cgal-discuss - Re: [cgal-discuss] Install script doesn't detect Boost
  • To:
  • Subject: Re: [cgal-discuss] Install script doesn't detect Boost
  • Date: Sun, 23 Sep 2007 18:09:40 -0400
  • Priority: normal
Okay, past that problem, on to the next.
gcc 4.0.1 doesn't seem to like any use of "CGAL_NTS sign()" or "CGAL_NTS
abs()". Attached is the output from an attempted compile of a program that
just pulls in a few CGAL headers.
Cmdline:
g++ *.cpp -I"./" -I"/Developer/Headers/CGAL-3.3.1/include"
-I"/Developer/Headers/boost_1_34_1/"
-I"/Developer/Headers/CGAL-3.3.1/include/CGAL/config/powerpc_Darwin-8.10_g++-4.0.1"
> compileoutput.txt
----- Original Message -----
Date: Sunday, September 23, 2007 12:21 pm
> On Sunday 23 September 2007 17:25:04 Lindley M French wrote:
> > Here's the log.
> Thanks for the log file. There might be a bug in install_cgal: it
> seems that
> the --BOOST_INCL_DIR option has been ignored.
> Can you use the following command, instead?
> CPPFLAGS="-I/Developer/Headers/boost_1_34_1/" ./install_cgal
> > I really only need CGAL's Delaunay triangulation code for the
> moment, so I
> > don't think Boost.ProgramOptions will be required.
> You are right. More generally, Boost.ProgramOptions is not used by
> the CGAL
> library it self. It is only used in a few example programs.
> > /sw/include and /sw/lib are places that Fink likes to install
> things,> right? Should I be using that? I'm not right now, just
> downloading the .bz2
> > file from boost.org to my desktop.
> That might be the easiest way to make sure CGAL compiles. However,
> your first
> email said "Boost doesn't have to be compiled; good thing, too,
> because I
> don't have the extra gigabytes necessary for that monster." :-)
> Laurent Rineau
> INRIA - Sophia Antipolis
> BP 93, 2004 Route des Lucioles
> 06902 Sophia Antipolis Cedex FRANCE
> Tel: +33 4 92 38 78 62 (Fax: +33.4.97.15.53.95)
> You are currently subscribed to cgal-discuss.
> To unsubscribe or access the archives, go to
> https://lists-sop.inria.fr/wws/info/cgal-discuss
/Developer/Headers/CGAL-3.3.1/include/CGAL/number_utils.h:213: error:
expected unqualified-id before 'const'
expected `)' before 'const'
/Developer/Headers/CGAL-3.3.1/include/CGAL/number_utils.h:222: error:
/Developer/Headers/CGAL-3.3.1/include/CGAL/number_utils_classes.h: In member
function 'CGAL::Sign CGAL::Sgn<T>::operator()(const NT&) const':
/Developer/Headers/CGAL-3.3.1/include/CGAL/number_utils_classes.h:96: error:
expected unqualified-id before '(' token
function 'NT CGAL::Abs<NT>::operator()(const NT&) const':
/Developer/Headers/CGAL-3.3.1/include/CGAL/number_utils_classes.h:101: error:
/Developer/Headers/CGAL-3.3.1/include/CGAL/Interval_nt.h: At global scope:
/Developer/Headers/CGAL-3.3.1/include/CGAL/Interval_nt.h:943: error: expected
`)' before 'const'
`)' before 'const'
/Developer/Headers/CGAL-3.3.1/include/CGAL/Interval_nt.h: In member function
'CGAL::Uncertain<CGAL::Sign>
CGAL::Real_embeddable_traits<CGAL::Interval_nt<Protected>,
CGAL::Boolean_tag<false> >::Sign::operator()(const
CGAL::Interval_nt<Protected>&) const':
/Developer/Headers/CGAL-3.3.1/include/CGAL/Interval_nt.h:1094: error:
