Archives de la liste
- To: <starpu-devel@lists.gforge.inria.fr>
- Cc: Dimitris Tsoukalas <tsoukj@iti.gr>
- Subject: [Starpu-devel] [exa2pro] StarPU installation
- Date: Mon, 13 May 2019 14:10:06 +0300
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=astavrid@iti.gr; spf=Pass smtp.mailfrom=astavrid@iti.gr; spf=None smtp.helo=postmaster@mail.iti.gr
- Ironport-phdr: 9a23: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
- List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel/>
- Organization: CERTH/ITI
Hi there.
I am trying to compile 1.3.1 tarball version on an 64bit Ubuntu host. Configure runs smoothly ok, but then when I run make I get the following error.
/usr/bin/ld: warning: libcublas.so.9.0, needed by ../src/.libs/libstarpu-1.3.so, not found (try using -rpath or -rpath-link) /usr/bin/ld: warning: libcudart.so.9.0, needed by ../src/.libs/libstarpu-1.3.so, not found (try using -rpath or -rpath-link) /usr/bin/ld: warning: libcusparse.so.9.0, needed by ../src/.libs/libstarpu-1.3.so, not found (try using -rpath or -rpath-link)
Do you have any idea how this is solved? I tried to set the variable CUDA_HOME=/usr/local/cuda-9.0/ according to the version installed but still doesn’t work.
Adam
Dr. Adamantios Stavridis Research Associate Centre of Research & Technology - Hellas Information Technologies Institute (CERTH/ITI) 6th km Xarilaou - Thermi, 57001, Thessaloniki, Greece
- [Starpu-devel] [exa2pro] StarPU installation, Dr. Adamantios Stavridis, 13/05/2019
- Re: [Starpu-devel] [exa2pro] StarPU installation, Samuel Thibault, 13/05/2019
- Re: [Starpu-devel] [exa2pro] StarPU installation, Dr. Adamantios Stavridis, 13/05/2019
