Archives de la liste
- To: Hatem Ltaief <hatem.ltaief@kaust.edu.sa>, Amani Alonazi <amani.alonazi@kaust.edu.sa>, "starpu-devel@lists.gforge.inria.fr" <starpu-devel@lists.gforge.inria.fr>
- Subject: Re: [Starpu-devel] Starpu stats about disk, OOC, and swapping
- Date: Wed, 16 Jan 2019 09:59:10 +0100
- List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel/>
- Organization: I am not organized
Samuel Thibault, le mer. 16 janv. 2019 09:23:19 +0100, a ecrit:
> Hatem Ltaief, le mer. 16 janv. 2019 04:53:18 +0000, a ecrit:
> > Does starpu allocate separate threads to perform the OOC data movement?
> > Does the IO operation turn out to be done in parallel? How does it differ
> > from standard fwrite and fread system calls?
> Yes, it always uses asynchronous data transfers, which allows to overlap
> everything.
(and it pushes data to disk ahead of missing out memory, and prefetches
it from the disk ahead of needing it for tasks).
Samuel
- Re: [Starpu-devel] Starpu stats about disk, OOC, and swapping, (suite)
- Re: [Starpu-devel] Starpu stats about disk, OOC, and swapping, Amani Alonazi, 14/01/2019
- Re: [Starpu-devel] Starpu stats about disk, OOC, and swapping, Samuel Thibault, 14/01/2019
- Re: [Starpu-devel] Starpu stats about disk, OOC, and swapping, Samuel Thibault, 15/01/2019
- Re: [Starpu-devel] Starpu stats about disk, OOC, and swapping, Hatem Ltaief, 16/01/2019
- Re: [Starpu-devel] Starpu stats about disk, OOC, and swapping, Samuel Thibault, 16/01/2019
- Re: [Starpu-devel] Starpu stats about disk, OOC, and swapping, Hatem Ltaief, 17/01/2019
- Re: [Starpu-devel] Starpu stats about disk, OOC, and swapping, Samuel Thibault, 17/01/2019
- Re: [Starpu-devel] Starpu stats about disk, OOC, and swapping, Amani Alonazi, 17/01/2019
- Re: [Starpu-devel] Starpu stats about disk, OOC, and swapping, Amani Alonazi, 18/01/2019
- Re: [Starpu-devel] Starpu stats about disk, OOC, and swapping, Samuel Thibault, 18/01/2019
