Archives de la liste
Re: [Starpu-devel] environment variable for instrumenting the write back to disk
Chronologique Discussions
- To: Amani Alonazi <amani.alonazi@kaust.edu.sa>
- Cc: "starpu-devel@lists.gforge.inria.fr" <starpu-devel@lists.gforge.inria.fr>, Hatem Ltaief <hatem.ltaief@kaust.edu.sa>
- Subject: Re: [Starpu-devel] environment variable for instrumenting the write back to disk
- Date: Tue, 12 Mar 2019 16:15:23 +0100
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=samuel.thibault@inria.fr; spf=Neutral smtp.mailfrom=samuel.thibault@ens-lyon.org; spf=Pass smtp.helo=postmaster@hera.aquilenet.fr
- Ironport-phdr: 9a23:CzAGOhZcHNLOj8eITD0v2aX/LSx+4OfEezUN459isYplN5qZr8S6bnLW6fgltlLVR4KTs6sC17OO9fi5EUU7or+5+EgYd5JNUxJXwe43pCcHRPC/NEvgMfTxZDY7FskRHHVs/nW8LFQHUJ2mPw6arXK99yMdFQviPgRpOOv1BpTSj8Oq3Oyu5pHfeQpFiCehbb9oMBm6sBjau9ULj4dlNqs/0AbCrGFSe+RRy2NoJFaTkAj568yt4pNt8Dletuw4+cJYXqr0Y6o3TbpDDDQ7KG81/9HktQPCTQSU+HQRVHgdnwdSDAjE6BH6WYrxsjf/u+Fg1iSWIdH6QLYpUjm58axlVAHnhzsGNz4h8WHYlMpwjL5AoBm8oxBz2pPYbJ2JOPZ7eK7WYNEUSndbXstJWSJPAp2yYZYMAeoPMulXs5TyqFkJrRSwHgSsGP/jxyVUinPqx6A2zeIsGhzG0gw6GNIOtWzZosjvO6cXTOC60q3IxijdYfNW2Dfy85LHcg0lofGQQLl9dtHRxlMqFwPYkFqQrZbpPy+V1uQMqGeU9fdgVeazi2M8qgFxpCKvxsY2hYXTiIIV0EnJ+CNky4g7It24TVR0Yd+iEJZIqi6aNpB2Qt84Q2Fpoyk20KAJtoSnfCcQzpks2h3Ra+SffoSV4R/uVPydLSl2iX9rYr6zmgq+/VS6xuHhTsW4zVlHojZfntTOtH0BzQHf58adRvZ5+kqs3yuE2RrJ5eFeO080kLLWK54/zb40kZoeqUTDETHsmErslqOZbFwk+vWp6+TjfLrmoIGTN5NuhgHwKKQigs2/AeImPQgSR2WX5Oex2b358UHnTrhHgOc6nrTFvJzGP8gXu7a1AwpP3YYi7xa/AS2m0NMdnXQfN1JKYheHj5X3NFHKOvz4Efe/g1W3nzhx2vDGOqHhD47TIXjFi7ftZLJ96k5byAo119xf4IhUCr4ZLPLpRkDxrMDYDgM+MwGs2ObnFM9y1pkGWWKSG6OWLb3dsUGW6eIrOOSMYI4VuC3hK/g+/fLugnE5mVgHfammw5QbcnG4HvJ8I0WYe3XgmNkBEX1Z9jY5GcXvgVuDGRdXYHC7TaN0sjg+AYSnS47HQYakkr2p3y6mBYEQa2xbTEuFRyTGbYKBDswFbT+fJoddkj0OXKWlV8d1zhirqQL+jaZnL+Dd5ykEnZPlztl8oePJw0JhvQdoBtiQhjneB1p/mXkFEnpvhPgm8B5Nj2yb2K09uMR2UNla5vdHSAA/bMKOwuphTtTjXQSHec2GGgz/HoeWRAopR9d0+OcgJl5nEoz63BHFxSujRbEPxeTSWc4Et5nE1n20HP5TjnbL0K543gsmT9FGc2S/m697+g7eG8jHiRfAmg==
- List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel/>
- Organization: I am not organized
Amani Alonazi, le mar. 12 mars 2019 17:54:30 +0300, a ecrit:
> Thanks, one more thing what is the timing in distrib.data? is it time per
> task?
It seems so yes.
(I'd really advise to rather use tasks.rec, which I believe has no less
information, and much more information).
Samuel
- [Starpu-devel] environment variable for instrumenting the write back to disk, Hatem Ltaief, 12/03/2019
- Re: [Starpu-devel] environment variable for instrumenting the write back to disk, Samuel Thibault, 12/03/2019
- Re: [Starpu-devel] environment variable for instrumenting the write back to disk, Amani Alonazi, 12/03/2019
- Re: [Starpu-devel] environment variable for instrumenting the write back to disk, Amani Alonazi, 13/03/2019
- Re: [Starpu-devel] environment variable for instrumenting the write back to disk, Samuel Thibault, 13/03/2019
