Archives de la liste
- From: Samuel Thibault <samuel.thibault@ens-lyon.org>
- To: Jeff Hand <jeffrey.hand@gmail.com>
- Cc: Starpu-devel@lists.gforge.inria.fr
- Subject: Re: [Starpu-devel] Assert failure with regenerate flag enabled
- Date: Fri, 21 Nov 2014 18:52:57 +0100
- List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel/>
Jeff Hand, le Wed 19 Nov 2014 10:22:51 -0600, a écrit :
> Is the solution to enable data consistency and have the callback submit the
> next task in the pipeline?
That can be working yes, depending on your workflow.
> Can I guarantee the dependencies of the output to many inputs occurs?
Which situation are you thinking about more precisely?
Samuel
- Re: [Starpu-devel] Assert failure with regenerate flag enabled, (suite)
- Re: [Starpu-devel] Assert failure with regenerate flag enabled, Samuel Thibault, 07/11/2014
- Re: [Starpu-devel] Assert failure with regenerate flag enabled, Samuel Thibault, 13/11/2014
- Re: [Starpu-devel] Assert failure with regenerate flag enabled, Jeff Hand, 14/11/2014
- Re: [Starpu-devel] Assert failure with regenerate flag enabled, Samuel Thibault, 14/11/2014
- Re: [Starpu-devel] Assert failure with regenerate flag enabled, Samuel Thibault, 17/11/2014
- Re: [Starpu-devel] Assert failure with regenerate flag enabled, Jeff Hand, 18/11/2014
- Re: [Starpu-devel] Assert failure with regenerate flag enabled, Samuel Thibault, 19/11/2014
- Re: [Starpu-devel] Assert failure with regenerate flag enabled, Jeff Hand, 19/11/2014
- Re: [Starpu-devel] Assert failure with regenerate flag enabled, Jeff Hand, 21/11/2014
- Re: [Starpu-devel] Assert failure with regenerate flag enabled, Samuel Thibault, 21/11/2014
