Accéder au contenu.
Menu Sympa
starpu-devel - Re: [Starpu-devel] Assert failure with regenerate flag enabled
Archives de la liste
Chronologique Discussions
  • To: Samuel Thibault <samuel.thibault@ens-lyon.org>, Starpu-devel@lists.gforge.inria.fr
  • Subject: Re: [Starpu-devel] Assert failure with regenerate flag enabled
  • Date: Fri, 21 Nov 2014 13:23:58 -0600
  • List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel/>
  • List-id: "Developers list. For discussion of new features, code changes, etc." <starpu-devel.lists.gforge.inria.fr>
> Can I guarantee the dependencies of the output to many inputs occurs?
Which situation are you thinking about more precisely?
It will probably work with implicit dependencies. I should be able to write test cases to prove by using modified versions found in StarPU's examples and test cases.
Thanks for the assistance.
Jeff
Haut de le page
