cgal-discuss - Re: [cgal-discuss] Install script doesn't detect Boost
  • To:
  • Subject: Re: [cgal-discuss] Install script doesn't detect Boost
  • Date: Sun, 23 Sep 2007 17:09:06 +0200
  • Organization: Inria, Sophia Antipolis, FRANCE
On Sunday 23 September 2007 16:12:53 Lindley M French wrote:
> Since the compile error said it couldn't find
> boost/version.hpp, I set the incl dir to be '...../boost_1_34_1', since
> 'boost/version.hpp' exists under that. Same error list anyway.
Can you then send the install_cgal.log file output with the following command?
./install_cgal --BOOST_INCL_DIR /Developer/Headers/boost_1_34_1/
Among the platforms on which CGAL is daily tested, we have a few MacOS-X.
Them
have Boost-1.34.1 headers in /sw/include and Boost libraries in /sw/lib/.
If you only have boost library, you will not have the support for
Boost.ProgramOptions, but you will have support for all Boost components that
do not have libraries.
Laurent Rineau
INRIA - Sophia Antipolis
BP 93, 2004 Route des Lucioles
06902 Sophia Antipolis Cedex FRANCE
Tel: +33 4 92 38 78 62 (Fax: +33.4.97.15.53.95)
