- To:
- Subject: Re: [cgal-discuss] Install script doesn't detect Boost
- Date: Sun, 23 Sep 2007 16:31:42 -0400
- Priority: normal
That appears to have solved it. Thanks!
----- Original Message -----
Date: Sunday, September 23, 2007 12:21 pm
> On Sunday 23 September 2007 17:25:04 Lindley M French wrote:
> > Here's the log.
> Thanks for the log file. There might be a bug in install_cgal: it
> seems that
> the --BOOST_INCL_DIR option has been ignored.
> Can you use the following command, instead?
> CPPFLAGS="-I/Developer/Headers/boost_1_34_1/" ./install_cgal
> > I really only need CGAL's Delaunay triangulation code for the
> moment, so I
> > don't think Boost.ProgramOptions will be required.
> You are right. More generally, Boost.ProgramOptions is not used by
> the CGAL
> library it self. It is only used in a few example programs.
> > /sw/include and /sw/lib are places that Fink likes to install
> things,> right? Should I be using that? I'm not right now, just
> downloading the .bz2
> > file from boost.org to my desktop.
> That might be the easiest way to make sure CGAL compiles. However,
> your first
> email said "Boost doesn't have to be compiled; good thing, too,
> because I
> don't have the extra gigabytes necessary for that monster." :-)
> Laurent Rineau
> INRIA - Sophia Antipolis
> BP 93, 2004 Route des Lucioles
> 06902 Sophia Antipolis Cedex FRANCE
> Tel: +33 4 92 38 78 62 (Fax: +33.4.97.15.53.95)
> You are currently subscribed to cgal-discuss.
> To unsubscribe or access the archives, go to
> https://lists-sop.inria.fr/wws/info/cgal-discuss
- Install script doesn't detect Boost, Lindley M French, 09/23/2007
- Re: [cgal-discuss] Install script doesn't detect Boost, Laurent Rineau, 09/23/2007
- Re: [cgal-discuss] Install script doesn't detect Boost, Lindley M French, 09/23/2007
- Re: [cgal-discuss] Install script doesn't detect Boost, Lindley M French, 09/24/2007
- Re: [cgal-discuss] Install script doesn't detect Boost, Laurent Rineau, 09/24/2007
