Archives de la liste
- To: "Dr. Adamantios Stavridis" <astavrid@iti.gr>
- Cc: Dimitris Tsoukalas <tsoukj@iti.gr>, starpu-devel@lists.gforge.inria.fr
- Subject: Re: [Starpu-devel] [exa2pro] StarPU installation
- Date: Mon, 13 May 2019 13:13:10 +0200
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=samuel.thibault@inria.fr; spf=Neutral smtp.mailfrom=samuel.thibault@ens-lyon.org; spf=Pass smtp.helo=postmaster@hera.aquilenet.fr
- Ironport-phdr: 9a23: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
- List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel/>
- Organization: I am not organized
Hello,
Dr. Adamantios Stavridis, le lun. 13 mai 2019 14:10:06 +0300, a ecrit:
> I am trying to compile 1.3.1 tarball version on an 64bit Ubuntu host.
> Configure runs smoothly ok, but then when I run make I get the following
> error.
> /usr/bin/ld: warning: libcublas.so.9.0, needed by ../src/.libs/
> libstarpu-1.3.so, not found (try using -rpath or -rpath-link)
> Do you have any idea how this is solved?
It looks like your shell does not have LD_LIBRARY_PATH set to the place
where these CUDA libraries are installed, you need it for execution,
CUDA_HOME will not be enough.
Samuel
- [Starpu-devel] [exa2pro] StarPU installation, Dr. Adamantios Stavridis, 13/05/2019
- Re: [Starpu-devel] [exa2pro] StarPU installation, Samuel Thibault, 13/05/2019
- Re: [Starpu-devel] [exa2pro] StarPU installation, Dr. Adamantios Stavridis, 13/05/2019
