Archives de la liste
- To: Amani Alonazi <amani.alonazi@kaust.edu.sa>
- Cc: "starpu-devel@lists.gforge.inria.fr" <starpu-devel@lists.gforge.inria.fr>, Hatem Ltaief <Hatem.Ltaief@kaust.edu.sa>
- Subject: Re: [Starpu-devel] Starpu stats about disk, OOC, and swapping
- Date: Tue, 15 Jan 2019 11:13:13 +0100
- List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel/>
- Organization: I am not organized
Amani Alonazi, le lun. 14 janv. 2019 22:06:03 +0300, a ecrit:
> On Mon, Jan 14, 2019 at 9:31 PM Samuel Thibault
> <[1]samuel.thibault@inria.fr>
> wrote:
> Amani Alonazi, le lun. 14 janv. 2019 21:24:33 +0300, a ecrit:
> > Hopefully last question :-) I'm using STARPU_DISK_SWAP_BACKEND=unistd.
> How can
> > I analyze how much data transferred to disk during OOC computation?
> Shall
> I
> > assume that anything exceeds the sustained BW that it runs at the
> sustained
> > BW?
> > I clearly notice the extra time required in executing each tasks with
> big
> > smaller STARPU_LIMIT_CPU_MEM. I just want to quantify the amount of
> transfer in
> > /out to disk.
> I'm not sure which precise information do you want. Do you mean you
> want to know *during the execution* the amount of data transferred so
> far?
> We can easily add a function to get this.
> Yes, I would like to know during the execution.
The function is actually already available, it's
starpu_bus_get_profiling_info(). You can look at
_starpu_profiling_bus_helper_display_summary() in
src/profiling/profiling_helpers.c to have a usage example.
Samuel
- Re: [Starpu-devel] Starpu stats about disk, OOC, and swapping, (suite)
- Re: [Starpu-devel] Starpu stats about disk, OOC, and swapping, Samuel Thibault, 14/01/2019
- Re: [Starpu-devel] Starpu stats about disk, OOC, and swapping, Amani Alonazi, 14/01/2019
- Re: [Starpu-devel] Starpu stats about disk, OOC, and swapping, Samuel Thibault, 15/01/2019
- Re: [Starpu-devel] Starpu stats about disk, OOC, and swapping, Hatem Ltaief, 16/01/2019
- Re: [Starpu-devel] Starpu stats about disk, OOC, and swapping, Samuel Thibault, 16/01/2019
- Re: [Starpu-devel] Starpu stats about disk, OOC, and swapping, Hatem Ltaief, 17/01/2019
- Re: [Starpu-devel] Starpu stats about disk, OOC, and swapping, Samuel Thibault, 17/01/2019
- Re: [Starpu-devel] Starpu stats about disk, OOC, and swapping, Amani Alonazi, 17/01/2019
- Re: [Starpu-devel] Starpu stats about disk, OOC, and swapping, Amani Alonazi, 18/01/2019