/Developer/Headers/CGAL-3.3.1/include/CGAL/Number_types/internal_functions_comparison_root_of_2.h:
In function 'CGAL::Comparison_result CGAL::CGALi::compare_21_11(const FT&,
const FT&, const FT&, const FT&, const FT&)':
/Developer/Headers/CGAL-3.3.1/include/CGAL/Number_types/internal_functions_comparison_root_of_2.h:61:
error: expected unqualified-id before '(' token
error: no matching function for call to 'enum_cast(<type error>)'
In function 'CGAL::Comparison_result CGAL::CGALi::compare_22_21(const FT&,
const FT&, const FT&, const FT&, const FT&, const FT&)':
/Developer/Headers/CGAL-3.3.1/include/CGAL/Number_types/internal_functions_comparison_root_of_2.h:100:
In function 'CGAL::Comparison_result CGAL::CGALi::compare_22_11(const FT&,
/Developer/Headers/CGAL-3.3.1/include/CGAL/Number_types/internal_functions_comparison_root_of_2.h:158:
/Developer/Headers/CGAL-3.3.1/include/CGAL/Number_types/internal_functions_comparison_root_of_2.h:176:
/Developer/Headers/CGAL-3.3.1/include/CGAL/Root_of_2.h: In member function
'CGAL::Root_of_2<RT_> CGAL::Root_of_2<RT_>::inverse() const':
/Developer/Headers/CGAL-3.3.1/include/CGAL/Root_of_2.h:223: error: expected
'CGAL::Sign CGAL::Root_of_2<RT_>::sign_at(const T&) const':
/Developer/Headers/CGAL-3.3.1/include/CGAL/Root_of_2.h:306: error: expected
'CGAL::Sign CGAL::Real_embeddable_traits<CGAL::Root_of_2<RT>,
CGAL::Boolean_tag<false> >::Sign::operator()(const CGAL::Root_of_2<RT>&)
const':
/Developer/Headers/CGAL-3.3.1/include/CGAL/Root_of_2.h:462: error: expected
/Developer/Headers/CGAL-3.3.1/include/CGAL/Root_of_2.h:465: error: expected
'CGAL::Comparison_result CGAL::Real_embeddable_traits<CGAL::Root_of_2<RT>,
CGAL::Boolean_tag<false> >::Compare::operator()(const CGAL::Root_of_2<RT>&,
const CGAL::Root_of_2<RT>&) const':
/Developer/Headers/CGAL-3.3.1/include/CGAL/Root_of_2.h:507: error: expected
/Developer/Headers/CGAL-3.3.1/include/CGAL/Root_of_2.h:516: error: expected
/Developer/Headers/CGAL-3.3.1/include/CGAL/Root_of_2.h:521: error: expected
/Developer/Headers/CGAL-3.3.1/include/CGAL/Root_of_2.h:542: error: expected
/Developer/Headers/CGAL-3.3.1/include/CGAL/Root_of_2.h:543: error: expected
/Developer/Headers/CGAL-3.3.1/include/CGAL/Root_of_2.h:585: error: expected
const typename CGAL::Root_of_traits<RT>::RootOf_1&) const':
/Developer/Headers/CGAL-3.3.1/include/CGAL/Root_of_2.h:618: error: expected
const RT&) const':
/Developer/Headers/CGAL-3.3.1/include/CGAL/Root_of_2.h:653: error: expected
/Developer/Headers/CGAL-3.3.1/include/CGAL/Quotient.h: In function
'CGAL::Comparison_result CGAL::quotient_cmp(const CGAL::Quotient<NT_>&, const
CGAL::Quotient<NT_>&)':
/Developer/Headers/CGAL-3.3.1/include/CGAL/Quotient.h:345: error: expected
/Developer/Headers/CGAL-3.3.1/include/CGAL/Quotient.h:346: error: expected
/Developer/Headers/CGAL-3.3.1/include/CGAL/Quotient.h:353: error: expected
/Developer/Headers/CGAL-3.3.1/include/CGAL/Quotient.h: In member function
'double
CGAL::INTERN_QUOTIENT::Real_embeddable_traits_quotient_base<CGAL::Quotient<NT_>
>::To_double::operator()(const CGAL::Quotient<NT_>&) const':
