Archives de la liste
- To: "'Samuel Thibault'" <samuel.thibault@inria.fr>
- Cc: 'Dimitris Tsoukalas' <tsoukj@iti.gr>, starpu-devel@lists.gforge.inria.fr
- Subject: Re: [Starpu-devel] [exa2pro] StarPU installation
- Date: Mon, 13 May 2019 14:43:05 +0300
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=astavrid@iti.gr; spf=Pass smtp.mailfrom=astavrid@iti.gr; spf=None smtp.helo=postmaster@mail.iti.gr
- Ironport-phdr: 9a23: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
- List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel/>
- Organization: CERTH/ITI
Hi Sam.
Thanks for your quick reply.
Ok I put in the the .bash_profile file and it seems to work now I get some
warning messages in the procedure but that might be because I have also
starpu ver1.2 installed from Ubuntu repository directly.
But now, I get the following error message.
unsupported GNU version! gcc versions later than 6 are not supported!
#error -- unsupported GNU version! gcc versions later than 6 are not
supported!
Is this true?
The latest version of Ubuntu has gcc 7.4.
What now?
Adam
-----Original Message-----
Sent: 13 May 2019 14:13
To: Dr. Adamantios Stavridis <astavrid@iti.gr>
Cc: starpu-devel@lists.gforge.inria.fr; Dimitris Tsoukalas <tsoukj@iti.gr>
Subject: Re: [exa2pro] StarPU installation
Hello,
Dr. Adamantios Stavridis, le lun. 13 mai 2019 14:10:06 +0300, a ecrit:
> I am trying to compile 1.3.1 tarball version on an 64bit Ubuntu host.
> Configure runs smoothly ok, but then when I run make I get the following
error.
> /usr/bin/ld: warning: libcublas.so.9.0, needed by ../src/.libs/
> libstarpu-1.3.so, not found (try using -rpath or -rpath-link)
> Do you have any idea how this is solved?
It looks like your shell does not have LD_LIBRARY_PATH set to the place
where these CUDA libraries are installed, you need it for execution,
CUDA_HOME will not be enough.
Samuel
- [Starpu-devel] [exa2pro] StarPU installation, Dr. Adamantios Stavridis, 13/05/2019
- Re: [Starpu-devel] [exa2pro] StarPU installation, Samuel Thibault, 13/05/2019
- Re: [Starpu-devel] [exa2pro] StarPU installation, Dr. Adamantios Stavridis, 13/05/2019
