Accéder au contenu.
Menu Sympa
starpu-devel - Re: [Starpu-devel] [exa2pro] StarPU installation
Archives de la liste
Chronologique Discussions
  • To: "'Samuel Thibault'" <samuel.thibault@inria.fr>
  • Cc: 'Dimitris Tsoukalas' <tsoukj@iti.gr>, starpu-devel@lists.gforge.inria.fr
  • Subject: Re: [Starpu-devel] [exa2pro] StarPU installation
  • Date: Mon, 13 May 2019 15:47:28 +0300
  • Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=astavrid@iti.gr; spf=Pass smtp.mailfrom=astavrid@iti.gr; spf=None smtp.helo=postmaster@mail.iti.gr
  • Ironport-phdr: 9a23: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
  • List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel/>
  • List-id: "Developers list. For discussion of new features, code changes, etc." <starpu-devel.lists.gforge.inria.fr>
  • Organization: CERTH/ITI
Thanks once more indeed, got through this one.
Now the error message is...
gcc-6: error trying to exec 'cc1plus': execvp: No such file or directory
Adam
-----Original Message-----
Sent: 13 May 2019 14:50
To: Dr. Adamantios Stavridis <astavrid@iti.gr>
Cc: starpu-devel@lists.gforge.inria.fr; 'Dimitris Tsoukalas' <tsoukj@iti.gr>
Subject: Re: [exa2pro] StarPU installation
Dr. Adamantios Stavridis, le lun. 13 mai 2019 14:43:05 +0300, a ecrit:
> unsupported GNU version! gcc versions later than 6 are not supported!
> #error -- unsupported GNU version! gcc versions later than 6 are not
> supported!
> Is this true?
Yes, Nvidia's nvcc only supports old GCC, that's a recurring issue with it.
You can install gcc-6 in your ubuntu system and use
export NVCC_CC=gcc-6
before configure.
Samuel
Haut de le page
