Accéder au contenu.
Menu Sympa
starpu-devel - Re: [Starpu-devel] environment variable for instrumenting the write back to disk
Archives de la liste
Chronologique Discussions
  • To: Hatem Ltaief <hatem.ltaief@kaust.edu.sa>
  • Cc: "starpu-devel@lists.gforge.inria.fr" <starpu-devel@lists.gforge.inria.fr>, Amani Alonazi <amani.alonazi@kaust.edu.sa>
  • Subject: Re: [Starpu-devel] environment variable for instrumenting the write back to disk
  • Date: Tue, 12 Mar 2019 12:55:31 +0100
  • Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=samuel.thibault@inria.fr; spf=Neutral smtp.mailfrom=samuel.thibault@ens-lyon.org; spf=Pass smtp.helo=postmaster@hera.aquilenet.fr
  • Ironport-phdr: 9a23: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
  • List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel/>
  • List-id: "Developers list. For discussion of new features, code changes, etc." <starpu-devel.lists.gforge.inria.fr>
  • Organization: I am not organized
Hatem Ltaief, le mar. 12 mars 2019 11:52:33 +0000, a ecrit:
> Can you please remind us what is the name of the environment variable which
> instruments the write back to disk?
> This was the variable specifying the threshold on main memory from which
> StarPU starts OOCing to disk.
> I believe it is currently set to something like 10%.
It's STARPU_MINIMUM_CLEAN_BUFFERS and STARPU_TARGET_CLEAN_BUFFERS.
Samuel
Haut de le page
