- To:
- Subject: Re: [cgal-discuss] Install script doesn't detect Boost
- Date: Sun, 23 Sep 2007 22:07:08 -0400
- Priority: normal
All right, I've figured out that using cgal_create_makefile causes most of
the errors to go away.
But I'm not sure how to modify the generated makefile to include my own
headers. Seeing as the line:
-I../../include
doesn't actually point to anything interesting, I figured I'd modify it to
point to the [i]current[/i] directory. (Which really should be in the search
path already, but apparently isn't because a header file there isn't being
found.)
But when I make that line:
-I./
The all the CGAL errors come back again.
----- Original Message -----
Date: Sunday, September 23, 2007 6:22 pm
> On Monday 24 September 2007 00:09:40 Lindley M French wrote:
> > Okay, past that problem, on to the next.
> > gcc 4.0.1 doesn't seem to like any use of "CGAL_NTS sign()" or
> "CGAL_NTS> abs()". Attached is the output from an attempted compile
> of a program that
> > just pulls in a few CGAL headers.
> Make sure that you include <CGAL/basic.h> before anything else, in
> every .cpp
> file that uses CGAL. I am not sure, but that might be the cause of
> the error.
> Laurent Rineau
> INRIA - Sophia Antipolis
> BP 93, 2004 Route des Lucioles
> 06902 Sophia Antipolis Cedex FRANCE
> Tel: +33 4 92 38 78 62 (Fax: +33.4.97.15.53.95)
> You are currently subscribed to cgal-discuss.
> To unsubscribe or access the archives, go to
> https://lists-sop.inria.fr/wws/info/cgal-discuss
- Install script doesn't detect Boost, Lindley M French, 09/23/2007
- Re: [cgal-discuss] Install script doesn't detect Boost, Laurent Rineau, 09/23/2007
- Re: [cgal-discuss] Install script doesn't detect Boost, Lindley M French, 09/23/2007
- Re: [cgal-discuss] Install script doesn't detect Boost, Lindley M French, 09/24/2007
- Re: [cgal-discuss] Install script doesn't detect Boost, Laurent Rineau, 09/24/2007
