- To: Cyril Bouvier <Cyril.Bouvier@loria.fr>
- Cc: cado-nfs-discuss@lists.gforge.inria.fr
- Subject: Re: [Cado-nfs-discuss] Possible problem with "purge!'s ARGV?
- Date: Thu, 04 Apr 2013 19:46:19 +0100
- List-archive: <http://lists.gforge.inria.fr/pipermail/cado-nfs-discuss>
- List-id: A discussion list for Cado-NFS <cado-nfs-discuss.lists.gforge.inria.fr>
Thanks Cyril.
I'll give it a try and see what happens. This is the first time I've
used cadofactor.pl and didn't know what to expect.
Paul
On Thu, 2013-04-04 at 20:25 +0200, Cyril Bouvier wrote:
> Paul,
> The output of purge in c147.purge.log suggest that this is not the
> latest version of purge that is executed.
> Are you sure that the version of purge and the version of cadofactor.pl
> that are running are identical ?
> > Should I let the run continue or should I interrupt it and try to
> > recover somehow?
> You can stop the factorization as the purge binary will always fails in
> the same way (unused parameter) and the sieving step will never stop.
> You can later recover the work that are already done by using
> cadofactor.pl with exactly the same arguments on the command line.
> Cyril
> [2013-04-04 17:51:39 +0100] Paul Leyland:
> > I'm running the latest git repository version of CADO-NFS on a c147 and
> > was wondering why I never had enough relations. As I'm a complete newby
> > I may genuinely not have enough, but I also have lines like this in
> > purge.log
> > pcl@maat ~/cado-nfs/test $ cat tmp/c147.purge.log
> > /home/pcl/cado-nfs-1.1/build/maat/filter/purge.ra55366a
> > -poly ./tmp//c147.poly -keep 160 -nrels 38129246
> > -out ./tmp//c147.purged.gz -npthr 2x2 -basepath ./tmp/
> > -subdirlist ./tmp//c147.subdirlist -filelist ./tmp//c147.filelist
> > Warning: unused command-line parameter npthr
> > Usage: purge [options] -poly polyfile -out purgedfile -nrels nnn
> > [-basepath <path>] [-subdirlist <sl>] [-filelist <fl>] file1 ... filen
> > Options:
> > -excess nnn - initial excess (default 1.01)
> > -keep nnn - prune if excess > nnn (default 160)
> > -minpa nnn - purge alg. primes >= nnn (default alim)
> > -minpr nnn - purge rat. primes >= nnn (default rlim)
> > -nprimes nnn - expected number of prime ideals
> > -sos sosfile - to keep track of the renumbering
> > -raw - output relations in CADO format
> > Should I be worried?
> > recover somehow?
> > Right now there are "Info:Running total: 47706267 relations." which is
> > plausibly large enough to complete the factorization.
> > The factorization was started with
> > ../cadofactor.pl params=../params/params.c147 wdir=./tmp/ name=c147
> > n=`cat num.n`
> > and, of course, num.n contains a single line containing 147 decimal digits
> > Thanks,
> > Paul
> > _______________________________________________
> > Cado-nfs-discuss mailing list
> > Cado-nfs-discuss@lists.gforge.inria.fr
> > http://lists.gforge.inria.fr/cgi-bin/mailman/listinfo/cado-nfs-discuss
- [Cado-nfs-discuss] Possible problem with "purge!'s ARGV?, Paul Leyland, 04/04/2013
- Re: [Cado-nfs-discuss] Possible problem with "purge!'s ARGV?, Cyril Bouvier, 04/04/2013
- Re: [Cado-nfs-discuss] Possible problem with "purge!'s ARGV?, Paul Leyland, 04/04/2013
- Re: [Cado-nfs-discuss] Possible problem with "purge!'s ARGV?, Zimmermann Paul, 04/05/2013
- Re: [Cado-nfs-discuss] Possible problem with "purge!'s ARGV?, Paul Leyland, 04/05/2013
- Re: [Cado-nfs-discuss] Possible problem with "purge!'s ARGV?, Zimmermann Paul, 04/06/2013
- Re: [Cado-nfs-discuss] Possible problem with "purge!'s ARGV?, Paul Leyland, 04/07/2013
- Re: [Cado-nfs-discuss] Possible problem with "purge!'s ARGV?, Zimmermann Paul, 04/07/2013
- Re: [Cado-nfs-discuss] Possible problem with "purge!'s ARGV?, Paul Leyland, 04/08/2013
- Re: [Cado-nfs-discuss] Possible problem with "purge!'s ARGV?, Paul Leyland, 04/10/2013
- Re: [Cado-nfs-discuss] Possible problem with "purge!'s ARGV?, Emmanuel Thomé, 04/10/2013
- Re: [Cado-nfs-discuss] Possible problem with "purge!'s ARGV?, Zimmermann Paul, 04/10/2013