/Developer/Headers/CGAL-3.3.1/include/CGAL/Quotient.h:686: error: 'abs' is
not a member of 'CGAL'
/Developer/Headers/CGAL-3.3.1/include/CGAL/Quotient.h:693: error: 'abs' is
/Developer/Headers/CGAL-3.3.1/include/CGAL/predicates/sign_of_determinant.h:
In function 'typename CGAL::Sgn<T>::result_type
CGAL::sign_of_determinant3x3(const RT&, const RT&, const RT&, const RT&,
const RT&, const RT&, const RT&, const RT&, const RT&)':
/Developer/Headers/CGAL-3.3.1/include/CGAL/predicates/sign_of_determinant.h:48:
CGAL::sign_of_determinant4x4(const RT&, const RT&, const RT&, const RT&,
const RT&, const RT&, const RT&, const RT&, const RT&, const RT&, const RT&,
/Developer/Headers/CGAL-3.3.1/include/CGAL/predicates/sign_of_determinant.h:62:
CGAL::sign_of_determinant5x5(const RT&, const RT&, const RT&, const RT&,
const RT&, const RT&, const RT&, const RT&, const RT&, const RT&, const RT&)':
/Developer/Headers/CGAL-3.3.1/include/CGAL/predicates/sign_of_determinant.h:78:
CGAL::sign_of_determinant6x6(const RT&, const RT&, const RT&, const RT&,
/Developer/Headers/CGAL-3.3.1/include/CGAL/predicates/sign_of_determinant.h:102:
/Developer/Headers/CGAL-3.3.1/include/CGAL/predicates/kernel_ftC2.h: In
function 'typename CGAL::Equal_to<FT, FT>::result_type
CGAL::equal_lineC2(const FT&, const FT&, const FT&, const FT&, const FT&,
const FT&)':
/Developer/Headers/CGAL-3.3.1/include/CGAL/predicates/kernel_ftC2.h:62:
/Developer/Headers/CGAL-3.3.1/include/CGAL/predicates/kernel_ftC2.h:64:
/Developer/Headers/CGAL-3.3.1/include/CGAL/predicates/kernel_ftC2.h:66:
function 'typename CGAL::Compare<NT>::result_type CGAL::compare_xC2(const
FT&, const FT&, const FT&, const FT&, const FT&, const FT&, const FT&)':
/Developer/Headers/CGAL-3.3.1/include/CGAL/predicates/kernel_ftC2.h:80:
FT&, const FT&, const FT&, const FT&, const FT&, const FT&, const FT&, const
FT&, const FT&)':
/Developer/Headers/CGAL-3.3.1/include/CGAL/predicates/kernel_ftC2.h:108:
/Developer/Headers/CGAL-3.3.1/include/CGAL/predicates/kernel_ftC2.h:109:
/Developer/Headers/CGAL-3.3.1/include/CGAL/predicates/kernel_ftC2.h:110:
/Developer/Headers/CGAL-3.3.1/include/CGAL/predicates/kernel_ftC2.h:111:
/Developer/Headers/CGAL-3.3.1/include/CGAL/predicates/kernel_ftC2.h:126:
/Developer/Headers/CGAL-3.3.1/include/CGAL/predicates/kernel_ftC2.h:127:
CGAL::compare_y_at_xC2(const FT&, const FT&, const FT&, const FT&, const
FT&)':
/Developer/Headers/CGAL-3.3.1/include/CGAL/predicates/kernel_ftC2.h:139:
/Developer/Headers/CGAL-3.3.1/include/CGAL/predicates/kernel_ftC2.h:141:
CGAL::compare_y_at_xC2(const FT&, const FT&, const FT&, const FT&, const FT&,
/Developer/Headers/CGAL-3.3.1/include/CGAL/predicates/kernel_ftC2.h:151:
/Developer/Headers/CGAL-3.3.1/include/CGAL/predicates/kernel_ftC2.h:152:
/Developer/Headers/CGAL-3.3.1/include/CGAL/predicates/kernel_ftC2.h:166:
const FT&, const FT&, const FT&, const FT&, const FT&, const FT&, const FT&)':
/Developer/Headers/CGAL-3.3.1/include/CGAL/predicates/kernel_ftC2.h:185:
/Developer/Headers/CGAL-3.3.1/include/CGAL/predicates/kernel_ftC2.h:186:
/Developer/Headers/CGAL-3.3.1/include/CGAL/predicates/kernel_ftC2.h:187:
