Archives de la liste
- To: Samuel Thibault <samuel.thibault@ens-lyon.org>, Starpu-devel@lists.gforge.inria.fr
- Subject: Re: [Starpu-devel] Assert failure with regenerate flag enabled
- Date: Wed, 19 Nov 2014 10:22:51 -0600
- List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel/>
On Wed, Nov 19, 2014 at 4:54 AM, Samuel Thibault <samuel.thibault@ens-lyon.org> wrote:
With the chain A->B->C->D, it will likely be a long term requirement to change to A->C->B->D quickly. Jeff Hand, le Tue 18 Nov 2014 09:45:59 -0600, a écrit :
> On a slightly different topic, I'm wondering: How can dependencies be changed?
> I'm not aware of a way change or clear the dependencies.
We haven't really thought about an interface for this.
Why was I using dependencies in the first place?
1. make D dependant on A rather than the previous task (priming the pipeline)
2. declaring the dependency of a task output routed to multiple task inputs
Is the solution to enable data consistency and have the callback submit the next task in the pipeline?
Can I guarantee the dependencies of the output to many inputs occurs? Would it require a StarPU pause, submit the many tasks, and resume StarPU?
- [Starpu-devel] Assert failure with regenerate flag enabled, Jeff Hand, 04/11/2014
- Re: [Starpu-devel] Assert failure with regenerate flag enabled, Samuel Thibault, 04/11/2014
- Re: [Starpu-devel] Assert failure with regenerate flag enabled, Jeff Hand, 05/11/2014
- Re: [Starpu-devel] Assert failure with regenerate flag enabled, Samuel Thibault, 07/11/2014
- Re: [Starpu-devel] Assert failure with regenerate flag enabled, Samuel Thibault, 13/11/2014
- Re: [Starpu-devel] Assert failure with regenerate flag enabled, Jeff Hand, 14/11/2014
- Re: [Starpu-devel] Assert failure with regenerate flag enabled, Samuel Thibault, 14/11/2014
- Re: [Starpu-devel] Assert failure with regenerate flag enabled, Samuel Thibault, 17/11/2014
- Re: [Starpu-devel] Assert failure with regenerate flag enabled, Jeff Hand, 18/11/2014
- Re: [Starpu-devel] Assert failure with regenerate flag enabled, Samuel Thibault, 19/11/2014
- Re: [Starpu-devel] Assert failure with regenerate flag enabled, Jeff Hand, 19/11/2014
- Re: [Starpu-devel] Assert failure with regenerate flag enabled, Jeff Hand, 21/11/2014
- Re: [Starpu-devel] Assert failure with regenerate flag enabled, Samuel Thibault, 21/11/2014
