Archives de la liste
- To: typographie AT inria.fr
- Subject: Re: [typo] Usage des accents
- Date: Wed, 28 Jul 2021 11:44:59 +0200
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=benoit AT leraillez.com; spf=Pass smtp.mailfrom=benoit AT leraillez.com; spf=Pass smtp.helo=postmaster AT gateway30.websitewelcome.com
- Ironport-hdrordr: A9a23:wCLERa7AnbUu/AOIAgPXwCfXdLJyesId70hD6qkRc31om6Oj5qOTdZgguiMczQxhPU3I5+rvBEDwexPhHPdOiOF7V9uftUvdyQyVxepZnOnfKlPbaknDHss079YYAtAOc6yLfCVHZTaW2mSF+xxM+qj6zEhb6N2uuEuEs2xRGtBdB2ESMHfTLqQPfnghOXIKfKDslvaukVKbCAcqhjHXPAhwYwA/yue74q4PVnY9dmwaAD/it0LW1FYzfiLooCv3qV50sMIfzVQ=
- Ironport-phdr: A9a23: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
Le 28 juil. 2021 à 10:07, Jacques Melot <jacques.melot AT isholf.is> a écrit :Le 27/07/21, à 23:22 +0200, nous recevions de Benoît Leraillez :Le 27 juil. 2021 à 22:53, diconoma <diconoma AT orange.fr> a écrit :
Jacques Melot : « on constate que beaucoup ne profitent pas de l'accès possible à l'ensemble des caractères diacrités des langues les plus diverses, accès possible mais en pratique peu facilité, si ce n'est sur Apple MacIntosh, et encore à condition d'être un peu bricoleur parfois. »
Sous Word pour PC, il me suffit de saisir au clavier standard é$ pour obtenir É , è$ pour È, etc.Voulez-vous savoir comment faire ?Question bricolage sur Mac, j¹ai un clavier où j¹ai échangé le « ' » et le « ¹ ». Pourquoi ne pas faire de même avec Microsoft Keyboard Layout Creator pour les majuscules accentuées ? Du style alt-shift-minuscule accentuée = majuscule accentuée.[…] Le QWERTZ présente le gros inconvénient de ne pas pouvoir être utilisé par les dactylographes déjà formés sans nécessiter un nouvel apprentissage qui se verra compliqué par la nécessité de dominer les anciens réflexes. La solution la plus simple est de faire des claviers bien conçus et qui seraient distribués sans alternative possible par tous les fabricants. La seule différence avec l'AZERTY actuel devrait être la possibilité de produire les majuscules accentuées françaises sans plus de difficulté que pour l'accent circonflexe et le tréma, processus qui ne demande pas plus de deux touches à actionner.
Le vrai problème est qu’il n’y a pas une méthode uniforme pour obtenir les caractères accentués et que certains peuvent être saisis de plusieurs façons. La caricature étant le Ÿ que l’on peut obtenir avec « ¨+Y » ou « alt-shift-@ »
Ce serait bien que l’accent aigu soit aussi une touche morte. Sur mon clavier les « ` ^ ¨ » sont directement disponibles, l’accent aigu nécessite une frappe complexe : all-shift-&, et le tilde alt-n.
En attendant, j'utilise le logiciel Ukelele (sur Mac) pour redistribuer les touches du clavier afin d'avoir un accès aisé aux caractères que j'utilise le plus souvent en dehors du français (lettres islandaises et autrement germaniques, y compris le hver du gotique). Encore une fois, moi et quelques autres nous le faisons, mais le fait est que même cette solution relativement très simple constitue un obstacle dissuasif pour l'immense majorité des utilisateurs. Par contre cela ne devrait pas être le cas des professionnels, mais ce l'est pourtant encore trop souvent.
Même logiciel ici.
Sinon, en ce qui concerne les professionnels, si seulement quelqu’un diffusait un tel profil clavier et le faisait savoir.
On aimerait avoir accès à É comme on a accès à é (frappe unique), mais cela n'est pas possible, en tout cas pour l'ensemble des voyelles à accentuer à cause du nombre insuffisant de touches. On peut certes mettre É en accès direct en faisant émajuscule, mais alors c'est au prix de la perte du chiffre 2 (d'où l'obligation de disposer d'un pavé numérique). Bref il n'existe pas de solution entièrement satisfaisante, mais celle suggérée ici présente l'avantage qu'elle ne nécessite qu'un apprentissagesupplémentaire (donc qui ne suppose aucun réflexe à refouler), alors que l'adoption du clavier QWERTZ nécessite elle un apprentissage de remplacement, ce qui est évidemment un investissement beaucoup plus lourd, puisqu'il consiste à apprendre le métier à nouveau.
Puisque tu es sur Mac tu as deux claviers français disponibles : Français et Français-numérique. Avec le Français, toutes les majuscules accentuées sont disponibles via le caps-lock et les chiffres sont obtenus via shift, sur le Français-numérique caps-lock et shit te donnent les chiffres et les majuscules accentuées s’obtiennent avec des alt divers et variés.
Benoît Leraillez
4, venelle du Port
22560 Trébeurden
+33 (0)6 75 88 13 50
- Re: [typo] Usage des accents, (suite)
- Re: [typo] Usage des accents, Jacques Melot, 27/07/2021
- Re: [typo] Usage des accents, Jacques André, 27/07/2021
- Re: [typo] Usage des accents, Amalric Oriet, 27/07/2021
- Re: [typo] Usage des accents, Marion Gevers, 28/07/2021
- RE: [typo] Usage des accents, diconoma, 27/07/2021
- Re: [typo] Usage des accents, Benoît Leraillez, 27/07/2021
- Re: [typo] Usage des accents, Jacques Melot, 28/07/2021
- Re: [typo] Usage des accents, Benoît Leraillez, 28/07/2021
- Re: [typo] Usage des accents, Didier Verna, 28/07/2021
- Re: [typo] Usage des accents, Nicolas Ribeyre, 28/07/2021
- Re: [typo] Usage des accents, jm, 28/07/2021
