpu_shutdown();
	/* Cleanup the statically allocated tasks after shutdown, as StarPU is still working on it after the callback */
	starpu_task_clean(&taskA);
	starpu_task_clean(&taskB);
	return EXIT_SUCCESS;
enodev:
	fprintf(stderr, "WARNING: No one can execute this task\n");
	/* yes, we do not perform the computation but we did detect that no one
 	 * could perform the kernel, so this is not an error from StarPU */
	starpu_shutdown();
Haut de le page
