cgal-discuss - Re: [cgal-discuss] Install script doesn't detect Boost
  • To:
  • Subject: Re: [cgal-discuss] Install script doesn't detect Boost
  • Date: Mon, 24 Sep 2007 10:10:31 +0200
  • Organization: Inria, Sophia Antipolis, FRANCE
On Monday 24 September 2007 04:07:08 Lindley M French wrote:
> All right, I've figured out that using cgal_create_makefile causes most of
> the errors to go away.
> But I'm not sure how to modify the generated makefile to include my own
> headers. Seeing as the line:
> -I../../include
> doesn't actually point to anything interesting, I figured I'd modify it to
> point to the [i]current[/i] directory. (Which really should be in the
> search path already, but apparently isn't because a header file there isn't
> being found.)
> But when I make that line:
> -I./
> The all the CGAL errors come back again.
At that point, the mailing list can no longer help you, unless you give us
more details: you code, and even the list of all files that are in the
current directory "./"
However, do not send too big files to the file. Publish them somewhere on the
web, instead.
Laurent Rineau
INRIA - Sophia Antipolis
BP 93, 2004 Route des Lucioles
06902 Sophia Antipolis Cedex FRANCE
Tel: +33 4 92 38 78 62 (Fax: +33.4.97.15.53.95)
