Accéder au contenu.
Menu Sympa
starpu-devel - Re: [Starpu-devel] Assert failure with regenerate flag enabled
Archives de la liste
Chronologique Discussions
  • To: Samuel Thibault <samuel.thibault@ens-lyon.org>, Starpu-devel@lists.gforge.inria.fr
  • Subject: Re: [Starpu-devel] Assert failure with regenerate flag enabled
  • Date: Thu, 20 Nov 2014 17:37:47 -0600
  • List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel/>
  • List-id: "Developers list. For discussion of new features, code changes, etc." <starpu-devel.lists.gforge.inria.fr>
Experimenting with regenerate etc. I found the following...
https://gforge.inria.fr/scm/viewvc.php/tags/starpu-1.1.3/tests/Makefile.am?view=markup&revision=13471&root=starpu
- change 9918 omited
As a result of change 9918,
am__main_subgraph_repeat_regenerate_SOURCES_DIST =  \
    main/subgraph_repeat.c main/increment.cu
This causes subgraph_repeat.c to be compiled instead of subgraph_repeat_regenerate.c.
Was this intentional?
On Wed, Nov 19, 2014 at 10:22 AM, Jeff Hand <jeffrey.hand@gmail.com> wrote:
On Wed, Nov 19, 2014 at 4:54 AM, Samuel Thibault <samuel.thibault@ens-lyon.org> wrote:
Jeff Hand, le Tue 18 Nov 2014 09:45:59 -0600, a écrit :
> On a slightly different topic, I'm wondering: How can dependencies be changed?
> I'm not aware of a way change or clear the dependencies.
We haven't really thought about an interface for this.
With the chain A->B->C->D, it will likely be a long term requirement to change to A->C->B->D quickly.
Why was I using dependencies in the first place?
1. make D dependant on A rather than the previous task (priming the pipeline)
2. declaring the dependency of a task output routed to multiple task inputs
Is the solution to enable data consistency and have the callback submit the next task in the pipeline?
Can I guarantee the dependencies of the output to many inputs occurs?  Would it require a StarPU pause, submit the many tasks, and resume StarPU?
Haut de le page
