- To: Paul Leyland <paul.leyland@gmail.com>
- Cc: cado-nfs-discuss@lists.gforge.inria.fr
- Subject: Re: [Cado-nfs-discuss] Possible problem with "purge!'s ARGV?
- Date: Thu, 4 Apr 2013 20:25:51 +0200
- List-archive: <http://lists.gforge.inria.fr/pipermail/cado-nfs-discuss>
- List-id: A discussion list for Cado-NFS <cado-nfs-discuss.lists.gforge.inria.fr>
Paul,
The output of purge in c147.purge.log suggest that this is not the
latest version of purge that is executed.
Are you sure that the version of purge and the version of cadofactor.pl
that are running are identical ?
> Should I let the run continue or should I interrupt it and try to
> recover somehow?
You can stop the factorization as the purge binary will always fails in
the same way (unused parameter) and the sieving step will never stop.
You can later recover the work that are already done by using
cadofactor.pl with exactly the same arguments on the command line.
Cyril
[2013-04-04 17:51:39 +0100] Paul Leyland:
> I'm running the latest git repository version of CADO-NFS on a c147 and
> was wondering why I never had enough relations. As I'm a complete newby
> I may genuinely not have enough, but I also have lines like this in
> purge.log
> pcl@maat ~/cado-nfs/test $ cat tmp/c147.purge.log
> /home/pcl/cado-nfs-1.1/build/maat/filter/purge.ra55366a
> -poly ./tmp//c147.poly -keep 160 -nrels 38129246
> -out ./tmp//c147.purged.gz -npthr 2x2 -basepath ./tmp/
> -subdirlist ./tmp//c147.subdirlist -filelist ./tmp//c147.filelist
> Warning: unused command-line parameter npthr
> Usage: purge [options] -poly polyfile -out purgedfile -nrels nnn
> [-basepath <path>] [-subdirlist <sl>] [-filelist <fl>] file1 ... filen
> Options:
> -excess nnn - initial excess (default 1.01)
> -keep nnn - prune if excess > nnn (default 160)
> -minpa nnn - purge alg. primes >= nnn (default alim)
> -minpr nnn - purge rat. primes >= nnn (default rlim)
> -nprimes nnn - expected number of prime ideals
> -sos sosfile - to keep track of the renumbering
> -raw - output relations in CADO format
> Should I be worried?
> recover somehow?
> Right now there are "Info:Running total: 47706267 relations." which is
> plausibly large enough to complete the factorization.
> The factorization was started with
> ../cadofactor.pl params=../params/params.c147 wdir=./tmp/ name=c147 n=`cat
> num.n`
> and, of course, num.n contains a single line containing 147 decimal digits
> Thanks,
> Paul
> _______________________________________________
> Cado-nfs-discuss mailing list
> Cado-nfs-discuss@lists.gforge.inria.fr
> http://lists.gforge.inria.fr/cgi-bin/mailman/listinfo/cado-nfs-discuss
- [Cado-nfs-discuss] Possible problem with "purge!'s ARGV?, Paul Leyland, 04/04/2013
- Re: [Cado-nfs-discuss] Possible problem with "purge!'s ARGV?, Cyril Bouvier, 04/04/2013
- Re: [Cado-nfs-discuss] Possible problem with "purge!'s ARGV?, Paul Leyland, 04/04/2013
- Re: [Cado-nfs-discuss] Possible problem with "purge!'s ARGV?, Zimmermann Paul, 04/05/2013
- Re: [Cado-nfs-discuss] Possible problem with "purge!'s ARGV?, Paul Leyland, 04/05/2013
- Re: [Cado-nfs-discuss] Possible problem with "purge!'s ARGV?, Zimmermann Paul, 04/06/2013
- Re: [Cado-nfs-discuss] Possible problem with "purge!'s ARGV?, Paul Leyland, 04/07/2013
- Re: [Cado-nfs-discuss] Possible problem with "purge!'s ARGV?, Zimmermann Paul, 04/07/2013
- Re: [Cado-nfs-discuss] Possible problem with "purge!'s ARGV?, Paul Leyland, 04/08/2013
- Re: [Cado-nfs-discuss] Possible problem with "purge!'s ARGV?, Paul Leyland, 04/10/2013
- Re: [Cado-nfs-discuss] Possible problem with "purge!'s ARGV?, Emmanuel Thomé, 04/10/2013