CGAL::equal_directionC2(const FT&, const FT&, const FT&, const FT&)':
/Developer/Headers/CGAL-3.3.1/include/CGAL/predicates/kernel_ftC2.h:273:
/Developer/Headers/CGAL-3.3.1/include/CGAL/predicates/kernel_ftC2.h:274:
CGAL::compare_slopesC2(const FT&, const FT&, const FT&, const FT&)':
/Developer/Headers/CGAL-3.3.1/include/CGAL/predicates/kernel_ftC2.h:306:
/Developer/Headers/CGAL-3.3.1/include/CGAL/predicates/kernel_ftC2.h:307:
/Developer/Headers/CGAL-3.3.1/include/CGAL/predicates/kernel_ftC2.h:310:
/Developer/Headers/CGAL-3.3.1/include/CGAL/predicates/kernel_ftC2.h:311:
/Developer/Headers/CGAL-3.3.1/include/CGAL/predicates/kernel_ftC2.h:314:
/Developer/Headers/CGAL-3.3.1/include/CGAL/predicates/kernel_ftC2.h:315:
/Developer/Headers/CGAL-3.3.1/include/CGAL/predicates/kernel_ftC2.h:321:
error: 'abs' is not a member of 'CGAL'
/Developer/Headers/CGAL-3.3.1/include/CGAL/predicates/kernel_ftC2.h:322:
error: no matching function for call to 'compare(<type error>, <type error>)'
/Developer/Headers/CGAL-3.3.1/include/CGAL/predicates/kernel_ftC2.h:324:
/Developer/Headers/CGAL-3.3.1/include/CGAL/predicates/kernel_ftC2.h:325:
CGAL::compare_slopesC2(const FT&, const FT&, const FT&, const FT&, const FT&,
/Developer/Headers/CGAL-3.3.1/include/CGAL/predicates/kernel_ftC2.h:343:
/Developer/Headers/CGAL-3.3.1/include/CGAL/predicates/kernel_ftC2.h:353:
/Developer/Headers/CGAL-3.3.1/include/CGAL/predicates/kernel_ftC2.h:368:
/Developer/Headers/CGAL-3.3.1/include/CGAL/predicates/kernel_ftC2.h:369:
/Developer/Headers/CGAL-3.3.1/include/CGAL/predicates/kernel_ftC2.h:375:
/Developer/Headers/CGAL-3.3.1/include/CGAL/predicates/kernel_ftC2.h:376:
/Developer/Headers/CGAL-3.3.1/include/CGAL/predicates/kernel_ftC2.h:378:
/Developer/Headers/CGAL-3.3.1/include/CGAL/predicates/kernel_ftC2.h:379:
function 'typename CGAL::Same_uncertainty_nt<CGAL::Angle, FT>::type
CGAL::angleC2(const FT&, const FT&, const FT&, const FT&, const FT&, const
FT&)':
/Developer/Headers/CGAL-3.3.1/include/CGAL/predicates/kernel_ftC2.h:431:
function 'typename CGAL::Same_uncertainty_nt<CGAL::Orientation, FT>::type
CGAL::side_of_oriented_lineC2(const FT&, const FT&, const FT&, const FT&,
const FT&)':
/Developer/Headers/CGAL-3.3.1/include/CGAL/predicates/kernel_ftC2.h:617:
/Developer/Headers/CGAL-3.3.1/include/CGAL/rational_rotation.h: In function
'void CGAL::rational_rotation_approximation(const NT&, const NT&, NT&, NT&,
NT&, const NT&, const NT&)':
/Developer/Headers/CGAL-3.3.1/include/CGAL/rational_rotation.h:53: error:
/Developer/Headers/CGAL-3.3.1/include/CGAL/rational_rotation.h:54: error:
/Developer/Headers/CGAL-3.3.1/include/CGAL/rational_rotation.h:139: error:
'void CGAL::rational_rotation_approximation(const double&, NT&, NT&, NT&,
/Developer/Headers/CGAL-3.3.1/include/CGAL/rational_rotation.h:175: error:
/Developer/Headers/CGAL-3.3.1/include/CGAL/rational_rotation.h:176: error:
/Developer/Headers/CGAL-3.3.1/include/CGAL/ConicCPA2.h: In static member
function 'static void CGAL::ConicCPA2<PT, DA>::set_two_linepairs(const _PT&,
const _PT&, const _PT&, const _PT&, CGAL::ConicCPA2<PT, DA>&,
CGAL::ConicCPA2<PT, DA>&)':
/Developer/Headers/CGAL-3.3.1/include/CGAL/ConicCPA2.h:86: error: expected
