Archives de la liste
- To: Didier Verna <didier AT didierverna.net>, Jacques Melot <jacques.melot AT isholf.is>
- Cc: typographie AT inria.fr
- Subject: Re: [typo] Usage des accents
- Date: Wed, 28 Jul 2021 15:06:10 +0200
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=jacques.melot AT isholf.is; spf=Pass smtp.mailfrom=jacques.melot AT isholf.is; spf=None smtp.helo=postmaster AT smtp-out1-03.simnet.is
- Ironport-hdrordr: A9a23:GN4rAK7ayOPl3dgUqAPXwO/XdLJyesId70hD6qkRc20pTiX2ra CTdZgguCMczQxhPU3I+urwRJVoI0mslqKdiLN5VdzJYOClghrLEGgI1+TfKkjbehEWgdQy6U 4PScRD4fTLfD9HZZyT2njfLz9q+qjizEnhv5am8585JTsaEJ2Jx29Ce3ym+mQffng/OaYE
- Ironport-phdr: A9a23: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
- Ironport-phdr: A9a23:xbHRER1E9ryW/18ksmDPhFBlVkEcU9TcJQsJ8t8glq4LKv/l5JXnO kHDo/R23xfFXoTevvRDjeee86XtQncJ7pvJtnceOIdNWBkIhYRenwEpDMOfT0yuKvnsYkQH
- Ironport-sdr: XU9P3izY2uSqW9BfX97ob8s1CKeZjNvMwr33ZwefpcMe2jZCOu9njl96caoRAUc/jSOTKIpy1H eFqVVoq9AaG7R2I3r8ysDrx3npLJDDmlBaRL0xR7SbjLj6I0eFj2c7sPKkXcIQ3Fgs/bn1U2Iy 5gtNKYvnjksZIe0YRhnBkezlcXw1rLmHdKD85LPGPrkj+HQiArHf0om3ouOuvO6nDzv1KUM236 CD0+I91v9CvPsXqQsDtpNAongx97bkUUhbVmYxzciu2xjXllX86WH0e2Y+fckAtmqsbsBd3Yrp fUg=
Le 28/07/21, à 14:28 +0200, nous recevions de Didier Verna :
Jacques Melot <jacques.melot AT isholf.is> wrote:
Le QWERTZ présente le gros inconvénient de ne pas pouvoir être utilisé
par les dactylographes déjà formés sans nécessiter un nouvel
apprentissage qui se verra compliqué par la nécessité de dominer les
anciens réflexes.
C'est le problème général des agencements de clavier « en dur », qui
ne seront jamais adaptés qu'à peu près à une langue à la fois... À titre
personnel, je trouve vraiment dommage que le concept de « méthode de
saisie », assez connu chez les informaticiens, et que l'on trouve par
exemple sous l'éditeur de texte Emacs, ne soit pas plus répandu.
Voici comment sous Emacs, et sur un clavier QWERTY, j'obtiens les
accents (y compris dans cet email):
- e ' -> é
- E ' -> É
- c , -> ç
etc.
Pour obtenir e', on double l'accent et c'est tout: e ' '.
C'est très facile à mémoriser et ça devient très vite un réflexe.
Dans ce cas, il s'agit d'une méthode postfixe, mais il existe la même
chose en préfixe (p.ex. on tape ' e au lieu de e ').
Pour taper de l'Espagnol, je change de méthode, et j'obtiens en plus,
par exemple, n ~ -> ñ. Pas besoin de changer de clavier à chaque
langue...
En somme, si je comprends bien, nous disons à peu près la même chose, au moins dans l'esprit (cf. mon dernier message).
J. M.
¡En Seguida! -- New album: https://www.didierverna.com/records/en-seguida.php
Available on all digital platforms now!
Lisp, Jazz, Aïkido: http://www.didierverna.info
- Re: [typo] Usage des accents, (suite)
- Re: [typo] Usage des accents, Jacques Melot, 27/07/2021
- Re: [typo] Usage des accents, Amalric Oriet, 27/07/2021
- Re: [typo] Usage des accents, Marion Gevers, 28/07/2021
- RE: [typo] Usage des accents, diconoma, 27/07/2021
- Re: [typo] Usage des accents, Benoît Leraillez, 27/07/2021
- Re: [typo] Usage des accents, Jacques Melot, 28/07/2021
- Re: [typo] Usage des accents, Benoît Leraillez, 28/07/2021
- Re: [typo] Usage des accents, Didier Verna, 28/07/2021
- Re: [typo] Usage des accents, Nicolas Ribeyre, 28/07/2021
- Re: [typo] Usage des accents, jm, 28/07/2021
