Accéder au contenu.
Menu Sympa
starpu-devel - Re: [Starpu-devel] [exa2pro] StarPU installation
Archives de la liste
Chronologique Discussions
  • To: "Dr. Adamantios Stavridis" <astavrid@iti.gr>
  • Cc: 'Dimitris Tsoukalas' <tsoukj@iti.gr>, starpu-devel@lists.gforge.inria.fr
  • Subject: Re: [Starpu-devel] [exa2pro] StarPU installation
  • Date: Mon, 13 May 2019 13:49:57 +0200
  • Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=samuel.thibault@inria.fr; spf=Neutral smtp.mailfrom=samuel.thibault@ens-lyon.org; spf=Pass smtp.helo=postmaster@hera.aquilenet.fr
  • Ironport-phdr: 9a23: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
  • List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel/>
  • List-id: "Developers list. For discussion of new features, code changes, etc." <starpu-devel.lists.gforge.inria.fr>
  • Organization: I am not organized
Dr. Adamantios Stavridis, le lun. 13 mai 2019 14:43:05 +0300, a ecrit:
> unsupported GNU version! gcc versions later than 6 are not supported!
> #error -- unsupported GNU version! gcc versions later than 6 are not
> supported!
> Is this true?
Yes, Nvidia's nvcc only supports old GCC, that's a recurring issue with
it. You can install gcc-6 in your ubuntu system and use
export NVCC_CC=gcc-6
before configure.
Samuel
Haut de le page
