Accéder au contenu.
Menu Sympa
starpu-devel - [Starpu-devel] environment variable for instrumenting the write back to disk
Archives de la liste
Chronologique Discussions
  • To: "starpu-devel@lists.gforge.inria.fr" <starpu-devel@lists.gforge.inria.fr>
  • Cc: Amani Alonazi <amani.alonazi@kaust.edu.sa>
  • Subject: [Starpu-devel] environment variable for instrumenting the write back to disk
  • Date: Tue, 12 Mar 2019 11:52:33 +0000
  • Accept-language: en-GB, en-US
  • Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=hatem.ltaief@kaust.edu.sa; spf=Pass smtp.mailfrom=prvs=6974b72203=hatem.ltaief@kaust.edu.sa; spf=None smtp.helo=postmaster@mx08-0025e101.pphosted.com
  • Ironport-phdr: 9a23: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
  • List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel/>
  • List-id: "Developers list. For discussion of new features, code changes, etc." <starpu-devel.lists.gforge.inria.fr>
Dear Sam,
Can you please remind us what is the name of the environment variable which
instruments the write back to disk?
This was the variable specifying the threshold on main memory from which
StarPU starts OOCing to disk.
I believe it is currently set to something like 10%.
Does it make sense?
Thanks,
Hatem
Haut de le page
