Accéder au contenu.
Menu Sympa
typographie - Re: [typo] Usage des accents
Archives de la liste
Chronologique Discussions
  • To: typographie AT inria.fr
  • Subject: Re: [typo] Usage des accents
  • Date: Tue, 27 Jul 2021 18:24:30 +0200
  • Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=o.amalric AT gmail.com; spf=Pass smtp.mailfrom=o.amalric AT gmail.com; spf=None smtp.helo=postmaster AT mail-wm1-f50.google.com
  • Ironport-hdrordr: A9a23:Z85a8are36PmR/cxdAKNM+oaV5oZeYIsimQD101hICG9Kvbo9fxG785rsCMc6QxhIE3I9urhBEDtex7hHP1OkPIs1NWZLWrbUQKTRekIh7cKqAeOJ8SKzI9gPNBbHZSWZuedMbEwt7ef3ODxKadG/DCoytHPuQ+RpU0dND1XVw==
  • Ironport-phdr: A9a23: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
Bonjour,
Si je voulais être taquin (en toute amitié), je dirais que les codes, c’est comme les opinions, il faut les mettre à jour de temps à autre… (pas taper, merci).
Dans la dernière édition du Manual, il est désormais écrit ceci (§ 11.37) :
  1. Although French publishers have often omitted accents on capital letters (especially A) and may set the ligature (E as two separate letters (OE), all the special characters needed for French-including capitalized forms­ are widely available, and they should be retained wherever needed in English-language contexts. This practice, advocated by the Academie française, is especially helpful to readers who may not be familiar with French typographic usage.
En 2021, l’écrasante majorité des codes (récents ou mis à jour) relatifs à l’orthotypographie française recommande chaudement l’accentuation systématique des majuscules. La raison principale étant qu’à l’heure de la 5G et de la fibre optique, il n’existe plus véritablement d’arguments sérieux s’y opposant. L’usage adoptant cette saine pratique un poil plus rapidement que ne le suggère Jacques Melot…
Cordialement,
Amalric O.
Le 27 juil. 2021 à 16:00, Jacques Melot <jacques.melot AT isholf.is> a écrit :
 Le 27/07/21, à 14:29 +0200, nous recevions de Jacques André :
Le 27 juil. 2021 à 08:03, Brigitte Gaudin de Gaullier - Freelance Translator <bgaudin AT gmail.com> a écrit :
Bonjour,
Une amie argentine qui donne des cours de français à Buenos Aires recherche un site fiable sur les règles d'accentuation. Avez-vous une recommandation ?
Au passage, que pensez-vous de ce site ?
https://www.lalanguefrancaise.com/articles/le-guide-de-usage-des-accents-en-francais
Cordialement,
Brigitte
AMHA votre question relève d¹avantage de listes de discussions sur la langue françaiseŠ comme vous l¹on sous-entendu  les experts  Jacques Poitou et Jacques  Melot !
Vue d¹un point de vue (étroit certes) de typo, la seule question pertinente serait « Quand doit-on omettre en français l¹accentuation (et la pose des signes diacritiques) ? »
À quoi la réponse lapidaire serait « Jamais. Et surtout pas sur les capitales ». Mais ça relancerait un vieux débat...
[J. M.]  Ah ! ces petits jeunes et leur enthousiasme parfois un peu sectaire...
   Non, ce n'est pas aussi simple. En français, l'usage est de ne pas accentuer les majuscules ou sinon une partie d'entre elles seulement, ce à quoi l'Académie objecte quelque chose comme « en français les accents ont pleine valeur orthographique et doivent donc aussi être utilisées sur les majuscules » et de « condamner » ainsi 95 % (au bas mot) de l'écrit français. Cet ukaze de l'Académie est en réalité « à côté de la plaque », car le fait de ne pas accentuer les majuscules ou de ne les accentuer que partiellement est une simple convention qui n'est que l'_expression_ de l'usage ; cela ne marque nullement une intention de supprimer les accents considérant qu'ils sont inutiles. Pourquoi alors les conserverait-on sur les minuscules ?
   Quelle est l'origine de cet usage ? À vrai dire peu importe, puisque rien ne peut ni ne doit s'opposer à l'usage, sauf dans le cas où une norme extérieure à la langue s'applique. Récemment j'ai écrit un article de terminologie* dans lequel j'ai montré que l'on devait écrire « bleu de crésyle » et non « bleu de crésyl », bien que cette dernière orthographe soit environ vingt fois plus fréquente que l'orthographe correcte. Ici l'on doit rectifier l'usage, car la faute est due à une confusion entre le nom commercial d'un désinfectant (le Crésyl) et celui d'un radical chimique (crésyle). Tôt ou tard cette rectification aurait été faite car l'orthogaphe « crésyle » est imposée par la norme de la nomenclature chimique.
* Jacques Melot, 2019. -- Terminologie mycologique. I. Le bleu de crésyle. Bull. Soc. mycol. France, 132 (3-4), p. 261-267.
   Cela dit, dans la revue scientifique que je dirige, j'ai fait inscrire dans la marche que les majuscules doivent être accentuées systématiquement. La raison en est que la revue en question a un public international et que l'absence de tout ou partie des accents, ne serait-ce que sur les majuscules, est perturbant chez ceux dont la langue maternelle n'est pas le français et peut avoir un effet d'apprentissage à rebours qui ne serait pas un service à leur rendre. À cela s'ajoute que rétablir les accents sur les majuscules qui, suivant l'usage français, s'en étaient vues privées n'est en aucun cas une faute et ne présente aucun inconvénient. On doit y voir un « nouvel » usage typographique, celui du français international, usage que l'on peut étendre, si l'on veut, au français général, ce que je fais. Mais, encore une fois, déclarer à l'emporte-pièce que « en français on doit accentuer les majuscules », non. C'est là une « procédé totalitaire » du même acabit que la féminisation au forceps de la langue. On peut donc conseiller aux professeurs de français comme langue étrangère d'enseigner à leurs élèves qu'ils doivent accentuer les majuscules tout en leur précisant qu'une convention fait qu'en France on supprime la plupart du temps tout ou partie de ces accents, même si cet usage recule lentement.
   Jacques Melot
P.-S.  Dans le Chicago Manuel of Style (14e édition, § 9.33, p. 327), dont les rédacteurs n'ont a priori pas d'états d'âme particulier en ce qui concerne le français, on trouve ceci :
[Note infrapaginale :]
   French printers vary in practice, some retaining accents on all capitals (except the preposition à, which never carries the accent when capitalized), some retaining accents only on I and E (or using an accent on I even when omitting one from E), some omitting them altogether. English and American printers reflect all these practices.
Jacques André
La liste Typo ‹ discussions typographiques
Les archives : https://sympa.inria.fr/sympa/arc/typographie
Désabonnement : <mailto:sympa_inria AT inria.fr?subject=unsubscribe%20typographie>
La liste Typo — discussions typographiques
Haut de le page