primary-expression before ')' token
/Developer/Headers/CGAL-3.3.1/include/CGAL/ConicCPA2.h:90: error: expected
/Developer/Headers/CGAL-3.3.1/include/CGAL/ConicCPA2.h:99: error: expected
/Developer/Headers/CGAL-3.3.1/include/CGAL/ConicCPA2.h: In member function
'CGAL::Sign CGAL::ConicCPA2<PT, DA>::vol_derivative(typename _DA::FT,
typename _DA::FT, typename _DA::FT, typename _DA::FT, typename _DA::FT,
typename _DA::FT) const':
/Developer/Headers/CGAL-3.3.1/include/CGAL/ConicCPA2.h:144: error: expected
primary-expression before 'int'
`)' before 'int'
`)' before ';' token
'void CGAL::ConicCPA2<PT, DA>::analyse()':
/Developer/Headers/CGAL-3.3.1/include/CGAL/ConicCPA2.h:191: error: expected
/Developer/Headers/CGAL-3.3.1/include/CGAL/ConicCPA2.h:197: error: expected
/Developer/Headers/CGAL-3.3.1/include/CGAL/ConicCPA2.h:209: error: expected
/Developer/Headers/CGAL-3.3.1/include/CGAL/ConicCPA2.h:210: error: expected
',' or ';' before '::' token
/Developer/Headers/CGAL-3.3.1/include/CGAL/ConicCPA2.h:214: error: expected
/Developer/Headers/CGAL-3.3.1/include/CGAL/ConicCPA2.h:218: error: expected
/Developer/Headers/CGAL-3.3.1/include/CGAL/ConicCPA2.h:227: error: expected
/Developer/Headers/CGAL-3.3.1/include/CGAL/ConicCPA2.h:233: error: expected
/Developer/Headers/CGAL-3.3.1/include/CGAL/ConicCPA2.h:234: error: expected
/Developer/Headers/CGAL-3.3.1/include/CGAL/ConicCPA2.h:238: error: expected
/Developer/Headers/CGAL-3.3.1/include/CGAL/ConicCPA2.h:242: error: expected
/Developer/Headers/CGAL-3.3.1/include/CGAL/ConicCPA2.h:251: error: expected
/Developer/Headers/CGAL-3.3.1/include/CGAL/ConicCPA2.h:260: error: expected
/Developer/Headers/CGAL-3.3.1/include/CGAL/ConicCPA2.h:275: error: expected
/Developer/Headers/CGAL-3.3.1/include/CGAL/ConicCPA2.h:278: error: expected
'CGAL::Oriented_side CGAL::ConicCPA2<PT, DA>::oriented_side(const _PT&)
const':
/Developer/Headers/CGAL-3.3.1/include/CGAL/ConicCPA2.h:380: error: expected
'CGAL::Convex_side CGAL::ConicCPA2<PT, DA>::convex_side(const _PT&) const':
/Developer/Headers/CGAL-3.3.1/include/CGAL/ConicCPA2.h:408: error: expected
/Developer/Headers/CGAL-3.3.1/include/CGAL/ConicCPA2.h:410: error: expected
/Developer/Headers/CGAL-3.3.1/include/CGAL/ConicCPA2.h:412: error: 'abs' is
/Developer/Headers/CGAL-3.3.1/include/CGAL/ConicCPA2.h:412: error: expected
/Developer/Headers/CGAL-3.3.1/include/CGAL/predicates/kernel_ftC3.h: In
CGAL::angleC3(const FT&, const FT&, const FT&, const FT&, const FT&, const
/Developer/Headers/CGAL-3.3.1/include/CGAL/predicates/kernel_ftC3.h:149:
CGAL::equal_directionC3(const FT&, const FT&, const FT&, const FT&, const
FT&, const FT&)':
/Developer/Headers/CGAL-3.3.1/include/CGAL/predicates/kernel_ftC3.h:278:
/Developer/Headers/CGAL-3.3.1/include/CGAL/predicates/kernel_ftC3.h:279:
/Developer/Headers/CGAL-3.3.1/include/CGAL/predicates/kernel_ftC3.h:280:
CGAL::equal_planeC3(const FT&, const FT&, const FT&, const FT&, const FT&,
/Developer/Headers/CGAL-3.3.1/include/CGAL/predicates/kernel_ftC3.h:294:
/Developer/Headers/CGAL-3.3.1/include/CGAL/predicates/kernel_ftC3.h:296:
/Developer/Headers/CGAL-3.3.1/include/CGAL/predicates/kernel_ftC3.h:298:
