Accéder au contenu.
Menu Sympa
starpu-devel - Re: [Starpu-devel] environment variable for instrumenting the write back to disk
Archives de la liste
Chronologique Discussions
  • To: Samuel Thibault <samuel.thibault@inria.fr>, Hatem Ltaief <hatem.ltaief@kaust.edu.sa>, "starpu-devel@lists.gforge.inria.fr" <starpu-devel@lists.gforge.inria.fr>, Amani Alonazi <amani.alonazi@kaust.edu.sa>
  • Subject: Re: [Starpu-devel] environment variable for instrumenting the write back to disk
  • Date: Tue, 12 Mar 2019 17:54:30 +0300
  • Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=amani.alonazi@kaust.edu.sa; spf=Pass smtp.mailfrom=amani.alonazi@kaust.edu.sa; spf=None smtp.helo=postmaster@mail-ed1-f46.google.com
  • Ironport-phdr: 9a23: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
  • List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel/>
  • List-id: "Developers list. For discussion of new features, code changes, etc." <starpu-devel.lists.gforge.inria.fr>
Thanks, one more thing what is the timing in distrib.data? is it time per task?
Thanks again,
On Tue, Mar 12, 2019 at 2:55 PM Samuel Thibault <samuel.thibault@inria.fr> wrote:
Hatem Ltaief, le mar. 12 mars 2019 11:52:33 +0000, a ecrit:
> Can you please remind us what is the name of the environment variable which instruments the write back to disk?
> This was the variable specifying the threshold on main memory from which StarPU starts OOCing to disk.
> I believe it is currently set to something like 10%.
It's STARPU_MINIMUM_CLEAN_BUFFERS and STARPU_TARGET_CLEAN_BUFFERS.
Samuel
Amani AlOnazi
PhD Student
Extreme Computing Research Center
King Abdullah University of Science and Technology
Al-Khawarizmi (Bldg.1)
Floor 0, Office 0203-WS02
Telephone: +966 (12) 808 0218
Mobile: +966 (0) 555191795
Email: amani.alonazi@kaust.edu.sa
www.kaust.edu.sa
This message and its contents, including attachments are intended solely for the original recipient. If you are not the intended recipient or have received this message in error, please notify me immediately and delete this message from your computer system. Any unauthorized use or distribution is prohibited. Please consider the environment before printing this email.
Haut de le page