/Developer/Headers/CGAL-3.3.1/include/CGAL/predicates/kernel_ftC3.h:300:
/Developer/Headers/CGAL-3.3.1/include/CGAL/predicates/kernel_ftC3.h:302:
CGAL::side_of_oriented_planeC3(const FT&, const FT&, const FT&, const FT&,
/Developer/Headers/CGAL-3.3.1/include/CGAL/predicates/kernel_ftC3.h:312:
function 'typename CGAL::Same_uncertainty_nt<CGAL::Bounded_side, FT>::type
CGAL::side_of_bounded_sphereC3(const FT&, const FT&, const FT&, const FT&,
/Developer/Headers/CGAL-3.3.1/include/CGAL/predicates/kernel_ftC3.h:374:
/Developer/Headers/CGAL-3.3.1/include/CGAL/squared_distance_utils.h: In
function 'bool CGAL::CGALi::same_direction_tag(const typename K::Vector_2&,
const typename K::Vector_2&, const K&, const CGAL::Cartesian_tag&)':
/Developer/Headers/CGAL-3.3.1/include/CGAL/squared_distance_utils.h:265:
/Developer/Headers/CGAL-3.3.1/include/CGAL/squared_distance_utils.h:266:
/Developer/Headers/CGAL-3.3.1/include/CGAL/squared_distance_utils.h:268:
const typename K::Vector_2&, const K&, const CGAL::Homogeneous_tag&)':
/Developer/Headers/CGAL-3.3.1/include/CGAL/squared_distance_utils.h:284:
/Developer/Headers/CGAL-3.3.1/include/CGAL/squared_distance_utils.h:285:
/Developer/Headers/CGAL-3.3.1/include/CGAL/squared_distance_utils.h:287:
/Developer/Headers/CGAL-3.3.1/include/CGAL/squared_distance_2_1.h: In
function 'typename K::RT CGAL::CGALi::_distance_measure_sub(const typename
K::RT&, const typename K::RT&, const typename K::Point_2&, const typename
K::Point_2&)':
/Developer/Headers/CGAL-3.3.1/include/CGAL/squared_distance_2_1.h:193: error:
/Developer/Headers/CGAL-3.3.1/include/CGAL/squared_distance_2_1.h:194: error:
K::RT&, const typename K::RT&, const typename K::Vector_2&, const typename
K::Vector_2&)':
/Developer/Headers/CGAL-3.3.1/include/CGAL/squared_distance_2_1.h:297: error:
/Developer/Headers/CGAL-3.3.1/include/CGAL/squared_distance_2_1.h:298: error:
/Developer/Headers/CGAL-3.3.1/include/CGAL/squared_distance_3_0.h: In
function 'bool CGAL::CGALi::same_direction_tag(const typename K::Vector_3&,
const typename K::Vector_3&, const K&, const CGAL::Cartesian_tag&)':
/Developer/Headers/CGAL-3.3.1/include/CGAL/squared_distance_3_0.h:240: error:
/Developer/Headers/CGAL-3.3.1/include/CGAL/squared_distance_3_0.h:241: error:
/Developer/Headers/CGAL-3.3.1/include/CGAL/squared_distance_3_0.h:242: error:
/Developer/Headers/CGAL-3.3.1/include/CGAL/squared_distance_3_0.h:244: error:
/Developer/Headers/CGAL-3.3.1/include/CGAL/squared_distance_3_0.h:247: error:
/Developer/Headers/CGAL-3.3.1/include/CGAL/squared_distance_3_0.h:248: error:
/Developer/Headers/CGAL-3.3.1/include/CGAL/squared_distance_3_0.h:250: error:
const typename K::Vector_3&, const K&, const CGAL::Homogeneous_tag&)':
/Developer/Headers/CGAL-3.3.1/include/CGAL/squared_distance_3_0.h:268: error:
/Developer/Headers/CGAL-3.3.1/include/CGAL/squared_distance_3_0.h:269: error:
/Developer/Headers/CGAL-3.3.1/include/CGAL/squared_distance_3_0.h:270: error:
/Developer/Headers/CGAL-3.3.1/include/CGAL/squared_distance_3_0.h:272: error:
/Developer/Headers/CGAL-3.3.1/include/CGAL/squared_distance_3_0.h:275: error:
/Developer/Headers/CGAL-3.3.1/include/CGAL/squared_distance_3_0.h:276: error:
/Developer/Headers/CGAL-3.3.1/include/CGAL/squared_distance_3_0.h:278: error:
/Developer/Headers/CGAL-3.3.1/include/CGAL/squared_distance_3_1.h: In
function 'typename K::RT CGAL::CGALi::_distance_measure_sub(typename K::RT,
typename K::RT, const typename K::Vector_3&, const typename K::Vector_3&,
const K&)':
/Developer/Headers/CGAL-3.3.1/include/CGAL/squared_distance_3_1.h:214: error:
/Developer/Headers/CGAL-3.3.1/include/CGAL/squared_distance_3_1.h:215: error:
function 'typename K::FT CGAL::CGALi::squared_distance_parallel(const
typename K::Segment_3&, const typename K::Ray_3&, const K&)':
/Developer/Headers/CGAL-3.3.1/include/CGAL/squared_distance_3_1.h:353: error:
/Developer/Headers/CGAL-3.3.1/include/CGAL/squared_distance_3_1.h:354: error:
/Developer/Headers/CGAL-3.3.1/include/CGAL/squared_distance_3_1.h:356: error:
/Developer/Headers/CGAL-3.3.1/include/CGAL/squared_distance_3_2.h: In
function 'typename K::FT CGAL::CGALi::squared_distance(const typename
K::Ray_3&, const typename K::Plane_3&, const K&)':
/Developer/Headers/CGAL-3.3.1/include/CGAL/squared_distance_3_2.h:118: error:
K::Segment_3&, const typename K::Plane_3&, const K&)':
/Developer/Headers/CGAL-3.3.1/include/CGAL/squared_distance_3_2.h:166: error:
/Developer/Headers/CGAL-3.3.1/include/CGAL/Segment_2_Segment_2_intersection.h:
In member function 'typename
CGAL::CGALi::Segment_2_Segment_2_pair<K>::Intersection_results
CGAL::CGALi::Segment_2_Segment_2_pair<K>::intersection_type() const':
/Developer/Headers/CGAL-3.3.1/include/CGAL/Segment_2_Segment_2_intersection.h:358:
/Developer/Headers/CGAL-3.3.1/include/CGAL/Ray_2_Segment_2_intersection.h: In
CGAL::CGALi::Ray_2_Segment_2_pair<K>::Intersection_results
CGAL::CGALi::Ray_2_Segment_2_pair<K>::intersection_type() const':
/Developer/Headers/CGAL-3.3.1/include/CGAL/Ray_2_Segment_2_intersection.h:127:
/Developer/Headers/CGAL-3.3.1/include/CGAL/Ray_2_Ray_2_intersection.h: In
CGAL::CGALi::Ray_2_Ray_2_pair<K>::Intersection_results
CGAL::CGALi::Ray_2_Ray_2_pair<K>::intersection_type() const':
/Developer/Headers/CGAL-3.3.1/include/CGAL/Ray_2_Ray_2_intersection.h:122:
/Developer/Headers/CGAL-3.3.1/include/CGAL/Straight_2.h: In constructor
'CGAL::CGALi::Straight_2_<K>::Straight_2_(const typename K::Line_2&)':
/Developer/Headers/CGAL-3.3.1/include/CGAL/Straight_2.h:117: error: 'abs' is
/Developer/Headers/CGAL-3.3.1/include/CGAL/Straight_2.h:119: error: expected
'CGAL::CGALi::Straight_2_<K>::Straight_2_(const typename K::Ray_2&)':
/Developer/Headers/CGAL-3.3.1/include/CGAL/Straight_2.h:143: error: 'abs' is
/Developer/Headers/CGAL-3.3.1/include/CGAL/Straight_2.h:145: error: expected
'CGAL::CGALi::Straight_2_<K>::Straight_2_(const typename K::Ray_2&, bool)':
/Developer/Headers/CGAL-3.3.1/include/CGAL/Straight_2.h:159: error: 'abs' is
/Developer/Headers/CGAL-3.3.1/include/CGAL/Straight_2.h:161: error: expected
'CGAL::CGALi::Straight_2_<K>::Straight_2_(const typename K::Segment_2&)':
/Developer/Headers/CGAL-3.3.1/include/CGAL/Straight_2.h:180: error: 'abs' is
/Developer/Headers/CGAL-3.3.1/include/CGAL/Straight_2.h:182: error: expected
/Developer/Headers/CGAL-3.3.1/include/CGAL/Straight_2.h: In member function
'int CGAL::CGALi::Straight_2_<K>::collinear_order(const typename K::Point_2&,
const typename K::Point_2&) const':
/Developer/Headers/CGAL-3.3.1/include/CGAL/Straight_2.h:347: error: expected
/Developer/Headers/CGAL-3.3.1/include/CGAL/Segment_2_Iso_rectangle_2_intersection.h:
In constructor
'CGAL::CGALi::Segment_2_Iso_rectangle_2_pair<K>::Segment_2_Iso_rectangle_2_pair(const
typename K::Segment_2*, const typename K::Iso_rectangle_2*)':
/Developer/Headers/CGAL-3.3.1/include/CGAL/Segment_2_Iso_rectangle_2_intersection.h:130:
/Developer/Headers/CGAL-3.3.1/include/CGAL/Intersections_3/intersection_3_1_impl.h:
In function 'CGAL::Object CGAL::CGALi::intersection(const typename
K::Segment_3&, const typename K::Iso_cuboid_3&, const K&)':
/Developer/Headers/CGAL-3.3.1/include/CGAL/Intersections_3/intersection_3_1_impl.h:607:
/Developer/Headers/CGAL-3.3.1/include/CGAL/Intersections_3/intersection_3_1_impl.h:608:
/Developer/Headers/CGAL-3.3.1/include/CGAL/Intersections_3/intersection_3_1_impl.h:609:
/Developer/Headers/CGAL-3.3.1/include/CGAL/MP_Float.h: At global scope:
/Developer/Headers/CGAL-3.3.1/include/CGAL/MP_Float.h:245: error: expected
unqualified-id before ')' token
`)' before '>=' token
/Developer/Headers/CGAL-3.3.1/include/CGAL/MP_Float.h: In member function
'void CGAL::MP_Float::gcd_normalize()':
/Developer/Headers/CGAL-3.3.1/include/CGAL/MP_Float.h:325: error: expected
'CGAL::MP_Float CGAL::MP_Float::unit_part() const':
/Developer/Headers/CGAL-3.3.1/include/CGAL/MP_Float.h:333: error: expected
/Developer/Headers/CGAL-3.3.1/include/CGAL/MP_Float.h:338: error: expected
'CGAL::Sign CGAL::Real_embeddable_traits<CGAL::MP_Float,
CGAL::Boolean_tag<false> >::Sign::operator()(const CGAL::MP_Float&) const':
/Developer/Headers/CGAL-3.3.1/include/CGAL/MP_Float.h:466: error: expected
/Developer/Headers/CGAL-3.3.1/include/CGAL/MP_Float.h: In function
'CGAL::Sign CGAL::CGALi::compare_bitlength(const CGAL::MP_Float&, const
CGAL::MP_Float&)':
/Developer/Headers/CGAL-3.3.1/include/CGAL/MP_Float.h:513: error: 'abs' is
/Developer/Headers/CGAL-3.3.1/include/CGAL/MP_Float.h:514: error: 'abs' is
'std::pair<CGAL::MP_Float, CGAL::MP_Float> CGAL::CGALi::division(const
CGAL::MP_Float&, const CGAL::MP_Float&)':
/Developer/Headers/CGAL-3.3.1/include/CGAL/MP_Float.h:586: error: expected
/Developer/Headers/CGAL-3.3.1/include/CGAL/MP_Float.h:595: error: 'abs' is
/Developer/Headers/CGAL-3.3.1/include/CGAL/Lazy_exact_nt.h: In constructor
'CGAL::Lazy_exact_Abs<ET>::Lazy_exact_Abs(const CGAL::Lazy_exact_nt<ET>&)':
/Developer/Headers/CGAL-3.3.1/include/CGAL/Lazy_exact_nt.h:279: error: 'abs'
/Developer/Headers/CGAL-3.3.1/include/CGAL/Lazy_exact_nt.h: In member
function 'void CGAL::Lazy_exact_Abs<ET>::update_exact()':
function 'CGAL::Sign CGAL::Real_embeddable_traits<CGAL::Lazy_exact_nt<ET>,
CGAL::Boolean_tag<false> >::Sign::operator()(const CGAL::Lazy_exact_nt<ET>&)
const':
/Developer/Headers/CGAL-3.3.1/include/CGAL/Lazy_exact_nt.h:1040: error:
/Developer/Headers/CGAL-3.3.1/include/CGAL/Lazy_exact_nt.h:1044: error:
